Question about NEC It3640d it3640d
HOW FIND MAC ADDRESS IN PRINTER NEC IT3640D - NEC It3640d it3640d
Entering service mode on an nec 2840
Ok, I realize this machine is already EOL, but if anyone else runs into this issue, I found the answer here.
  1. Press the "Utility" button
  2. Press the "Access" button
  3. Press * four times
  4. Press the "Maint" soft button on the touch screen
  5. Press the "Service Mode" soft button on the touch screen
Once you are in there, you can reset the admin password by pressing the "Administrator # Initialize" soft button, and that will reset the admin password back to the default 00000000. This is actually for an IT3640, but evidently, this works for a few other models of NEC copiers as well.
Dec 11, 2013 | NEC It 3640 2530 3530 2840d Copier...
Need driver for nec it3640d for windows 7
VIEW AND DOWNLOAD
http://support.necam.com/Legacy/Document_Solutions/IT3640D.cfm
Nov 11, 2013 | NEC IT3640D Printer
My new HP - Officejet 4500 G510n-z wireless printer will not connect to my verizon net work. Tells me that "The printer attempted to join the network but is not receiving any data. This may be...
I tried everything, even called HP and they tried to sell me a new printer. So about 6 hours into trying to fix it, I decided to just reset my router (unplugged it and let it reboot). It was fixed.
Feb 13, 2011 | Office Equipment & Supplies
I have an HP Lasejet 1320 printer and I am trying to reset static IP Address as we are moving from one network to another. I need to know how I can determine the mac address of the printer as I can...
To find the static IP and Mac Address of your printer, press and hold green button for 10 seconds until green and yellow light starts blinking together, it will take out 3 print outs, 1 is printer information, 2nd will be configuration page, 3rd will be the toner status page,
Also you can Check your printer manual. This is the easiest and fastest way to find the printer's MAC address
Alternatively Print out a configuration page.
If you require more assistance, feel free to reply to this post
Thanks for Asking FixYA!
Regards, BA
Feb 08, 2011 | HP LaserJet 1320 Printer
How do i add the mac address of my printer to the list of permitted devices
Disconnect the Ethernet cable between the router and the cable-modem (or DSL-modem).
Access the web-interface inside the router.
Allow "all" MAC-addresses to access the router.
Turn the printer off.
Turn the printer on, so that it gets a "fresh" IP-address from the router.
On the router's web-interface, get it to show a list of the "active" DHCP-connections.
It should show the IP-address and MAC-address for your printer.
Copy that MAC-address, and the MAC-address of your computer.
On the router's web-interface, access the table of "allowable" MAC-addresses.
Add the two MAC-addresses.
Enable the "selected MAC-addresses only" option.
Reconnect the Ethernet cable.
Nov 04, 2010 | Computers & Internet
How do I find out what the mac address is on a
Just tap the Go button 3 times and it will print out the settings pages, on page 3 you will find the network settings with ip and mac address.
Jun 15, 2010 | Brother HL 5250DN Laser Printer
Can't find the mac address on a brother laser printer 2170w
page 66 of the network users manual explains how to find the mac address on your printer, you have to print out a test page from the printer and it should give you the info, still get the manual so you can read up more on network settings:
http://www.brother-usa.com/manuals/default.aspx?PGID=1&R3ModelID=hl2170W
Download the manual and make sure you have adobe reader installed on the computer.
Feb 05, 2010 | Brother Office Equipment & Supplies
How to check the MAC address of Zebra 105SL Printer
go to the configuration on the printer. Scroll through until you reach the network settings. You can display or print the results, which will show the MAC address. Also, if you have a PC on the same network, and you know the IP of the printer, you can look at your ARP tables and find the MAC associated with the IP. ARP -a at the dos prompt
Jun 23, 2009 | Zebra 105SL Thermal Label Printer
Brother printer and Neygear router wireless connection bad.
Had the same issue. Change the router wireless security settings from TKIP to AES algorithms. This did the trick for me.
Feb 21, 2009 | Brother MultiFunction Center MFC-440CN...
NEC It3640d it3640d Logo
60 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
