Question about Olympus Science & Laboratory
Replace burned out bulb
I need to replace a burned out bulb in my bathroom. The bulb is fc8t9/22w. I can't figure out how to remove/unplug the bulb in order to replace it.
garyq1970
  • 85 Answers
SOURCE: I can't figure out how to replace the front turn signal
There is one screw on top of headlight assembly that holds turn signal lens in place you have to remove that screw and pull lens straight out. As far as head lamps go its just a matter of getting your hand behind headlight assembly to remove the collar that holds the bulbs in place.
Posted on Nov 12, 2008
SOURCE: How do I remove headlight cover in Subaru 1998 brighton wagon?
Hi ' this sounds a bit daft but it works ' put the light unit in the oven on a low heat for about 45 mins ' this should be enough to soften the seal and allow the light to be opened ' you need to re-seal again after bulb replacement
Posted on Jan 02, 2009
blueextc3221
  • 15935 Answers
SOURCE: How do you replace the headlight bulb in 2003 Mitsu Outlander?
if you are removing the power clip, grab the recepticle it was plugged in to (look at your new bulb as a reference) and twist counterclockwise. The entire bulb assembly will come out, and replace with the new assembly.
Posted on Jan 06, 2009
  • 23 Answers
SOURCE: I need to replace a tail light
Hi,If you open the tailgate you will see two plastic plugs on the light unit prise these out and you will see the 2 torx screws these can be removed with the SAAB toolkit you can then slide the lamp unit out to replace the faulty bulb.
Posted on Feb 01, 2009
SOURCE: Tail Light in 2004 Beetle
If you need to replace your tail light bulb, first remove the cover (it's round) from the inside of your trunk. There will be a black knob that needs to be unscrewed totally to release the back light casing. The screw is spring loaded so it is not going to fall. Be sure to hold on to the black knob. If you drop it you can retrieve it, but it's best to not drop it. Next pry the light casing from the fender with a knife or some other sturdy object. It is best to pry the light out from the line that runs from the light to the hatchback door. Don't be afraid, it takes a little force to pull out. After you pull out casing, you'll find two light switches. The one with one filament is for the turn signals and the one with two filaments is for the break light. Turn the light switch counter clockwise and remove. Switch out light bulb with new one (AutoZone has them for about $5.00 - package of 2). Replace every thing back as you uninstalled it. It is recommended that you replace all bulbs, that way it you don't have to do it again later when they go out. It'll save you the time and hassle of doing this again. Hope this will help anyone so print and save in your manual for later use.
Posted on Feb 07, 2009
1997 Volvo 850 no abs light
The abs light bulb has burned out (just like a regular light bulb). These bulbs can be replaced easily, you just remove the upper portion of the dashboard by removing the retaining screws and then you will see the gauge cluster underneath. The gauge cluster will unclip and unplug and then you can replace the bulbs which are burned out. It is very common for older cars to have dash bulbs burn out.
Feb 01, 2017 | Volvo 850 Cars & Trucks
How do I replace the light bulb in a NEFF H7860B1GB/01 ?
Unplug power first. You need to remve the screwa that hold the bulb cover, access the bulb and replace it, I will wee if I can find a diagram.
Oct 06, 2008 | Neff Microwave Ovens
I can not figure out how to get into the rear light bulbs (Stop light, etc). The manual says to remove two (phillips) screws to disengage the housing from the body. There's even a a picture. However, on...
To access the rear lights, you access them from inside the trunk. Pull down the carpet at rear of trunk near latch. There should be the screws the manual is referring to. Once you locate and remove all screws, gently pull the light assembly away from body. Replace the needed bulbs then gently push assembly against the body, replace the screws and set carpet back in place.
Nov 14, 2010 | 1995 Toyota Camry
My timer is running and I have swapped the black and red pins to turn on and off the lights but the lights do not come on? Were do I find the model number?
My model number is on a sticker inside the door.
I have the 300 watt, and it matches the total wattage of my bulbs.
