Question about Craftsman EasyFire Electric Staple Gun
Load brad nails on craftsman 968514
How to load brads
4 Suggested Answers
  • 163 Answers
SOURCE: bought Craftsman electric brad nailer
You should be able to get the instruction manual from www.searspartsdirect.com just enter in the model # of your kit.
Posted on Apr 05, 2011
  • 885 Answers
SOURCE: evolv 2 brad nailer no power
If you can check nailer on another compressor. If it works check your compressor, if not the nail gun is in need of repairs. Otherwise, reading the two guages on the compressor, check that the pressure in the tank is around 100psi and the regulated pressure is between 85 and 90psi. If not, regulated pressure is adjusted by the knob on the front of the housing. With a blowgun on the end of hose, connect the other end to the compressor. If you don't get any air the regulator may be broken and not letting air through. If you have air at the blowgun the problem may be with the nailer.
Posted on Apr 09, 2012
  • 3203 Answers
SOURCE: How do I fix my craftsman electric brad nailer
I have one that looks just like the illustration and mine doesn't operate either. I have had it apart and the switch is faulty and seems to be a very poor design.
Mine has a different brand name (Rapesco) and under the label is a generic Chinese export which the local supplier reckons is a throw-away item and no spares are available.
One of these days I will exercise some guile and attempt a repair.
Posted on Feb 03, 2015
How do I load the stapler?
No you don't. We answer most things here.
If the stapler is like any of these
http://www.amazon.com/s?ie=UTF8&page=1&rh=i%3Aaps%2Ck%3Abostitch%20staple%20gun
You push the back in slightly to unlatch it and then drop it down a bit and the staple pusher comes out completely.
Jan 28, 2016 | Heavy Duty Stanley Bostich Heavy-duty...
How to load brads into Stanly brad gun
Load in slider of nail magazine with the nails touching the bottom of the magazine.
Sep 28, 2014 | Tools & Hardware - Others
How to load brads into stanley tre 550 electric staple/brad nail gun
HOW TO USE YOUR ELECTRIC STAPLER/NAILER
TO LOAD STAPLES
1. Unplug tool, (fig. 1)...(place on/off switch in "off" position, (fig. 2).)
2. Place on/off switch in "off' position.
3. Select proper staple length.
4. Use only staples identified by stock numbers on next page. Substitute staples may cause jamming.
5. Hold tool upside down. (Squeeze latch and pull, (fig.3).)
6. Drop staples in channel, legs facing upward. Push latch back in to lock in place, (fig. 4).
TO LOAD BRADS
2. Use only brads identified by stock numbers on next page. Substitute brads will cause jamming.
3. Look for the image of a brad nail on the front side of the tool (fig. 5). Load brads into this side only.
4. Hold tool upside down (Squeeze latch and pull, (fig. 3).)
5. Drop brads into the channel, tilt the tool so the brads lay against the channel wall, (fig. 5).
Push the latch back in watching that the brad strip does not fall over.
6. Use High/Low power when driving brads.
TO STAPLE OR NAIL
1. Make sure the on/off switch is in the "off" position, plug stapling tacker in.
2. Turn tool on by switching to position 1 which is the "on" position and hold firmly against work surface to
engage safety mechanism.
3. Apply adequate pressure on the top of the knob (fig. 6.) while the trigger is pulled.
You can find the figures mentioned above at the following link:
http://bdk.force.com/FAQ/servlet/fileField?retURL=%2Fapex%2FPKB_Article%3Fid%3DkA0C0000000CdtPKAS%26brand%3DStanley%26returl%3D%252Fapex%252Fpkb_search%253Fbrand%253DStanley%2526mode%253D0%2526model%253D%2526sortby%253D0%2526terms%253DTRE550&entityId=ka0C0000000CdqqIAC&field=File_1__Body__s
Jun 20, 2011 | Stanley Tools TRE550 Electric Staple/Brad...
How to load brad nails
UNPLUG
look for image of brad nails on tool, load this side only.
Hold upside down.
Pull base back, and swing open......
Be sure they dont fall out, and make sure to use hi power ONLY.
Feb 14, 2011 | Electric Stanley Tre500 Staple Gun /...
Forgot how to load the 9/16 brads into craftsman 968514 staple gun
turn the gun upside down and there is a silver slide plate left that up and there will be the location to load the brads
Jan 09, 2010 | Hand Tools
How do you load nails in stanley tr250 staple and nail gun??
The magazine on the TR250 has a recess on one side as well as a relief at the top where the driver pushes them through the opening. Load the brads/nails on that side of the magazine and it should operate properly. AS A REMINDER: ALWAYS REMOVE NAILS/STAPLES/BRADS WHEN NOT IN USE AS THIS WILL WEAKEN THE SPRING AND CAUSE FEED PROBLEMS IN THE FUTURE.
Dec 22, 2009 | Stanley TR250 H Heavy Duty Heavy Duty...
Power shot nail gun? how do you load nails into it? i can do th
With the brad head torwards the top, just slide the brads down the center of the track, (same one as for staples), and then insert the follower. Hope this helps.
Jul 05, 2009 | Hand Tools
Inserting brads into my Stanley TR250 Staple Gun
I bought one of these guns today and I had the same problem and it took me about 2 hours to figure it out as the instructions were very poor. Here how to load the brad nails:-
(a) Pull the slider bar all the way out
(b) Place the brad nail stick on the left side, IN FRONT OF the slider, NOT in the narrow gap in front of the two arrows where it says "LOAD BRADS"
(c) The nail heads should be facing the handle of the gun
(d) Close the slider and lock it
(e) Try it out. I tried nailing hardboard onto chipboard. The lever at low power only put the nail in about 30%. On Hi power it went in about 80%.
Good Luck
Peter
Jan 07, 2009 | Stanley TR250 H Heavy Duty Heavy Duty...
How to insert fasteners
Already posted in response to a similair question, however repeated here to close off open query!
Good Luck
Peter
Craftsman EasyFire Electric Staple Gun Logo
67 people viewed this question
Top Craftsman Tools & Hardware - Others Experts
Dusty Ryan
Level 1 Expert
Mike
John Trevino
Are you a Craftsman Tool and Hardware - Other Expert? Answer questions, earn points and help others
