Question about Caterpillar Peterbilt Model 389 Tractor/trailer With Cat D8r Dozer
Where is the abs fuse located in 2011 389 peterbilt
Can't find abs light is not working
What would cause the Emergency Brake light to not go off when the emergency light is released? What causes the ABS warning light to come on?
When I had that problem with the emergency light it was the sensor for emergency brake
The abs and brakes sounds like you are loosing pressure in the system
Apr 18, 2015 | 2004 Toyota Prius
Abs light on in 2000 Alero 3.4
check fuses..If the fuse blows the light comes on and the ABS system is not working..Or possible the abs motor is shot. In any rate it is a good idea to look into it as soon as possible. You ABS system is not working. You still have brakes but the anti lock system that prevents skids will not work
Feb 12, 2015 | 2000 Oldsmobile Alero
91 Buick park avenue abs light. This happened after my friend was driving down the freeway and his tire blew. Now it just blew the rubber off and he was able to drive t off the freeway on the belts. And...
ABS LIGHT AND MODULE TROUBLESHOOTING:
Anti lock brake system light comes up when there is issue with car brake systems. It can be low brake fluid or faulty ABS fuse or its issue with brake system or assembly. Your vehicles brake system needs inspection.
To troubleshoot these issues, I suggest you to refer the help links provided below. There are direct links with accurate solution, for these specific issues.
Click the link below and follow the procedure: ------
All types of ABS LIGHT / brake problems and repairs
http://howtobyme.blogspot.com/2011/11/abs-and-service-light-comes-on.html
ABS light stays on but brakes work fine?
http://howtobyme.blogspot.com/2011/11/abs-light-stays-on-but-brakes-work-fine.html
VCS and ABS lights go on and off intermittently on Lexus?
http://howtobyme.blogspot.com/2011/11/vcs-and-abs-lights-go-on-and-off.html
The ABS and Traction Control Lights stays ON dash of car?
http://schematicsdiagram.blogspot.com/2011/06/abs-and-traction-control-lights-stays.html
ABS & Brake lights warning indicator steady on dash and speedometer not working for Dodge Ram?
http://howtobyme.blogspot.com/2011/11/abs-brake-lights-warning-indicator.html
Battery Light and ABS Light on Dash
http://whoisbyme.blogspot.in/2012/07/battery-light-and-abs-light-on-dash.html
Sometimes ABS light comes on while Driving?
http://howtobyme.blogspot.com/2011/12/sometimes-abs-light-comes-on-while.html
How Anti-Lock Brakes Work?
http://technoanswers.blogspot.com/2011/11/how-anti-lock-brakes-work.html
Brake System Troubleshooting?
http://technoanswers.blogspot.com/2011/11/brake-system-troubleshooting.html
Anti-lock brake light stays on all the time?
http://technoanswers.blogspot.com/2012/01/anti-lock-brake-light-stays-on-all-time.html
ABS light comes on and Car makes Grinding noise?
http://repairhelpcenter.blogspot.com/2012/01/abs-light-comes-on-and-car-makes.html
ABS trouble codes for all models?
http://repairhelpcenter.blogspot.com/2011/11/abs-trouble-codes-for-all-1994-00-acura.html
2008 Toyota Highlander: ABS warning light Blinking and OBD Error codes Coming?
http://technoanswers.blogspot.in/2012/05/2008-toyota-highlander-abs-warning.html
2003 Lexus ES: VSC, TRAC OFF, ABS lights ON?
http://technoanswers.blogspot.in/2012/04/2003-lexus-es-vsc-trac-off-abs-lights.html
2008 Toyota Highlander Hybrid: Warning Lights Abs, Vsc & Brake Are On?
http://technoanswers.blogspot.in/2012/04/2008-toyota-highlander-hybrid-warning.html
ABS & Brake warning lights remains steady on dash?
http://schematicsdiagram.blogspot.com/2011/12/abs-brake-warning-lights-remains-steady.html
Can I drive the car without ABS fuse connected?
http://schematicsdiagram.blogspot.in/2012/02/can-i-drive-car-without-abs-fuse.html
Where is ABS/TCS module located on 2005 Cadillac Deville
http://schematicsdiagram.blogspot.com/2011/12/where-is-abstcs-module-located-on-2005.html
ABS motor keeps running?
http://schematicsdiagram.blogspot.com/2012/01/abs-motor-keeps-running.html
When the car stops, abs pump turns ON?
http://howtobyme.blogspot.com/2011/12/when-car-stopsabs-pump-turns-on.html
Replacing ABS unit on Buick Century?
http://technoanswers.blogspot.in/2012/02/replacing-abs-unit-on-buick-century.html
2008 Toyota Tacoma: ABS causes Brake pedal fade?
http://technoanswers.blogspot.in/2012/04/2008-toyota-tacoma-abs-causes-brake.html
Toyota Camry: Premature ABS Actuation?
http://technoanswers.blogspot.in/2012/04/toyota-camry-premature-abs-actuation.html
How to replace ABS Modulator Control Unit on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-replace-abs-modulator-control.html
How to replace ABS Pump Assembly on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-replace-abs-pump-assembly-on.html
How to remove ABS Accumulator on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-abs-accumulator-on-acura.html
How to remove ABS Control Unit on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-abs-control-unit-on-acura.html
These details will help.
Thanks.
Feb 04, 2013 | Cars & Trucks
The ABS light comes on, and sure enough on slipery road conditions, there's no ABS. BUT when it's icy, the ABS light on the dashboard goes out, and checking to see if I have ABS, sure enough I do. It's...
the abs warning light also works with the electronic traction control, (or traction control,same system,different names) and when icy, stops the wheels from spinning,above about 15 mph.(the abs dont work under 5mph) so if im right regarding your question,your car is doing what its supposed to,stopping the driving wheels from spinning/locking up.the warning light comes on when one or the other is doing its job.(working).the trick is to drive so that the warning light doesnt come on..... boring.
Jan 28, 2011 | 2000 Volkswagen Beetle
ABS is not working but the ABS light is not on.
Early ABS can lock up the tires, best bet is the pads need replaced and there is air in the system.
Apr 27, 2010 | 1990 Mercedes-Benz 190
Brake,abs and dsc lights game on
theres a problem with the abs, when the abs has a problem the brake and abs light come on, also dsc light does too, because it uses the abs to control the system so when abs doesnt work it shuts down the dsc and turns the light on, you will need to have the abs system scanned for codes these codes will give an idea of whats not working and it can be diagnosed why.
Apr 21, 2010 | 2005 BMW 3 Series
2001 pontiac sunfire abs and check engine light is on. brake fluid is full and the front brakes were just changed about a month ago.
I think these lights are not related. The ABS light means the ABS is not working, and has nothing to do with the brakes working. You can have brakes and not have the ABS part working. I don't think a bad ABS would turn on the check engine light, but it may.
Dec 23, 2009 | 2001 Pontiac Sunfire
Caterpillar Peterbilt Model 389 Tractor/trailer With Cat D8r Dozer Logo
112 people viewed this question
Top Caterpillar Toys Experts
fordexpert
Are you a Caterpillar Toy Expert? Answer questions, earn points and help others
