Question about Metra 98 Dodge Intrepid Radio Install Kit
Engine will not start
Sometimes engine will not start. engine cranks fine. removing power to car can make the issue go away. no engine codes show up. problem happens with engine hot and cold.
    Sergeant:
  • 182 Answers
Fuel pump, check if you can hear the fuel pump spinning up when the problem happens. Turn the key to the on position and listen to hear it making a high pitched spinning sound for 2 seconds then stops once fuel is pressurized in line. Also check fuel filter, air filter and vacuum lines if needed. Also check throttle body butterfly vavlve to see if it's sticking open or closed.
Posted on Nov 16, 2014
2000 grand caravan 3.8l changed torque
What prompted you to change the CPS? Was the issue existing before and you tried to solve it with a new CPS? I had a Jeep Grand Cherokee that kept giving me a bad CPS code. I replaced it and the problem didn't go away. Ended up being the computer.
Jan 27, 2014 | 2000 Dodge Grand Caravan
96 Jaguar XJ6 starts fine, idles at 800 in neutral 700 in gear, at times it gets a bit rough and stalls sometimes, restarts right away with no issues. Will not rev over 2700 rpm in neutral it just bogs. In...
the crank sensor is favorite they are unreliable that explaines why the trans not getting engine speed signal unless its a manual box and that code will allways be logged advise start by checking for water ingress in engine control module located lower rh a post then change crankshaft position sensor or better still try and borrow one from a good running car
Mar 02, 2017 | 1995 Jaguar XJ6
My 2002 pontiac grand am has been running good, but has trouble starting right away, for a long time when turning the key over it will crank but wont start on the first try it takes a couple attemps then...
First of all, common sense tells you, that you didn't need 6 sensors
Codes do not tell you to replace anything
Study OBD2 Systems
I have a problem when someone say for a long time
I assume that means up to six months
If your not a car person capable of diagnosing &
make at least some repairs,then you need a repair
shop ,after a couple of weeks,at least for some issues
Either study cars & obd2 or pay a shop while your learning
Jul 12, 2011 | 2002 Pontiac Grand Am
I have a 2000 eclipse and the night before it ran fine. The next morning I went to start it and it cranks but that's about it. I checked for spark and after I cleaned the oil off there was spark, but...
Providing a accurate diagnosis is difficult. All previous advice could be correct.
I'd look into the fuel delivery issue first. The MPI (fuel pump) relay is controlled by the engine computer (ECU). If this is OK, your Check Engine Light should be off. A test with an OBD-2 code reader will tell if the ECU really is OK, and show any error codes.
If the ECU is OK, and the fuel pump is getting power, open the gas tank cap and see if this helps the car to start. (might be worn pump issues).
If you are actually getting fuel and spark, a no-start condition will generally throw an ECU error code, see above. There may be a crank or cam sensor that has failed.
The next thing to check is that the timing belt has not slipped a few teeth. This does happen. Your engine is probably a 4G64, and you MAY get away with it without bending valves. Or maybe not.
Jun 23, 2011 | Mitsubishi Eclipse Cars & Trucks
01 Suburban engine, 8.1 liter, abruptly turns off
Its the crank sensor. There was a recall a few years back for 2001 8.1 liter engines crank sensor. Engine would shut off perodically and sometimes would not restart untill cool. Plus it just happened to mine. about a 350 dollar dealer fix.
Feb 22, 2009 | 2003 Chevrolet Suburban 1500
Crank no start
SOUNDS LIKE THE CRANK SENSOR POSS. AS I HAVE ONE HERE THAT I JUST DIAGNOSED FOR THE SAME THING WITH A SCAN TOOL WHEN WE FINALLY GOT IT NOT TO START. I'LL FOLLOW UP AFTER SENSOR INSTALL
Aug 11, 2008 | 1995 Lincoln Town Car
Car losing power and turning off
if your car is 2003+ try turning the key to run (but not crank) then to acc. 3 times and the engine codes will show up on the odometer, then you can look up what those codes are to help diagnose some of the problems.
Jul 21, 2008 | 2005 Dodge Neon
Metra 98 Dodge Intrepid Radio Install Kit Logo
61 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Jason
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
