Question about DC 33 Light MolyKote Grease - 3.6 Kg Can
Where can I purchase a small quantity of Molykote AI-6159, SK-623, or D-708 for power window regulator slides?
Does anyone offer these in a small tube?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 45 Answers
Try finding on e-bay. Why molykote use some petroleum jelly.
Posted on Mar 27, 2014
Does anyone have a picture diagram of the reardoor window tracks and hardware /2002 saturn L300
Your power window motor is shot , buy another one, it takes three or four bolts to remove it. The window slides on the track.
Apr 16, 2015 | 2002 Saturn L-Series
I want to buy gift wrap but in large quantities. Anyone know where I can get this?
I've come across a couple of websites that sell gift wrapping but also offer large quantities at cheaper prices.
Try the Mr Gift Wrap site:
http://www.mrgiftwrap.com/
or Superior Gift Wrap:
http://www.superiorgiftwrap.com/
Feb 25, 2013 | Event Planning & Celebration
Where do i get the small plastic piece that slides back and forth in the track at the bottom of the power window? It holds the stud at the end of the regulator arm in the track. Mine broke into four...
Go to this site and poke around, they have never sent me a bad or wrong Saturn part.
http://www.trademotion.com/splash/index.cfm?siteid=214643
Sep 25, 2010 | 2001 Saturn SL
Power windows falling down-1996 nissan 200sx se
The problem is with the window regulator, which the motor attaches to. The regulator has come off the window.
Feb 15, 2010 | 1996 Nissan 200SX
2001 Toyota corolla LE: Driver side power window problems
The motor is burned out, likely due to heavily worn brushes inside. As the motor cools (from lack of use) it becomes usable again, but quickly heats up and seizes with use.
You will need to replace the window motor. If you are mechanically inclined it is not a difficult job.
The door panel needs to be removed (numerous philips screws and push fasteners), then there are two 10mm bolts holding the glass to the regulator. Support the glass in the upward position with tape or suction cup supporting devices.
Disconnect the power to the motor and unbolt the regulator from the door (about 5 10mm bolts), then slide the regulator and motor assembly out the door opening.
If you purchased a complete regulator/motor (typical aftermarket), simply install the new one in reverse order.
If you purchased just the motor (typical OEM), you will need to unbolt the motor from the regulator. Becautious as the regulator is spring loaded and will snap open once the motor separates. Install the new motor with the regulator in the same position as before disassembly, and reinstall into the vehicle.
Sep 10, 2009 | Toyota Corolla Cars & Trucks
Driver side window regulator
I would suggest replacing the whole regulator. They do offer the plastic slide pieces seperatly but usually the regulators bend and cause premature breakage of new component. If you can just replace the slides-remove the regulator and drill out existing piece if it is broken off in regulator. Next take a ball peen hammer and peen new metal into a mushrrom to secure it to existing regulator. I would remove the slider from the glass and push window all the way up and secure with a suction cup to keep it from falling down. Then take off the 2 screws securing the motor harness(disconnect the battery because one wire is hot and pay attention to the placement of the wires when they are resecured-it will just work in the opposite fashion if the polarities are reversed). Then take out the nuts and bolts securing the regulator to the door frame. If you figured out how to take off a 126 door panal you should be able to figure out the regulator position in the shell. Once the regulator is out remove the motor and secure it to the new regulator. Inspect the teeth on the motor and lube with grease (white lithium grease is what I use-wheel bearing grease is fine but it can be messy). Then "fish" new regulator into the door and secure nuts(use red locktight so they do not loosen up in the future).Then slide window down and slide in new plastic slides into window glass frame-you will want to leave the regulator loose and may have to start one of the slides before you secure regulator to door. Lube up the run channels and slides with grease. Snug regulator and operate window with regulator partially loose to let window find the best position with the lease stress and then secure regulator. It isn't as bad as it looks and with a new regulator it will be more self explanitory. Worse case senario remove the other rear panal and copy that regulator position. Good luck I hope I have been helpful.
Aug 08, 2009 | 1990 Mercedes-Benz 300 Diesel
Window problems electric powered off track
Unless the motors were replaced at one time, the only bolts holding the window to the regulator are at the slides. any hardware that fell apart should be inside the bottom of the door. Panel removal is pretty simple..only hidden fastener is on the edge...small reflector has one under there.
Haynes makes a good reference for that car for about $20.
May 22, 2009 | 1996 Pontiac Grand Am
Grand Am Power Window Replacement
Are you able to loosen any other bolts that could cause the window to come down more? You could also try manually turning the gears to lower the window...
Apr 10, 2009 | 2001 Pontiac Grand Am SE
Can't get window motor out
if it is the same as my 1996 ford you have to unhook the cables from the slide(the metal bar the window slides up and down on) and they are located at the very top and bottom of the slide(of course on the back of the slide) so it's not very easy. it's best to take the motor and regulator out as one piece unless you have very small hands.
Apr 08, 2009 | 2003 Ford Windstar
With WLI-U2-KG54-AI my computer freezes
I had same problem with my Buffalo, my computer freeze after some time I was not working with it,most certainly when I watched movies. You might have a problem with USB power saving, I solved it and it works fine for me now. Go to deviece manager, find USB root hub device, list its properties and at power managment tab, uncheck Allow the computer to turn off this device to save power.Please let me know if it works for you too lakk@azet.sk
May 17, 2008 | Buffalo Technology AirStation...
DC 33 Light MolyKote Grease - 3.6 Kg Can Logo
62 people viewed this question
Top Dow Corning Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Dow Corning Vehicle Part and Accessory Expert? Answer questions, earn points and help others
