Question about Motorola Mobility H620 Bluetooth Headset
H620 reset
H620 flashes pink 10 times when turned on. I have charged the unit and had a green indicator, Any idea what the flashing pink means when turned on.
if the flashes are rapid, normally it means that the connection was successful. A quick google search for motorola h620 should bring up the users manual in pdf format with an explaination of all the light combinations
Feb 01, 2011 | Motorola Mobility H620 Bluetooth Headset
I have the Motorola H620 bluetooth and it is paired fine, phone answer and dial and voice activation works fine, but, music will not play through the headset. When I play my ipod app in my iphone, music...
1)this feature not availeble
2)go to this link 100% sure solve your problem http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones%20Accessories/H620/US-EN/_Documents/Static%20Files/H620_QSG_US_9518A57A.pdf
Nov 13, 2010 | Motorola Mobility H620 Bluetooth Headset
Can u give me the pAiring pin for m h620
Motorola handsets and accessories will use the following default passkeys: 0000 or 1234, if not, then check the fol link
https://motorola-global-en-usa.custhelp.com/app/answers/detail/a_id/21216/~/bluetooth-passkey
Sep 14, 2010 | Motorola Mobility H620 Bluetooth Headset
Need code for motorola h620 for the iphone 4
code is 0000. same for all Bluetooth headsets. Hope this Helped! Remember to Rate!
Aug 26, 2010 | Motorola Mobility H620 Bluetooth Headset
I need the passkey for the Motorola H620
Try 0000. I am sure that it will work as this is default key for all bluetooth devices.
May 28, 2010 | Motorola Mobility H620 Bluetooth Headset
Need pin number to use my H620 with my iphone
First try '0000' (four zeros). If it doesn't work, then try '1234'.
Hope it works for you.
Cheers! Carlos
May 13, 2010 | Motorola Mobility H620 Bluetooth Headset
Motorola Mobility H620 Bluetooth Headset Logo
23 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
