Question about Necchi Sewing Machines
New home 921 tension assembly
Tension is out
WHY??!! *Check if thread is entangled. Check if needle is bent. So far as I can tell everything is fine, used new bobbin, new needle, still getting error. How do I know if the motor has become locked
Time to take it in and have the repair tech service & clean upper tension assembly. When you clip/ change threads be sure not to pull the thread back out of tension assembly. Snip thread at spool, raise foot to release tension and then pull the short thread out from the needle. The Automatic tension is very delicate and pulling thread out backwards can cause thread/lint build up and problems like your having. Sal the Sewing Gal
Oct 30, 2015 | Baby Lock Ellure
Repair tension spring
Is this the upper thread tension spring? In most instances it is replace rather than repair. A good service manual or youtube search can provide instructions on how to take apart the tension assembly and replace the spring with a new one.
Jan 01, 2015 | Sewing Machines
Bottom tension on my bernette 50 sewing mechine don't know how to fix it.
Bottom tension is controlled by the bobbin case. First, ensure that the thread is wound tight onto the bobbin (should not be spongy when you push your fingernail into into it) Looking at the open side of the bobbin case, insert the bobbin into the bobbin case (so the thread winds off in a clockwise direction) and feed under the 'tension finger'. If you now hold the end of the thread, suspending the bobbin and case from it, the assembly should not drag any more thread out of the bobbin case. If it does, the small screw on the tension finger needs to be tightened slightly. If the assembly does not drag out any more thread, give the thread a little upwards tug. The assembly should slide down a little.If it does not slide, the tension finger is too tight - loosen it a little.
Insert a NEW needle, make sure the top thread is correctly threaded and tension is set at the 'normal' setting (as per book) ..... .... try sewing a sample. Note: using 'cheap' thread will cause all sorts of tension issues as well as fluff up your machine fast - avoid it!
Good luck
Feb 03, 2014 | Bernina Sewing Machines
Singer 301 won't stitch properly, thread bunching up on underside
Likely that it is a lower tension issue
Good luck
Oct 12, 2013 | Bernina Artista 180
Bottom tension is too loose
You really need a proper set of weights and test spindle to adjust the bobbin tension, however if the bobbin tension is genuinely too loose, you can adjust it by turning the tension screw clockwise - this is the larger of the two screws on the side that are attached to the spring under-which the thread goes when it comes off the bobbin. You only need to turn the screw a little bit to make a big difference to tension, so dont overdo it.
Jan 27, 2012 | Bernina Artista 180
Where do i put the oil in my ancient new home 921 my granddaughter is desparate to take over?
    New Home NLB Manual
  • Part 1 Pages 1-13 (~6Mb)
  • Part 2 Pages 14-25 (~5Mb)
  • Part 3 Pages 26-36 (~4Mb)
YOU CAN VIEW THE MANUAL
May 24, 2010 | Janome Sewing Machines
Janome 6600 tension
You need to do a tension assembly test.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Tension assembly test. To do this test. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.)
If it doesn’t work this way then you probably have a piece of thread or lint stuck inside the tension discs. To remove it, turn the tension to 0 zero and raise the presser foot.Using a small screwdriver, open the space between the discs and spray with canned or compressed air. The stuff should come out. Do the tension test again to make sure you got everything and then try sewing again.
sewman7
Feb 16, 2009 | Sewing Machines
Pfaff Creative 7570
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}You need to do a tension assembly test
Tension assembly test. To do this test. Pull the threadthrough the tension assembly and test it to make sure the tension is workingcorrectly.
(To do this test, adjust your tension setting to normal or medium or 5 orsomething in the middle. Raise the presser foot and pull the thread through thetension. It should pull easily!! Lower the presser foot and pull the thread. Itshould pull noticeably harder.)
If it doesn’t work this way then you probably have a pieceof thread or lint stuck inside the tension discs. To remove it, turn thetension to 0 zero and raise the presser foot.Using a small screwdriver, openthe space between the discs and spray with canned or compressed air( a needle will work also). The stuffshould come out. Do the tension test again to make sure you got everything andthen try sewing again.
sewman7
Nov 18, 2008 | PfaFF Creative 7570
Juki DDL 8300
You need to do a tension test.
If it doesn't do this you ned to rethread it through the tension discs and make sure the thread is between the discs.
sewman7
Oct 11, 2008 | Sewing Machines
Threading my sewing machine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Aug 27, 2008 | New Home HF-106
Sewing Machines Logo
19 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
