Question about H2O FURNISHINGS LLC Furniture
Broken Pieces I have two broken shelves and have been trying to get a hold of the company for several months any tips
  • 100 Answers
SOURCE: Broken glass shelves- SR-4433S
you would have to order them from sanyo at www.us.sany.com
Posted on Oct 30, 2007
  • 518 Answers
SOURCE: fridge parts broken
Try checking HERE.
Hope that gets ya fixed up...
Geno
Posted on Mar 24, 2008
compdoctor20
  • 172 Answers
SOURCE: gateway 503gr power switch
if you are a practical person, the power on switch is the crudest item ever on a pc. The switch simply completes a circuit. If you look on you motherboard at the front panel connector cables, you will see the two that go to the power on switch. remove them, flash a small screw driver across the terminals and it will come to life
Posted on Nov 15, 2008
advacak
  • 125 Answers
SOURCE: Kenmore Progessive Lead wire "A" brackets broke on swivel
you could try GOOP adhesive
Posted on Dec 30, 2008
  • 396 Answers
SOURCE: broken table support
See if you can find the parts from this site. http://www.huskysupport.com/products/product.aspx?ID=4
Posted on Jul 28, 2010
Testimonial: "Fantastic!"
How to repair a cracked and broken Ne q'wa Xmas ornament.
These are reverse painted, so the paint is on the inside. I would glue it, then remove the top and pour in PVA Carpenters adhesive, swirl it around and then tip it upside down the drain. Test the adhesive on a small part of the paint first.
Glue the parts together with Super Glue GEL. This is easier to apply.
http://neqwaornament.com/
Jan 05, 2016 | Cars & Trucks
Icannot get the solder to hold to the items I am trying to hold together. My cold heat says it came with a book but it did not. Do you use flux? I am trying to solder broken pieces of jewelry. Karen...
I know when you are using solder for plumbing and some electrical you have to use flux. I would think if using solder on jewelry it would be also needed. I am not a jewelry expert though.
May 10, 2011 | Coleman Cable Coleman Cold Heat Bevel Tip...
Left side of top sliding shelf is broken, White plastic ballbearing strip is broken off in two pieces. The side will fall out if pulled too far Also 2 plastic tabs approx. 1"long have fallen out....
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend
http://ping.fm/zJDAM
heatman101
Apr 20, 2011 | KitchenAid Dishwashers
The pivot point on the seats has broken on several
You could try "Mighty Putty" if you still have the pieces it works well to hold things together and is very strong.
Jan 27, 2010 | Mad River Canoe Boating
The compressor is very loud and has been for some time. The refrigerator still keeps things cold. The noise is not from a fan
This is a defective compressor. Can continue to run this way for months or years. You should check to see that nothing is jammed under the fridge near the compressor. The compressor is shock mounted so it can vibrate a little. If the rubber mounts come out or get broken it can be very loud.
Take everything out, including shelves, and tip up to one side to look using a strong helper. turn on while tipped partly over if it is bad mounts you will see it.
Aug 22, 2009 | Kenmore Refrigerators
Broken Shelves
The only shelves you'll get for this model is probably the ones offered by the manufacturer.
The best way for longevity of the shelves, is to make sure that you do not put too many heavy things on it, and be careful when cleaning and replacing shelves..
May 28, 2008 | Frigidaire FRS3R5EMB Side by Side...
Freezer Shelves are too small for freezer and keep falling when I put food on them...
I had the same problem with the freezer sheles being too small in my GE Profile side by side. The shelves would simply collapse down with any weight on them.
After measurng the gap, I determined that the shelves were approximately 7/16" too narrow.
The fix I did was simple, effective, and very cheap.
I bought a roll of clear flexible polyethylene tubing at Lowes for about $5.The tubing is 3/8" outer diameter, 1/4" inner diameter (see picture below).
I cut pieces to fit along the side rails of the shelf, and then sliced the tube pieces down their length with a utility knife. I wrapped the pieces around the outside rails on each side of the shelf. It took a little work, but I got the tube pieces attached.
In a few spots, I did a double wrap of tubing.
The shelves fit tightly now and can hold significant weight without collapsing. Plus, they don't look too bad.
I hope GE fixes this simple problem in the future.
2_29_2012_2_35_52_am.jpg2_29_2012_2_36_07_am.jpg2_29_2012_2_36_33_am.jpg2_29_2012_2_36_53_am.jpg
Jan 21, 2008 | GE Profile PSW26P Stainless Steel Side by...
Furniture Logo
82 people viewed this question
Top H2O FURNISHINGS LLC Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a H2O FURNISHINGS LLC Furniture Expert? Answer questions, earn points and help others
