Question about Dryers
Dryer goes on but kicks off within 3 minutes.
  • debemack1 Jun 15, 2009
    can I replace the Thermistor on my Amana Distinction Dryer myself?
  • 27 Answers
The Thermistor is bad and needs to be replaced
Posted on Jun 15, 2009
Igniter starts to glow for 3-5 sec while making noise every minute or so
Check the thermocouple it is going bad or already has and that is why the gas valve is not staying open.
Jul 08, 2017 | Whirlpool GGW9200L Gas Dryer
Everything works but the gas dont kick on when the pilet comes on what can i do
Hello Anthony,
Thier is one of two things causing the dryer to not heat depending on what you see happening will determine what the exact problem is;
The gas valve coils are bad...if the igniter comes on and goes off but no flame the coils on the gas valve will be whats bad
The flame sensor is whats wrong... if the igniter comes on AND STAYS ON and does not go off (usually within 1 minute) the flame sensor is going to be what the problem is
GENE
Sep 10, 2011 | Maytag Dryers
Heat kicks off after 2-3 minutes. I have replaced the coils. There is a distinct "clicking" sound just before the flame cuts off. Any ideas?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 08, 2011 | Kenmore 73932 Gas Dryer
For whirlpool duet GGW 9250 PW0 GAS DRYER How do you know if the gas solenoid are bad? I check the resistance as per manual and its within its limit. It ignites and flames come out but the flame only...
The gas valve solenoid coils work when cool that's why the resistance reading is within the limit but fail when heated. Bypass the thermostat on the burner funnel and if the flame still goes out too soon, the coils are weak and both must be replaced. The resistance reading is reliable only when the dryer does not heat at all or shall we say the flame does not go on at all and the purpose is to check the continuity of the coil.
Oct 12, 2010 | Dryers
When my mdg 6000bww is turn on heating element glows, flame ignites, then flames goes off within 5 minutes. After waiting approximately 15 to 20 minutes, until it seems to cool down can restart and goes...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Heat kick on then off
Check the thermostats. They work when cold but will not reset once warmed up.
Eric
May 27, 2009 | Kenmore Dryers
Boggs down after 2-3 minutes.
Yeah after boot up the cooling fan should kick in. If it does not and it is a laptop it will get too hot in there. Thermal Shutdown protection will kick in, if it is equip. If in 2-3 minutes it got so hot reaching its preset temperature shutdown, it will be down to prevent damage to the system.
Apr 13, 2009 | Toshiba Satellite A45-S121 Notebook
Maytag atlantis gas dry is not heating up its about 6 years old
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Mar 28, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Whirpool Senseon stops mid-cycle
there is a thermostat called a thermister on the blower box that will do that(run for few minutes and shut off) get the model number off dryer door or on inside dryer door wall ,go to sears .com click on parts put in model number and it will show you exactly where everything goes,let me know how you do-mike
Oct 02, 2008 | Whirlpool LER4634J Electric Dryer
Dryers Logo
226 people viewed this question
Top Dryers Experts
Marvin
Marvin
