Question about SWANN Home Security
MONITOR I HAVE HP ALL-IN-OINE COMPUTER. CAN NOT GET SWANN SYSTEM TO SHOW ON OUTSIDE MONITOR
Do I need internet connection to set up new swann security system even if I don't want to remotely view footage
go to the main menu in DVR find network setup and give it static IP
Example :
IP: 192.168.1.100
Gateway : 192.168.1.1
subnet: 255.255.255.0
then go to your monitor device (computer or smart phone)
inter the IP address (192.168.1.100)
into your browser address bar
Oct 20, 2016 | SWANN Home Security
Can I hard wire to my laptop to monitor my Swann system?
its more easier to connect them through network
Jan 04, 2016 | SWANN Home Security
Swann H.264 8Ch Digital Video Recorder wiring diagram of the components inside the receiver.
Hi Rod
They don't seem to have wiring diagrams or schematics for the public any more.
It's a throw away world!
Contact Swann support
Tech Support Email
Sep 21, 2015 | SWANN Home Security
How to monitor my surveillance system away from home
  1. Contact Swann, they have a very helpful support team.
  2. They have software that makes remote viewing so easy.
  3. Have your serial number for your DVR available, provide it to them and they will walk you through downloading the software and assisting you with the set up. It doesn't matter when you purchased it, they are very helpful.
  4. And if you would like, with your permission, they will take control of your computer and do it for you!
  5. Absolutely helpful team.
  1. Swann Communications Portal
Jun 14, 2014 | SWANN Home Security
How do I get my Swann ADW-400 camera/recorder of of PAL mode and Back to NTSC
Connect the DVR to a monitor, go to system or camera settings, select NTSC as signal type, save and reboot the DVR.
Jan 12, 2014 | SWANN Adw-400 Video Surveillance System...
No colour on my swann pro-530 cctv camera
Your cameras might be in PAL mode, go into system settings and change to NTSC setting.
May 03, 2013 | SWANN PRO-530 Multi-Purpose Day/Night...
Cannot install the drivers on windows 7 computer. for my Swann adw 300
hi,
Check the operating system you are using is it 32bit or 64 bit. If you are using windows 7 with 64 bit, then your operating system will accept only external devices that support 64bit. Also check the security system has the capability for working with windows 7 64 bit operating system.
Jun 09, 2011 | SWANN Security Sw233-adw - Swann Surv Kit...
Swann dvr pro-net
Go to menue ---> System ---> Clear HDD and make sure "yes" is selected and hit enter.
May 16, 2008 | Swann Communications DVR4-Pro-Net...
Home Security Logo
12 people viewed this question
Top SWANN Home Security Experts
Electro Med Services...
L Pfaff
L Pfaff
Da Doc
Are you a SWANN Home Security Expert? Answer questions, earn points and help others
