Question about InFocus IN2104EP Projector
InFocus IN2104EP will not power on
Won't power on
Infocus screenplay 5700 I've had this product for
Hi!
Just had the same problem and I want to sincerely thanks rey francis basa !
I went down and changed C16 as you said. Exactly where you said.
Works perfectly now!
Jan 05, 2013 | Office Equipment & Supplies
White dots on screen
White dots are usually caused by a bad DLD/DMD chip. These do have a warranty normally. If it is out of warranty you can obtain a chip for between 200 and 500 depending on who you buy it from. I would call tech support and find out the chip number if you can. If not take it apart and read the number from chip. global projectors is one supplier. Infocus may have them as well. youtube has lots of repair videos. Here's mine on a mitsubishi. http://www.youtube.com/watch?v=V_uUH-xHKkU
Dec 20, 2012 | InFocus IN2104EP DLP Projector
Can not find source keeps on searching
check your audio video cable ( make sure the cable work well try it on other device )
Sep 15, 2011 | InFocus IN2104EP Projector
The screen keeps flashing
Make sure you have a reliable video source plugged in beforeyou plug it in. It may be searching for a signal. Also try a different outlet as it may be a ground problem.
Apr 14, 2011 | InFocus IN2104EP Projector
How do I open the lamp cover on the InFocus IN2102EP (to replace the lamp)? Cheers
There is a single screw that you need to remove, which will allow the panel covering the lamp to be removed.
The screw is located on the back grille, opposite corner from the power connector. For a full diagram and instructions download the following PDF:
https://portal.infocus.com/support/Product%20Downloads/InFocus_IN2102%20IN2104%20IN2106_LampReplacement_en.pdf
Mar 04, 2011 | InFocus Replacement Lamp for IN2102 IN2104...
Why does my projector keep shutting off
The LEDs usually indicate a likely fault, for which you need to consult the manual after noting the sequence, timings and colours.
In many cases this problem is caused by overheating or a faulty lamp. It's worth checking the LEDs before purchasing a lamp as it will probably cost at least £100 which is wasted if the fault lies elsewhere.
If overheating is the problem then you could clean the filters and see if this helps.
Feb 20, 2011 | InFocus IN2104EP Projector
Projector is going off to service light
if you have time before the projector shuts down, go through the menu and see if you can find and reset the lamp timer. Otherwise I've taken the bulb out and put it back in, and sometimes that resets something so you are able to use it again.
Jan 16, 2010 | InFocus In2106 Projector
Projected image appears to shake on the screen. How do you fix that?
replace the colorwheel. if the motor starts to go, the image will jump. try av solutions in ny. they're pretty good.
Jul 09, 2009 | InFocus IN2104EP Projector
HP VP6210 won´t turn on at all
try to replace all the capacitors on the motherboard. This are the only parts that leak in time. Try otherwise to reset to counter or update the firmware on your machine on the infocus site.
Goodluck !
Sep 04, 2008 | InFocus LP120 / 1000 Lumens / XGA / DLP...
InFocus IN2104EP Projector Logo
42 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
