Question about Masonry Tools
Belle mixer 130
Will not turn when switch on
A belle cement mixer,wont stay on when start button is pushed,changed switch ,still the same?
Sometimes the most simplest of fixes is verifying that you have voltage at your outlet and that you have voltage getting to the motor.
Check the motor's overload button; reset if necessary.
Take resistance readings:
  • start capacitor
  • run capacitor
  • and motor
If anyone of their specs are out of whack, that's the component that is defective and will need to be replaced.
Mar 24, 2015 | Masonry Tools
The wires have come out of the switch
take it to an electronic repair shop in town karen don't fix yourself!
Mar 22, 2014 | Bell Labs Protecta Load-N-Lock Anchoring...
Water fills to over flowing and never starts agitate or spin cycle
With the tub empty disconnect the air hose from the water level switch in the console. Blow through it to see if its kinked or restricted. Check the air bell for a buildup of **** especially near the opening where the air hose attaches.
If all is OK reattach the hose and disconnect it from the air bell. Turn your water off and set it to wash. Blow through the hose to see if the switch goes from fill to agitate.
Jan 03, 2012 | Maytag Performa PAV2200
Iv'e got a belle cement mixer 150, i think the motor is on its way out, its around a 2007 model can you tell me if you can put new brushes in the motor if so how, or if i can have the motor reconditioned ?...
i have a belle 110v cement mixer just over a year old.Everytime i use it ,it switches itself off after mixing 2 barrows of concrete but it will run perfectly for hours when empty.(tryed this out on Monday)So therefore it only switches itself off when loaded.
Gets very hot quickly.
Any suggestions would be much appeciated.Brian
May 03, 2010 | Home Fencing
My KitchenAid KSM90 will not turn off. All the speed settings seem to work, it just won't shut off. I have it open, but don't understand how the switch operates such that it turns the mixer off. The...
I determined that the switch that controls whether the mixer is on or off is controlled by a copper bar with a contact. The contact got fused to the copper bar, possibly due to a short. Since the contact got fused to the copper bar, the circuit was always connected, so the mixer was always on. The solution was to 1) unplug the mixer, and 2) take a screw driver and gently pry the contact away from the copper bar. When the mixer is in the off position, the copper bar and contact are no longer in contact. When the mixer is on, the copper bar and contact make contact. My mixer now works just fine. Yea!
Jan 28, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
I dropped my KitchenAid mixer on its side on the counter. The knob broke off, and now the slider bar used in speed selection appears to be bent. it's very hard to turn it on. Is this repairable?
Yes it is. The whole lever is available as a spare part. You will need to provide the complete model number and the colour of the knob (they are usually black or storm grey). It is probably this part you need: http://kitchenaidmixers.co.uk/Home/tabid/36/ProductID/130/Default.aspx
Jan 23, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Broken mixer blades on a bravetti 300watt hand held mixer
Bravetti Mixer Beaters 10+ Bravetti Products Shop, Compare and Save at Pronto.Bravetti.Pronto.com
Nov 02, 2009 | Bravetti 130 Watts EP524H Hand Mixer
Water not hot at the Symmons Safety Mix valve. Had plenty of hot water before I installed a new hot water heater. Now, it's not as hot. I turned up the temperature to about 130 degrees. Sometimes it is...
There might have been some sediment that came thru the water line after changing the water heater and got into the mixer valve. You may need to shut off the water and clean out the mixer valve assembly.
Oct 27, 2009 | RTO Symmons Deluxe Temptrol pressure...
Masonry Tools Logo
Top Masonry Tools Experts
Tom Chichester
Are you a Masonry Tool Expert? Answer questions, earn points and help others
