Question about AT&T GoPhone Z222
Display screen does not work, how do you fix?
Display screen is black, how do you fix?
Screen won't come on my asus laptop.
Laptop screen won't turn on, but works with external monitor ...
www.tomsguide.com/.../laptop-screen-turn-works-external-monitor.html
Oct 16, 2015 - Hello, my laptop screen won't display anything. It boots up and ... External Monitor; Function Keys; Laptop Screen; Windows 8; Asus. Display.
ASUS laptop screen won't display anything - Tom's Guide
www.tomsguide.com/answers/id.../asus-laptop-screen-display.html
Aug 28, 2013 - My laptop screen won't display anything Forum; Asus n56vz laptopwont ... i cant remove the asus battery to my laptop and the screen wont turn ...
Asus laptop black screen problem - YouTube
? 7:52
https://www.youtube.com/watch?v=gRQgN5AT3a0
Aug 2, 2011 - Uploaded by mrwangyanfei
Black screen when switch on Asus laptop (N61J) ... I turn on mypc and the screen stays black. I tried ...
Dec 13, 2015 | ASUS Computers & Internet
What caused a black screen
I had the same problem. While rebooting the laptop the screen would be on for a few seconds after it finished rebooting then the display would go black. If you looked very carefully at the screen you could see the image was there but there was no light behind the screen to make the image visible.
I removed the black plastic display bezel cover that goes around the edge of the display screen to check out the lights and wiring. I found a small magnet that belongs inside the display bezel had fallen out of it's slot in the plastic bezel and was stuck to the inverter pcb (printed cicuit board). To fix this problem I secured the magnet into it's slot inside the display bezel with a bit of glue. After fixing the problem and putting the display bezel back together the laptop worked normally.
The magnet could possibly fall out if the laptop was closed and upside down then dropped on a hard surface. Mine did not feel very secure in the mounting slot which is why I secured it with glue.
This magnet is how the laptop knows the lid is closed. When the laptop is closed the magnet is moved closer to a magnetic switch on the inverter pcb and activates the switch. The laptop thinks it is closed and shuts off the lights behind the display screen. When the magnet fell out of it's slot and stuck to the inverter it activated the magnetic switch all the time whether the laptop was open or closed. This caused the laptop to think it was closed and shut off the lights behind the dispaly screen as soon as the reboot finished.
Aug 28, 2014 | Acer Aspire Computers & Internet
Compaq presario cq61 display not show
Aug 11, 2012 | Compaq Presario CQ61-310US Laptop
Everything lights up but the screen is black and stays black
hi Friend your Problem is that your cellphone is not working properly all the functions are working but screen stays black.so it can be happend by 2 reasons.-1>i think you are using slider phone,so slider phones always uses a belt between screen and keypad some times, i think in your cellphone its not working properly you'll have to go any repairing shop and fix this problem with changing your belt..2>if you are not using slider phone then something wrong with your display ,means you'll have to change your display.
thnks , for further query feel free to ask ,i am always here for you.
Aug 14, 2011 | Cell Phones
Why screen is black out.
On my Windows 7 laptop, I got problem of Black Screen of Death, Windows Boot Genius fix the problem without data loss! I vote it!
Jan 26, 2011 | Computers & Internet
Inside screen when black and the outside sreen was still working then it went black my phone still works like normal just the screens are black and i cant see anything
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
Apr 16, 2010 | Motorola Mobility RAZR2 V8 Cellular Phone
Screen is blank
ya seems this is a problem of display connector u can fix it by fitting the display connector by opening the cell if it doesn't work then also then replace ur display
Mar 10, 2010 | Nokia N96 Cell Phone
My phone has a blank screen but still works how do i fix it ?
There might be a Hardware issue with the display you need to walk into the service center to get it repaired.
Thank you fro using Fixya.
Nov 16, 2009 | Sony Ericsson w580i Cellular Phone
Zenith P42W34P Plasma Display Panel
Hello, My name is Dave and I can help you fix your Plasma TV. Do you have Black vertical 1.5 inch line or lines on your screen that come and go? Then give me a call. Please feel free to give me a call @ 1-503-432-9904 or message me at pleasefixitdave@yahoo.com
Thank you!
Dave,
Nov 20, 2008 | Akai PDP-4247 Television
AT&T GoPhone Z222 Logo
22 people viewed this question
Top AT&T GoPhone Cell Phones Experts
Lawrence Oravetz
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you an AT&T GoPhone Cell Phone Expert? Answer questions, earn points and help others
