Question about Refrigerators
Black slimy stuff comming out of my Refrigerator water dispenser
There is a black slimy stuff comming out of my Kenmore Refrigerator door water dispenser, I know is not the filter I put a new one, the slimy stuff looks just like the stuff that's on the bottom of my AC evaporator drain pan.
  • 27 Answers
Sounds like you need a new water filter
Posted on Jun 15, 2009
  • 10,865 Answers
Yout water dispenser is contaminated with mold. This is a potentially dangerous situation.
I would definitely contact the appliance store and tell them what is going on.
I have a GE refrigerator with ice and water dispenser. At times a stringy, slimy substance will pass through the water dispenser. I have changed filters, but it still happens . Any thoughts?
Inside the refrigerator is a coil of plastic tubing. It's purpose is to chill the water for the dispenser. The only way to clean this is to run a lot of water through it. I use a gallon container and fill it several times. If you get the same condition in your ice, then I'd install an external water filter in the water line behind the refrigerator.
May 10, 2016 | GE Refrigerators
My whirlpool GS6NBEXR refrigerator ice cube maker leaves slimey, flaky residue at the bottom of my glass. What can I do?
Diana, if I understand you ok, the ice you put in the glass leaves slimy residue. So that slimy stuff has to be in the ice cube. Well remove the the ice maker unit and thoroughly clean this ice holder and throw away the ice cubes in the kitchen sink and see if leaves slimy stuff. As for slimy stuff, while the unit is out, check any leaks etc. BTW any smell?
Jan 06, 2014 | Whirlpool GS6NBEXR Side by Side...
How to clean water tank as water dispenses with some black stuff
If you look up inside you will mold around the spout. this is were your black stuff is coming from. THe water system is completly sealed and cant be cleaned. However you can flush it. Use a cleaner with bleach in it to remove the mold from dispenser. You also may need to change the chute door . It leaking air is where the mold came from. Ihope this helps.
Aug 21, 2011 | Jenn-Air JCD2389G Side by Side...
Water is not getting to my icemaker...I swapped the solenoids and pressed water dispenser on door and now i get water to icemaker...not sure what that is telling me is bad
You swapped the solenoid's wires. Switch the wires back.
It means the ice detect lever is up or broken on the ice maker.
See the article on ice makers at How stuff works.com
Apr 17, 2010 | Kenmore 57029 Side by Side Refrigerator
No water from dispenser
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
Dec 21, 2009 | Kenmore 56722 / 56724 / 56726 / 56729
Kenmore s/s f/f; ice dispenser working; water dispenser not
If you can't hear the solenoid on the water inlet valve(it's on the back where the water supply hooks up) when you try the water then the water switch on the dispenser is at fault.
If you do hear it Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it doesleave the door open till it thaws.
If it doesn't come out there disconnect it at the water inlet valve and see if it comes out there.
Oct 02, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My Kenmore side by side unit leaks water onto the floor and the water dispenser has stopped working. When I hit the dispense switch I hear water squirting.
Probably the plastic tube that came from the solenoid is broken somewhere between the solenoid and the dispenser(usually under the refrigerator).
Sep 20, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Doble door kenmore new fiter water not working
While working withe filter assembly it is possible that you unplugged the dispenser electrical connection. I will need the Sears number for example 213.258978 to assist you better. Let me know
http://servicepartstec.blogspot.com/
May 28, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
New filter but water dispenser still not working
Check the water valve if its working most probably watewr line inbetween the water valve and the water dispencer is frozen. Un plug the refrigarator for four hours and try again.
Mar 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
924 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
