Question about Viking Genuine C8983701 Thermistor
I have a viking vcrb536rss all refrigerator and the thermister might be bad. I have a new one and pulled old before I marked the wire placement. Does this thermister have a certain wire to prong conn
Thermister c8983701 viking vcrb536 all frig wire placement on thermister
Door seal for a viking beverage center/wine cooler VUWC140
What did you need to know? If it fell out it just pushes back in. Press it in with your thumbs. If you want to replace it its very easy to change. Just pull out the old one and put the new one against the door and push it back into the tracks.
Sep 20, 2016 | Viking Refrigerators
How to replace the condensor fan on GE Mod.gdl20kcsabs --bottom freezer
How To Replace the Condenser Fan The condenser fan is located behind the refrigerator. It may be necessary to remove an access panel to reach it.
If the fan blade is damaged, it can be removed from the fan motor and replaced separately.
Caution:Please read our safety information before attempting any testing or repairs.
cautiontri.gif Before replacing the condenser fan, unplug the refrigerator to avoid an electrical shock hazard.
The fan motor is held in place with screws and possibly a mounting bracket. Remove the bracket and the screws and pull the motor back away from the housing.
The fan motor is connected by two or three wires. Label the wire placement on the motor before disconnecting the wires. The wires are connected to the terminals with slip-on connectors or a plug. Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Remove the fan blade from the old motor and install it onto the new motor. Connect the wires to the new motor and install the motor into the bracket or housing. Make certain that all of the screws are tightened securely.
Replace the access cover (if any) and plug in the refrigerator.
Jul 15, 2011 | Refrigerators
What fin does the thermister fit on?
It clips on to the tube near the fins. Here is a link that shows a typicall placement http://appliancehelponline.com/refertopdefrosttstat.html
Sep 17, 2010 | Dometic NDR 1062 Refrigerator
Food is unthawing
Cmax,
The cause of this is the evaporator thermister. Sounds daunting, doesn't it? It's not. See? This is an electronic component that connects to the main computer and is used to monitor the temperature of the evaporator during the defrost cycle. When it fails, the main computer simply doesn't go into its' defrost cycle. Then you'll see frost build up on the rear panel inside the freezer, your beer compartment will get warm and the fan inside the freezer will run constantly (ahhh!).
The repair is cheap. Seriously cheap (and easy, too!) It'll take me longer to type out the repair thn it would if I'd actually DONE the repair (I type slow). Take a gander at the full size diagram of your fridge's evaporator (freezer) section here. You'll be replacing # 243... it's located at the top of the coils on the left.
You'll need;
Phillips screwdriver
A towel (maybe)
Hair dryer
Wire cutters
Wire strippers
2 Wire nuts (small blue ones) <--- all of this is found at a local hardware store (except for the towel. Unless it's a "shop" towel)
Pull all the frozen stuff outta the freezer and remove the shelves and the basket at the bottom. Now remove the back panel. You'll probably see a huge block of ice now. Your jaw will most likely drop and you'll feel like freaking out..... don't. Grab the hair dryer and melt all of that outta there. (NOTE---> WHEN DOING THIS, KEEP THE DRYER IN MOTION. IF YOU DON'T, YOU RISK WARPING THE PLASTIC INNER LINER)
Now that all the frost is gone, look at the top left of the aluminum coils. You'll see the thermister clipped to one of the tubes (it's the only thing there that has 2 white wires going to it). Remember where it's clipped, then unclip it. Cut the wires close to the base of the thermister, keep the clip. Now seperate the 2 white wires and strip them back about 3/8". Now take your new thermister and install it.
Take one of your newly stripped wires and twist it together to one of the new thermister wires and cap it off with one of the blue wire nuts. Do the same with the next wire. Now take the clip that you saved from the old thermister and place it on the new one and clip it back onto the same tube the old thermister came from.
All you gotta do now is rebuild it all.
Please don't forget to rate this solution as "FixYa". OK?
SG
Apr 22, 2009 | GE GSH25JFR Side by Side Refrigerator
Does not freeze items / ice build up on the back wall
Your defrost heater is probably gone. Or you could have a bad thermister. This is not a job for the ordinary householder. Get a pro. This ice box has a computer board that relys on thermisters to report frost buildup and proper defrost proceedure.
Jan 08, 2009 | LG LSC26905TT Side by Side Refrigerator
Viking professional 30 inch, sparking problem
If you have replaced the spark module with the new, blue PA020041 Tytronics 0+4 spark module, the physical positions of the leads that go to the burner igniters are reversed compared to the positions on the old, white module. Make sure that the switch wire for the burner and the position of the spark wire both go to the same burner! The positions are marked on the white label with green lettering.
Nov 25, 2008 | Viking 31 in. VGSU101 Gas Cooktop
GE side By Side GSS22JEMDWW
Maybe but there is also a thermister in the defrost system that might be bad. The thermister is a small, white, barrell shape and is as big around as a pencil, It has 2 wires going in it and is attached to the top of the coils in the freezer.
Jun 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezing food in Frig especially lower compartments
Is you refrig. cycling off and on?... sounds like a themostate if its NOT.. you might see if you have vents that have adjustments.. pull out the crispers and check for adjustable vents ... if there close them down some.
Aug 30, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Viking Genuine C8983701 Thermistor Logo
Top Viking Dishwashers Experts
Mike
Don Kahr
Don Kahr
Level 1 Expert
Rick Gloria Malmoe
Rick Gloria Malmoe
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
