Question about Homelite Ut80993 Honda Gas Pressure Washer
No pressure buildup on a new pressure washer..old one works fine
This is my second one from home depot brand new i have good house pressure,and engine runs fine
2 Suggested Answers
vincob
  • 718 Answers
SOURCE: I have a gas powered
Clean your carb and give it fresh fuel. Thats if you are getting spark. Can you give me a note so I can give it to my teacher so I can get back into school.
Posted on Aug 21, 2010
Motor fires up fine runs slightly rough for about 10 seconds then smooths out for about 5 seconds and cuts off. Will start right back up after about 5 seconds and does the same thing. I have drained the...
Previous owner had way overfilled crankcase oil. Oil had gotten into carb and clogged air filter. Drained oil to correct level. Ran engine but kept cutting off-see above. Took off carb cover cleaned housing and ran without air filter-ran fine. Unsuccessfully tried to clean air filter with gas-did not work. Apparently, the engine could run just long enough to exhaust the air in the old filter and cut off which is why it would start back up after a few seconds. Bought new air filter-whole thing-about $15 at Carquest. Put in some carb cleaner and installed the new filter and it runs perfectly.
Jun 10, 2014 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
My pressure washer just stopped while working, why?
Check your oil level. This machine has a "low oil shutoff" safety mechanism. If the oil is low it shuts down.
Jun 08, 2014 | Ridgid Pressure Washer. 3,300 psi 3 GPM...
Husky 2600 pressure washer with honda gcv160 engine. engine won't run with choke off.
I bought mine at Home Depot, the pump failed after about 8 hours of use then Home Depot agreed to replace it now it failed again after aabout 10 hours of use. This is a piece of crap and Home Depot should be ashamed for selling this junk. I am sure they are in with Husky and making big dollars on a crappy product. My machine is like brand new just will not work. Now the carb has to be replaced only after less than 20 hours.
JUNK Home Depot
Nov 23, 2011 | Garden
I bought an Admiral washer Model No. ATW4475VQ. I bought it from Home Depot. The first washer was delivered, and when I did a load of laundry, water leaked from the bottom of the washer. I did not see any...
It's impossible to tell. from your description.
Usually a new washer is set up with new hoses. If the installers aren't complete idiots that should be good.
You can look at where the water lines come out of your wall and make sure it isn't wet there.
You could also test the water pressure at your house and make sure it isn't extremely high. Sometimes these new units can't take overly high water pressure.
Good Luck!
Mar 27, 2017 | Whirlpool ATW4475VQ Washer
My RMW 2.2G24 will not pump water
The cheapest pump I have found (for your model) is RMW2G24 2 2 GPM 2400 PSI Max pump on amazon. Hope this was helpful... cheers
Oct 28, 2010 | Annovi Reverberi RMW2.5G25D
Brand new machine and it ran fine for the first 5 minutes then when I squeeze the trigger now the pump takes a second to click on then when it does the engine stalls
Sound like you need to replace the unloader valve,or take it apart and free it up,lube the seats and o rings and retry the washer to see if it works.The valve has the pressure regulator in it so the knob that you adjust the pressure with needs to come off and then just unscrew the unloader valve.
May 09, 2010 | McCulloch FHH25A Gas Pressure Washer
I am trying to hook my washer up to a laundry room valve, but it keeps leaking and giving a "NF" code... Is the valve faulty or does my washer need a new hose to hook up to a brand new home's valve?
try changing the washers in the hoses / don't use red outside hose washers/ but hi pressure for fill hoses . home depot should have them . and ck the valve screens at the washer side . clean screens good washers . ( water flow's and washer should work .. mm
Dec 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Need a new hose where can i get 1
lowes or home depot carry some good ones
Sep 12, 2009 | Garden
I HAVE A BRAND NEW TROY-BUILT 2600PSI pressure washer. I have used it twice for about 1/2 hour each time. It worked perfectly. I tried to use it today with everything hooked up perfectly. The Honda engine...
Sounds like the governor is stuck. My pressure washer speeds up when it has to pump. Don't know if yours uses vacuum to trigger governor or direct linkage. Good Luck.
Jul 04, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Pressure washer - can't figure out soap
Dont use your mouth youll get poisoned, soap will only come out when there is high water flow, ex. with soaper tip (the one with the bigger hole) or no tip. When you have high pressure tip on it will not work.
Apr 09, 2009 | House Brand Garden
Homelite Ut80993 Honda Gas Pressure Washer Logo
82 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
