Question about Konica Minolta Bizhub C220 Color Copier/Printer/Scanner
The copier reads, "The ADF is currently not available." How do I fix this?
The copier reads, The ADF is currently not available." How do I fix this?
  • Konica Minolta Master
  • 6,680 Answers
This is going to be a two step process:
With the machine on go to service mode. Select System 1, Problem Unit Isolation, Find ADF, Select Unset, (This next step ensure you wait ten 10 seconds between) Power off the machine, 10 seconds later turn it on.
Once ready to copy. Conduct the same procedure again this time select ADF select SET this time. Power off a ten seconds later Power on. If the problem keeps coming back have a tech come out.
Posted on Feb 19, 2018
I have canon IR2010F copier with ADF and automatic feeder slips while taking the document in the feeder and makes tic tic tic tic noise while taking in the paper in the feeder, When we provide hand...
there are two locking handles for the adf on either side of the cover of adf i am sure one of them is broken or disfigured that why when u press it the adf works.i dont think this spare part is available u have to use ur own creative skills to make it through melting plastic to make a hook for that side
Jun 05, 2011 | Canon imageRUNNER 2010F Copier
My HP 2727nf ADF gets stuck on the second page because the first page doesn't completely discharge. There doesn't seem to be anything binding the sheets.
First, make sure that the firmware is up to date on the machine. Current revison is 20100902. Download from www.hp.com. That may not fix the problem, actually probably won't but can't hurt to try. I have found that this problem is usually caused by a bad ADF cable or board. Either way, unless you have a donor machine you will need to purchase a new ADF assembly. Part number is CB532-67903.
Apr 16, 2011 | HP M2727NF Laserjet Printer
How do I get a meter reading of number of copies?
Here you go.
  1. Press the [Reports] button on the Control Panel
  2. Press the [Up] or [Down] arrow until 'Systems Data' is displayed on the Display Screen.
  3. Press the [Enter] button.
    The System Data list will be printed with the following information:
    • Total Page Counts: Total number of pages printed
    • CRU Prints: Number of pages printed using the current Toner (Dry Ink) Cartridge
    • Replaced Toner Counts: Number of new Toner Cartridges installed in the machine
    • Replaced Drum Counts: Number of new Drum Cartridges installed in the machine
    • Current Drum Page Counts: Number of pages printed using the current Drum Cartridge
    • Platen Scan Page Counts: Number of pages scanned using the Document Glass
    • ADF Scan Page Counts: Number of pages scanned using the Automatic Document Feeder (ADF)
Feb 10, 2010 | Xerox WorkCentre M15i Laser Printer
ADF won't draw document to be scanned into the scanner
The first thing I always do to a misbehaving ADF is take a dust blaster(canned air) and blow all of the dust and debris out of the ADF,This means lifting the ADF cover and cleaning everywhere.There is always a switch or sensor whose job it is to detect a sheet of paper placed in the ADF.Good Luck.
Mar 27, 2009 | Canon Office Equipment & Supplies
My hp officejet G85 won't successfully send multipages faxes Can you help me with this problem?
Not sending multipage faxes I will assume the pages are not feeding correctly. If this is the case replacing the entire ADF would be the easy fix.
Not available new from HP as far as I can tel but available if you search G85 ADF.
If machine is terminating the connection try reseating th LIU this is the board the phone line plugs into. part C6735-60009
Hope this helps
Mar 06, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
How to disable Fujitsu fi-5750C ADF
Your scanner will never pass the initial boot "test" sequence without getting sensor and light readings. Cut the binding and scan it through the adf and save a few weeks work.
Oct 27, 2008 | Fujitsu fi-5750C Flatbed Scanner
Bizhub C650 (Minolta printer, copier)
setup for adf if is new machine u have the setup **** for adf
the setup **** (A4 page) with black border
Oct 13, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Black lines across copies
try the drum, replace and make a copy
Aug 18, 2008 | Sharp AL 1631 Copier
Konica Minolta Bizhub C220 Color Copier/Printer/Scanner Logo
498 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
