Question about Alpine CDA-9830 CD Player
How to cancel demo mode
Unit goes into demo mode repeatedly
It is stuck in demo mode how do I fix the problem
SELECTED PRODUCT: (change your search)
How to disable the demonstration (DEMO) mode.
Article ID: 42707 ' Last Updated: 03/11/2014
Sony® stereo systems will enter the DEMO mode the first time you power on the system or if you do not operate the unit shortly after turning on the power to the system.
To disable the DEMO mode, while the stereo system is powered off, press the DISPLAY button repeatedly until the demonstration display disappears.
NOTES:
  • Depending on your model, some units have a DEMO button that is used to disable the demonstration mode. If your unit has this button, with the power to the system off, press the DEMO button until the display disappears.
  • If applicable to your unit, setting the clock on your stereo system will also disable the DEMO mode.
  • Using the buttons on a supplied remote control will not disable the demonstration mode.
If model-specific information is needed to complete any of these steps, refer to the operating instructions supplied with the product. Manuals, Specifications and Warranty information for your Sony product is available online.
May 27, 2015 | Sony Audio Players & Recorders
Tip
How to Turn Off Demo Mode
<span style="font-weight: bold;">Blaupunkt:</span><br /><br /> <ol> <li>Press the (PWR) to turn the unit off.</li> <li>Press the (DIS) and (1) simultaneously for more than 3 seconds to activate the demonstration mode.</li> <li>Press both buttons again from more than 2 seconds to cancel this mode.</li></ol>or<br /> <ol> <li>Try pressing and holding menu for 10 seconds to turn it off.</li></ol><span style="font-weight: bold;">Bose:</span><br /> <ol> <li>Unplug the unit and wait ten seconds.</li> <li>Plug it back it and press repeatedly on the eject button.</li> <li>The demo disc will eject.</li></ol><span style="font-weight: bold;">Clarion:</span><br /> <ol> <li>Press and hold the "D" button to enter the settings menu.</li> <li>Use the next track button until SCRN SVR is displayed, use the rotary knob to select "OFF".</li> <li>Press the "D" button to exit the settings menu. </li></ol><span style="font-weight: bold;">Garmin:</span><br /> <ol> <li>DO NOT DO THIS TO A FUNCTIONING UNIT. Hold down your MENU key, Go to your SYSTEM tab, SYSTEM INFORMATION.</li> <li>When the software version window come up, hit ENTER.</li> <li>Press RANGE UP 3 time, Range DOWN 3 times, RANGE up 1 time, RANGE down 1 time.</li> <li>The system should reset, when asked to use RETAIL mode say NO.</li></ol><span style="font-weight: bold;">JVC:</span><br /> <ol> <li>Hold down the SEL button for 2-3 seconds.</li> <li>Use the &lt;&lt; or &gt;&gt; buttons to find DEMO.</li> <li>Turn the VOLUME knob until it says OFF or DEMO OFF.</li> <li>Press SEL again.</li></ol><span style="font-weight: bold;">Kenwood:</span><br /> <ol> <li>Go into standby mode, hit menu and then press "hold". A menu should pop up.</li> <li>Use knob to select demo.</li> <li>Press in on the knob and hold until it says "demo OFF".</li></ol>or<br /> <ol> <li>Switch to Standby.</li> <li>While holding down 5, press Reset with a paperclip or similar and continue to hold down 5.</li> <li>Demo mode should now be off.</li></ol><span style="font-weight: bold;">Magnavox:</span><br /> <ol> <li>Press and hold the menu button for 5-10 seconds until the normal menu pops up and then go to the section that says demo and turn the demo mode off.<span style="font-weight: bold;"></span></li></ol><span style="font-weight: bold;">Pioneer:</span> <ol> <li>Turn the vehicle's key to the Accessory or ACC position.</li> <li>Press the "Source" button, located on the left-side of the radio, and press the "Off" button that appears on the screen to turn off the unit.</li> <li>Locate the "Volume/Mute" button, located on the left-side of the unit.</li> <li>Press and hold the "Volume/Mute" button until the demo mode turns off.</li></ol>or<br /> <ol> <li>Turn the radio off.</li> <li>Push "Memory 5" or "Memory 6" (depending on your model) for just a second.</li> <li>When you hear a beep, demo mode is off.</li></ol><span style="font-weight: bold;">Pioneer Premier:</span><br /> <ol> <li>With the unit Off and the car ignition On and Running, press button number 5 and release that button to turn off Demo mode.</li></ol><span style="font-weight: bold;">Sharp:</span><br /> <ol> <li>When the unit is in the power stand-by mode (demonstration mode), press the X-BASS/DEMO button.</li> <li>The demonstration mode will be cancelled and the display will disappear.</li></ol><span style="font-weight: bold;">Sony:</span><br /> <ol> <li>Press display twice to turn off Demo mode.</li></ol>or<br /> <ol> <li>Press and hold the select button.</li> <li>Press the select button repeatedly until the desired item appears.</li> <li>Rotate the control dial to select the setting DEMO.</li> <li>Rotate the control dial to select the setting DEMO-OFF.</li> <li>Press and hold the select button.</li></ol><br />or<br /> <ol> <li>Press the STOP and the EJECT buttons simultaneously for 5 seconds.</li> <li>UNLOCKED should now appear in the display and you should be able to eject the disc.</li></ol>If Demo mode comes back on every time you turn off the ignition and back on, you have a wiring problem with your Constant +12 Volt Memory wire.
