Question about Fujitsu STYLISTIC M532 Tablet
M532 turns on ok but it won't react to my touch
My M532 was working ok till yesterday i powered it off. Can't get it to power on screen lights up but won't let me start the screen by touching the screen it shuts down its fully charged
No sound from my Fujitsu M532?
Hi Dave,
I would suspect that a lateral force has been applied to the headphone jack of your tablet. This occurs when you accidentally pull the headphone plug out at an angle instead of straight in line with the jack.
You might be able to find a repair shop to fix this. It might cost as much as the tablet. If under warranty you could try to get it replaced but Fujitsu is terrible in this department.
It is ALWAYS wise to get an extended warranty for consumer electronics. People tend to not do thi9s because they shop primarily by price and the extra warranty drives the cost up to high at the time of purchase. Then comes this kind of problem and you wonder why you didn't spend the extra 20 bucks.
Mar 01, 2015 | Fujitsu STYLISTIC M532 Tablet
I have downloaded the Manual onto my new Fujitsu M532 tablet but cant read it because it cant open the file;. Any idea what is wrong?
It is probably a PDF (Portable Document Format) file. If you want to read it, download and install the free PDF reader from Adobe.com.
Dec 01, 2014 | Fujitsu STYLISTIC M532 Tablet
I have a Samsung tablet 3 that the touch screen is frozen. I see where ppl are saying to turn off power, hold vol. down & power to get in reboot mode. I can't get mine to power off (touch screen froze) &...
Seems like the digitizer isn't working anymore u may wanna get ur tablet examined but to quickly turn off some tablets is to press and hold the power key till it shuts off and not lock the screen
Oct 21, 2014 | Tablets & eReaders
When your tablet has been dropped in the tub and your touch screen is not working
Any liquid immersion warrants a new battery. Those batteries do not like water at all. Actually, they can react quite violently with it. Clean your device and replace the battery, after that re-evaluate.
Aug 05, 2014 | ASUS Tablets & eReaders
My fujitsu m532 can't play movies from sd card
My suggestion would be to look at the format of the movie files you're trying to play and search for a movie player app that matches that. If one exists then download, install and open file from SD card with that app. If for example file type is "*. flv" then search for "flv player for android".
My guess is you don't have an app on the tablet that is compatible with the movie file type. Hope this helps.
May 23, 2014 | Fujitsu STYLISTIC M532 Tablet
Hi, i have a kobo arc, and recently it has stopped working. The light stays on, and every time i go on it, it freezes and i cant do a thing with it. not even turn the screen off, or do the volume or turn...
Hold the power and volume button at the same time till u get a box and a tool thing on your screen the by using the volume down go to wipe data press power button to ok then go down to yes with volume down key and press the power button to ok yes then will reset your tablet like when first got it
Mar 05, 2018 | Kobo Arc
Fujitsu siemens stylistic M532 tablet not charging battery
I have just had same problem. Battery on M532 absolutely refused to charge from flat.Tablet worked when plugged in so I downloaded an app killer from android market and killed all but the essential apps then tried again and it seemed top work! Maybe background apps draining battery at faster rate than could be charged?
Nov 08, 2012 | Tablets & eReaders
My screen is frozen and it wont turn off
Low specs tablet sometimes will get this problem.Or just let it alone for a while, it maybe ok later. If not, it's better to contact the supplier for help.
Android 4.0 Tablet PC
Feb 04, 2012 | PANDIGITAL Planet
My SGT is brand new, only a week old and it has aldready crashed. I can't access it at all, the screen lock won't react and it's been hung up like that for over an hour now. I was listening to...
First put the charger plug in the Tab, I just tried mine that was sitting on the desk, even though I held the power on button for a long time it would not start. I pluged the charger in so the red charging light is on Tried to start and it worked perfectly. i.e. the voltage level is very critical, if it is a fraction low it won't start.
Jun 09, 2011 | Samsung Galaxy Tab Tablet PC
Fujitsu STYLISTIC M532 Tablet Logo
Top Fujitsu Tablets & eReaders Experts
k24674
Tony
Mohammad Abumuailek
Mohammad Abumuailek
Are you a Fujitsu Tablet and eReader Expert? Answer questions, earn points and help others
