Question about Sankyo Sound 700 Super 8/ Single 8 Film Projector
Sankyo sound - 700 stopped
Sankyo sound - 700 quit running
My LT 1024 Hydrostatic drive cub cadet mower quiet moving and appeared to have leaked oil out on the grass before stopping.
Please be more specific. Did it leak engine oil out on the grass before it quit running? Or did it leak transaxle oil out before it quit moving? Were there any strange noises before the failure? and if so, where did it sound like it was coming from?
Either way its about the same cost. Engine or transaxle. Both can be rebuilt but it is not cost effective to do so. Loss of oil in large quantities during operation in either indicates major internal damage. Cost of a replacement transaxle is about $800. Cost of a replacement power unit depends on make and whether or not you get a short block or a complete motor. A Kohler short block is about $ 700.
But maybe Im jumping ahead of myself. Please describe in greater detail what happened. Try to determine exactly where the fluid came from ( i.e. is a seal leaking or is there a hole in the casting)
Nov 20, 2012 | Cub Cadet Garden
Looking for information on a 1989 760 Volvo ignition modular, also the wiring diagram? My Volvo starts when it wants to and quits the same way. Have checked distributor, fuel system, etc but to no avail....
hi-
my 1989 760 turbo wagon died with no warning wednesday morning. it was running fine, i stopped at the post office for 5 minutes, and it wouldnt start. it still hasnt.
i found good information at this page:
http://www.k-jet.org/documents/greenbooks/700-series/
scroll down and there is a link to the greenbook ignition manual (incomplete, buy mostly there) http://www.k-jet.org/files/greenbooks/700/TP31397-1_700_ignition_incomplete.pdf , with excellent troubleshooting instructions if you're handy with electrical testers. there is also a link to the 760 wiring diagram manual http://www.k-jet.org/files/greenbooks/700/TP31075-1_760_wiring_diagrams.pdf. good luck!
-sue d.
Jul 24, 2010 | 1989 Volvo 760
INDY XCSP 700 1 MINUTE IT IS RUNNING FINE THE NEXT WILL NOT IDLE AND CAN'T GET TO 50 MPH ON FULL THROTTLE
cdi box on top of air cleaner not making proper contact to check keep wiring clips tight with zip ties should work for quite a while cdi box cost $300+
Feb 11, 2010 | Polaris New Genuine Polaris Snowmobile...
Hi. I have a Sankyo SD-508 airconditioning compressor that runs the refrigeration on my boat. It doesn't hold the refrigerant charge for very long (2mths or so) and I understand the seals may need...
Hi, yes it is a possible that you may have leaking seals . I have a link for you to check out and it may be of some help with the Sankyo SD-508 compressor.I have repaired Refrigeration systems for a lot of years.What I would do is locate/pinpoint leaks in you're system.I don't know if you charge the system you're self, but if you do there is a 99.9% chance of you locating this leak, and you will know what is leaking.If it has pressure in the system at this time, you can take a soap and water solution, Liquid soap or better yet, you can buy it at Orchard supply Hardware already to go for gas and freon leaks. I have the most high tech tools available to locate leaks, but always go back to useing this soap to find a leak.Spray it on all joints seals, the weak links in a system like where you add the freon at the scrader valve? Soap down all of these places and you will find your leak. You cant assume it is maybe just a seal.You can pressurize with nitrogen gas or freon. Dont forget to check the evaporator.Good Luck and here is a link that may be helpful, www.citroen-sm.org/wiki/index.PhP/Air_Conditioning. Let me know what you find.
Shastalaker7
Nov 14, 2009 | Heating & Cooling
Have been told 'knox' sensor's need replacement @
The "knock sensor" adjusts timing. So bent valves could result if timing is way off. Your car would quit running before timing was that far off. $700 sounds high shop around.
Jun 17, 2009 | 1996 Lexus ES 300
GE disposall gfc 700 gets stuck
It sounds like the internal works are starting to corrode. You can remove the rubber shield and use a flashlight with the unit unplugged of coarse and look to see if something is caught under one of "teeth". If you don't see anything, then replace the unit.
Mar 21, 2009 | Little Giant SDS-10 Sewage Disposal System...
Sound Problem
Hi.........i have a compaq presario 700 series.In my laptop if i plugged my headphone into my laptop the lap speakers cant stop working,both laptop and headphone speakers are working
Aug 02, 2008 | Compaq Presario 700 470024-192 Notebook
Dark spot in centre of screen.
I have a little dark spot that i noticed it today too on my canon SD870IS i hope somebody can tell us what's the problem
Jan 02, 2008 | Olympus Stylus 700 / 700 Digital Camera
Sankyo Sound 700 Super 8/ Single 8 Film Projector Logo
48 people viewed this question
Top Sankyo Office Equipment & Supplies Experts
k24674
Are you a Sankyo Office Equipment and Supply Expert? Answer questions, earn points and help others