A lot of people ask for replacement Malibu tripper pins on Fixya, so your tripper pins might be worn down. I cannot find Malibu trippers, even on e-bay. And the new timer clocks are electronic.
Check your circuit breaker to see if unit is getting electricity, including GFCIs in bathroom.
Plug hair dryer in same plug as Malibu to see if there is power
Brush a wire across the screw terminals to see if there is any spark going to bulbs.
It's unlikely that all the bubs failed at once, but if power pack shows spark on the terminals, the bulbs should be getting electricity.
If a couple bulbs burned out, the power pack can burn out the others.
Unplug power pack until you get bulbs replaced.
Unfortunately if the power pack stops operating, it is broken.
I did find some tips to help folks preserve their power packs:
1) Match wattage of bulbs with wattage of power pack
-15 each X 20 watt bulbs = 300 watts, so install 300Watt power pack
2) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
3) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
4) When working on bulbs, unplug power pack or it may burn out.
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack
Nov 11, 2010 | Malibu Intermatic Inc. ML300RTW 300-Watt...
How to change light bulb in refrigerator
Unplug the Whirlpool refrigerator from the electrical outlet.
Step 2
Locate the bulb on the inside of the Whirlpool refrigerator.
Step 3
Remove the light cover. Usually these just snap off, but, on some models, they may need to be unscrewed. Use your screwdriver to unscrew the light cover retaining screws (if required).
Step 4
Unscrew the old light bulb.
Step 5
Screw in the new light bulb.
Step 6
Replace the light cover. Plug the Whirlpool refrigerator back in. Test your new light bulb.
Also note that the below can also work
Unplug refrigerator or disconnect power.
Slide the light bulb cover toward the back of the compartment to release it from the light assembly.
Replace burned-out bulb(s) with appliance light bulb(s) no greater than 40 watts.
Replace the light bulb cover by inserting the tabs on the cover into the liner holes on each side of light assembly. Slide the cover toward the front until it locks into place.
NOTE: Do not force the cover beyond its locking point; doing so may damage the light cover.
Plug in refrigerator or reconnect power.
To change the freezer light bulb:
NOTE: You may need to remove the upper freezer shelf or basket to access the light assembly.
The light bulb cover opens from the back. Firmly press forward on the notches in the back of the cover and pull down the cover.
Remove the cover and replace the burned-out bulb with an appliance bulb no greater than 40 watts.
Insert the front tabs of the cover into the liner and snap the back portion of the cover over the light assembly.
Good luck in applying the solution
Jul 29, 2010 | Whirlpool GX5FHTXVA Bottom Freezer French...
How to change inside bulb
Normal procedure is to remove case cover to access the bulb.
Usually several screws on the back and some partially hidden on the front to remove. Sometimes the screws require a Torx screwdriver.
Unplug unit and avoid touching any wires.
Replace bulb with exact type.
Jan 07, 2010 | Frigidaire FMV156DC Microwave Oven
Front side marker light bulb burned out. Can't figure out how to get to the bulb to replace it. I also have the ''top right'' brakelight bulb burned out & can't figure how to get to that bulb either....
you actually have to remove the light from the vehicle to change the bulb. if its the one in the bumper you will have to loosen that side of the bumper to get to the bulb.
Sep 27, 2009 | 1998 Lexus LS 400
THE HEADLIGHTS ARE A SEALED ASSEMBLY. YOU WILL NEED TO REMOVE THE COMPLETE HEADLAMP TO ACCESS THE BULBS.
Dec 18, 2008 | 1998 Subaru Legacy
Bulb replacement
Good Day, technonot;
To replace LAMP remove Front Panel outwards until the quick snap disengages. There is small cover on the left hand side, using a philips screw driver; remove. Two more screws secure lamp, use handle to remove. ALWAYS, unplug TV from A/C power source first. Good Luck, big IRISH.
Sep 05, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Science & Laboratory Logo
69 people viewed this question
Top Olympus Science & Laboratory Experts
TimHu
Level 1 Expert
Are you an Olympus Science and Laboratory Expert? Answer questions, earn points and help others
