Question about Nokia Lumia 710
Invald sim card
Can't make a phone call
STRAIGHT TALK PHONE
Troubleshooting - Sim Card - Straight Talk
https://www.straighttalk.com/wps/wcm/connect/StraightTalk/.../Sim+Card...
The "Enter PUK code" message means that the SIM card is blocked. ... Simply insertthe SIM card into the back of your phone or make sure that the SIM card ... on you may receive this message because your phone has not yet been Activated.
Products - Phones - Straight Talk
https://www.straighttalk.com/wps/wcm/connect/StraightTalk/.../Phone/
Straight Talk offers a variety of phone models to choose from. .... do support a SIM Card. However, if your iPhone is a 4 or 4S, DO NOT insert a SIM Card into it.
HI my straight talk phone is saying insert sim sos calls only ...
www.askmefast.com > ... > Phone
Jan 01, 2016 | Cell Phones
Even I inserted the sim card phone shows Insert sim card?How to solve it?
Well it is either a problem with the SIM card or the phone. First you should test out your SIM card.
Put the SIM in a friend's phone. If you put the SIM card in this other phone but it still says insert sim card, then it is the SIM that is no good. If the SIM works fine in the other phone, it would be the phone that is the problem.
May 07, 2011 | Cell Phones
I have an old att sim card in my phone and when i turn it on it says invald sim and i cant get wifi
You should be able to bypass that screen, but that will depend on the handset. You can goto att.com/wireless and select wireless, then support, then select your device, and use the tutorials if you are unable to get past that screen,
Mar 27, 2011 | Cell Phones
My phone shows "please insert
You could try to remove your sim card.
Install battery and turn on phone without sim card.
Use phone without sim card and do some operations.
This will check if you phone is working correctly.
Turn phone off and install sim card.
Made sure sim card is install correctly.
If this does not work, it could be the sim card is bad.
Jan 15, 2011 | Cell Phones
Samsung Geino, my sim is inserted but my phones keeps saying insert sim i carnt phone anyone blah blah help
Hi,when a phone keeps saying insert Sim card, is either the Sim card has problem or the Sim tray of the phone is bad and will need tobe replaced.
To confirm, Take the Sim card and insert it into another phone, If it still says insert Sim, that means the Sim card is bad, But if the Sim card works with another phone, That means the Sim tray of the phone is damaged.
Sim tray is located on the phone where you insert your Sim card in on the phone to make sure the Sim works with the phone.
Have a nice day.
Sep 12, 2010 | Cell Phones
Sim card
Sounds like phone is locked or firmware is bad
Mar 15, 2009 | Motorola Mobility RAZR V3
Invalid SIM
I think you have to unlock your phone for the SIM card to work. I don't have any links for that, but I'm sure if you ask around you can find a local shop to assist.
Apr 28, 2008 | AT&T Blackberry Curve 8300 Smartphone
Nokia Lumia 710 Logo
26 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