on Jun 22, 2011 | Audio Players & Recorders
I have kenwood XD-A75 stereo,and i have not been able to remove the demo mode after i try to cancle it it just comes back after i turn the power on, i read the manual but nothing. is there another step i...
When the AC cord is first plugged into the unit, the unit will go into demo mode. To cancel demonstration mode press the Ex.Bass/Demo button. This button is on the front of the receiver, left side towards the top. The demo mode will be cancelled and the receiver will be in low power consumption mode. It may appear that the unit is off because the display will disappear but the radio is in fact on. When the radio is on you can also adjust the bass with the Ex.Bass/Demo button as well.
Mar 24, 2011 | Kenwood XD-A75 CD Shelf System
The letters DENO is chown on the display
Hello & Welcome to FixYa
The washer is in DEMO Mode and to deactivate it there are three ways depending on the age of unit:
1. Press Start/Cancel button untill all console LEDs illuminate....Then press both Start/Cancel and On/Off buttons together until d OFF appears on display.
2. Press the CANCEL button to cancel the DEMO mode.
3. Press the On/Off and Start/Cancel button together with the top left button option until the d Off appears
Please get back to me if you have any other questions.
Kevin
Jan 26, 2011 | Indesit WA 125 Front Load Washer
How do I cancel demo mode on a Kenwood kdc-w3044 car front loader unit?
press menu till it shows demo, turn dial it should flip "demo o" demo off"
Dec 03, 2009 | Car Audio & Video
Electrolux dryer stuck in demo mode
To deactivate the demo mode:
Turn cycle knob to last cycle on right. Press start to save cycle position.
Press cancel to turn machine off.
Within 10 seconds, wake unit by pressing start once, immediately press and hold cancel and right most key under the display together for a minimum 6 seconds.
“DEMO MODE” will no longer be shown in the display.
May 24, 2009 | Electrolux EWED65H Dryer
CANCELLING the demo mode
Once the demo has started, press the STOP button on the front panel for 3 seconds. Demo will stop and the unit will enter standby.
You can download the user manual here:
https://www.p4c.philips.com/files/f/fw-r7_22/fw-r7_22_dfu_eng.pdf
May 07, 2009 | Philips FW-R7 CD Shelf System
How to diable demo mode on mx-kb30
Turn the stereo on, wait two minutes for the demo to start running then press the "demo/cancel" button located under the "sound mode" selector.
Mar 10, 2009 | JVC MX-KB30 CD Shelf System
Inverting color display
To cancel demo mode: While unit is OFF and ignition is ACC or ON, press "display" to cancel.
To cancel reverse demo: While unit is OFF and ignition is ACC or ON, press "band" to cancel.
You can also use the MULTI-CONTROL to turn demo mode OFF.
May 15, 2008 | Pioneer DEH-P5900IB CD Player
Sony demo
Had the same problem. The display of the home cinema system kept showing "sony demo". I went to the system menu and reset all settings to factory!
Nov 20, 2007 | Sony CMT-M100MD\W CD Shelf System
Alpine CDA-9830 CD Player Logo
20 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
