Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Sony not turning on
I am having the same problem as Bridgette with model
KP-46S15.  The red light is on & hear the clicking, but tnot coming on.  Would it be the same issue & if so, what does it take to fix it and how costly is it?
  • rcdhall42 Jan 16, 2009
    I have the videoscope kp-46s15 and it started just blinking for the first few minutes when I turned it on but now it is continuous
    President:
  • 4,402 Answers
How many flashes? Is it continuous?
If you count the number of blinks, then go to this site:
http://www.iwaynet.net/~nesda/SonyBlink.html
you will get some idea of the trouble. But, continuous blinking is usually associated with the "jungle" chip which is not a clear and easy cure; it must be further diagnosed by a tech; repairs are probably over $200.
Posted on Dec 19, 2007
Hi I have a sony kp-53HS10 TV. When i turn it on it use to make a clicking noise and than the tv would turn on, but now the clicking noise is gone and nothing comes on. A red light under the tv stays on....
Sounds like a Power Board / Video Board issue - stand by power is still ok - and why you have a red light - but the set is unable to power up the panel to drive a picture. Or the video board is the issue an is no longer processing the image to your panel. Based on the clicking noise - I lean towards the power board as the issue.
Dec 21, 2017 | Sony KP-53HS10 TV
My sony kp-53v35 keeps immediately shutting itself off
Older model---it should when you try to turn it on have the red light blink for several seconds (set is checking things inside) and if comes on and shuts off that light should blink a specific sequence of blinks----5 blinks and repeat it endlessly---
I have a stupid question: when it first failed did you hear a small pop or smell a faint odor of something burning?
Mar 22, 2012 | Sony KP-53V35 53" Rear Projection...
My Sony TV Model # KP-51WS510 flushing 4 red light or blinking 4 red light again and again, once I turn on the TV power. No picture on the screen and you will hear that it will shut off but the 4 blinking...
Usually a flashing power light on a rear projection TV means a bad bulb, try replacing the bulb. Also try unplugging it for 10-15 minutes, then come back and plug it in and try again. Also if its been a long time since its been serviced it could be dust buildup causing overheating, do you hear the cooling fan running? It could also be a failed cooling fan. Generally the first thing i do with projection TV's is clean them, clean all the vents, pull the bulb out, clean out the cooling fan and bulb housing, and then try a new bulb. If that doesn't fix it then its a bigger internal problem and there is no quick fix but have it serviced.
Jan 02, 2018 | Sony KP-51WS510 51" Rear Projection...
Picture not working on Sony Videoscope
YOU PROBABLY NEED NEW CRTS. UNIT IS GOING INTO IK BIAS SHUT DOWN WHICH MUTES THE VIDEO SIGNAL. YOUR SET IS OLD ENOUGH THAT IT WOULD BETTER TO GET A NEW SET. EST $1300.00 IF CRTS ARE AVAILABLE
30 YR SERVICER
APGONZO
Jan 01, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony wega kp51 turns on for 3 secs than off w/ blinking red light
The flashes are fault codes. It means your system is faulty. If it is intermittent then it is more than likely a dust issue. Buy an air duster, spray out the back and restart. Should be fine
If it continues to play up then it will be a repair job
Dec 08, 2008 | Sony KP-51WS520 51" Rear Projection...
Standby/timer light stays on red. no picture or sound on tv.
my sony red light flash.but it will not turn on just clicks
Nov 26, 2008 | Sony KP-48S75 48" Rear Projection...
6 red blinking codes
Below is picture of error code table of Sony TV KP-57WS500You can check what is error 5 and 6
Oct 31, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-53HS10
I've had my T.V for about 5 years, and the other day the screen just died and I have no audio, but the when I plug it in the red light in the front flashes, have any idea on what to do.
Nov 21, 2007 | Sony KP-53HS10 TV
Sony KP-53S75 Makes Clicking Sound But Wont Turn On HELP!!!
Good Day, menudude;
The Sony your friend gave you is a 2000 Model and cost about $2,000.00 and you don't want to spend $400.00 to get it repaired? GET THE TV REPAIRED FOR THE MONEY.
Good night & Luck, big IRISH.
Oct 01, 2007 | Sony KP-53S75 53" Rear Projection...
No picture
does the red light give you a blinking code pause then code?
Sep 13, 2007 | Sony KP-53HS10 TV
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
87 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
