Question about Vax U91-Ma-P Air Pet Multicyclonic Bagless Upright Vacuum Cleaner
Front wheels worn out
Front wheels seem warn out
Replacing broken wheel on kenmore vacuum power head #116 54614400
Although I'm not familiar with that model I'd start by turning the base upside down and check near the back. Most vacuums are secured there by screws or a lever. Sometime you also have to reach inside the machine in front, like a car hood.
Aug 13, 2014 | Kenmore Vacuums
How to repair the front left wheel and height adjustment assembly on a Kirby G10 vacuum cleaner
The wheels are held on by a screw behind the wheel guard, i suspect your height adjuster has come loose off the spline, this can be simply tapped back onto the axle
Jul 21, 2017 | Kirby G10 Sentria Vacuum Cleaner...
The vacuum does not pick up either dry or liquid. It seems like there is a loss of suction.
This is commonly caused by either a worn out squeegee on the nozzle, or a broken wheel assembly. To check the wheel assembly, turn the machine over and look for breakage where the assembly attaches at the rear. Another common problem is that the clear plastic cover over the filter has been misplaced. There should be a rectangular cover with a round hole in it covering the filter on the lower tank. Without this cover in place there is no suction to the pick-up tank.
Jul 26, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
I forgot to put a bag in my kenmore vacuum cleaner, now it will not suction and the wheel at the bottom will not turn. the motor seems to work fine.
If the motor is running, there's a good possibility the fan is broken or worn down. This will result in no airflow. Solution? Replace the fan assembly or vacuum. I recommend a vacuum that won't run without a bag and has sturdier and multiple fans in the motor assembly.
Nov 18, 2010 | Kenmore Vacuums
Roomba stutters on one wheel causing it to quit
Try setting the Roomba on the floor, powering it up, pressing down hard on the front, just above the front wheel, and hitting "clean" or "spot." My Roomba had the same problem, and this seems to do the trick for it. I think it has something to do with the Roomba thinking the front wheel is extended (which would indicate a cliff) even though it's really not.
If this doesn't work, you might try pressing down over whichever wheel doesn't turn when you turn the Roomba on.
Mar 22, 2010 | iRobot 4150 Roomba Vacuum
Quit sucking....seems to be the long narrow strip
yes its usually the squeege strip in the front that wears out. the two tabs on the front release the assy then there are two screws on the inside and one screw on the side of the squeegee in the center
Jan 03, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
Oreck upright hard to push
If hard to push, only a few things to check:
(1) Rear wheels will get hair or thread wrapped around axles, dust, etc. and be hard to turn. Make sure each wheel turns easily.
(2) Small wheels on newer models (since about 1997-98) toward front are worn, missing or have same problem as item 1.
(3) Brush roll not turning. The brush roll actually helps pull this unit along the floor, as it rotates in the "forward" direction. If the belt broke, and you do not realize it, it may suddenly seem harder to push.
Oct 11, 2009 | Oreck XL2000 Bagged Upright Vacuum
I have a Sebo x1. It will not pick up from the head.
Hi
If the wheel isn't moving when the upright handle is swung down normally then the hydrallic action will be broken. The wheel only adjusts to the carpet when the handle is swung down and the wheel goes to the highest position. HOWEVER if you have large pile / thick carpeting then the X1 will struggle to pick this up as it doesn't cope well with thick carpeting. Sebo's G1 series with a manual adjuster dial is better in that respect. Put back the wheel as normal and check that it is lowering once the handle is unlocked. If it doesn't show up with the lights on the front of the hood showing that the wheel is going down, then its either the carpet thickness or the hydrallic wheel mechanism is broken. Contact Sebo in your country and they can usually send out a line diagram or suggest a repair.
Jan 30, 2009 | Sebo Automatic X1 Bagged Upright Vacuum
Orech scratching hardwood floor ???
I would recommend using another cleaning method developed for use on hardwoods. It seems to me like even if you replace the wheels, eventually they will wear down again, causing more damage to your floors. Check home depot, ask them what the recommend. Hope I could help.
Jan 27, 2009 | Oreck XL2200 Bagged Upright Vacuum
Vax U91-Ma-P Air Pet Multicyclonic Bagless Upright Vacuum Cleaner Logo
15 people viewed this question
Top Vax Vacuums Experts
rugby prop
Are you a Vax Vacuum Expert? Answer questions, earn points and help others
