Igniter specs for AF22#6603940
Oil furnace wont start what are the specs for the igniter
    Sergeant:
    Champion:
  • 234 Answers
Does the power pack deliver enough volts? Is the gap on the electrodes too wide? Is the burner spud clogged? I believe it should put out about 10,000 v. is the cad cell clean?
Posted on Nov 26, 2014
I HAVE A GENERATOR HONDA E2500.
the generator is not big enough to run what you want
it needs to be 3500w minimum or 4.5w to be safe
although it is stated at 2500 watts , in fact that is the peak load on electric motor start up and its continuous rating will be around 1.8 watts
all of this is clearly stated on the specs plate on the generator
Dec 06, 2015 | Honda Generator E2500 Vintage Great...
Why will my oil furnace not start when cold
It's probably the igniter rods. Their tips need to be ground flat and realigned to specs. Or you can buy replacements for not much money.
Dec 08, 2014 | Heating & Cooling
My furnace works on ac and blows on ac but on heat it does not blow but i hear a humming sound coming from the furnace
Most furnace operating on Oil or gas will heat the combustion chamber before starting fan to prevent cold air draft at start-up, can last a minute or two. Eiter the main flame does not come on or the chamber thermostat have fail. Try to modify fan option on room thermostat from auto to on. Cold air coming out: burner problem or no more oil or gas, warm air: burning chamber thermostat problem, leave room thermostat fan option to on until repair.
Jan 02, 2014 | Comfortmaker Heating & Cooling
Where is my flame sensor on a single burner coleman evcon high efficiency furnace
If this is a hot surface ignition system, the sensor may also be your igniter.
Dec 11, 2013 | Heating & Cooling
Ruud furnace troubleshooting
check that elements are intact and getting voltage
Nov 14, 2013 | Heating & Cooling
Reillo 40 oil burner wont start
If I read correctly, you should have a pump for your fuel oil. If you are not getting anything out of the bleed screw I would suggest you start there, see if it is running, then check for clogged fuel lines, or possibly filter. Do you have a pilot light or HSI? Does that come on?
Mar 02, 2013 | Heating & Cooling
How many gallons of propane will I use per month?
Go on to google and use BTU per gallon calculator at Irving energy this will give you the price between them both
Mar 06, 2017 | Heating & Cooling
Goodman furnace gmh95090cxac wont stay lit keeps clicking will lite then clicks back off what would be the problem
Hello, if the burners light but do not stay on for more than 10 seconds, I would clean the flame sensor. The flame sensor is a metal rod that is on the opposite side of the Igniter, sometimes it gets coated by oxidation and does not sense the burner flame and shuts the Furnace down. To clean to kill power to tje furnace, remove flame sensor and clean with a steel wool, then reinstall and start Furnce back up. If this does not work then most likely the Igniter is too weak to ignite the gas and will have ro be replaced.
Oct 29, 2012 | Heating & Cooling
Rheem Highboy Oil Furnace runs, then shuts down. I throw in a lit paper to burn off oil residual from failed start. Hit 'Reset' button and furnace starts up. It may start up by itself for the next 3...
Oil furnaces have certain items that routinely go bad or need adjusted to work properly.Some of the common things are nozzle, then gap and location of the igniter,then last is the fire eye. You can see all of these items by pulling the burner tray out. The nozzle delivers the fuel in two ways more or less, first is spray angle then second is the rate or GPH. Nozzles are to spray an atomized mist this means no heavy droplets of fuel. If you have large drops of oil chances are a new nozzle can help you out, please pay attention to spray angle and GPH. The igniter is next, after time they will wear and you can clean the rods and reset the gap to specified distance, that being said it also needs to be a certain distance from the atomized fuel to ignite properly all very important. Then last is the fire eye it tells the furnace that a flame is established and to deliver fuel or flame out and shuts fuel down. These will build carbon deposits at times so simply clean off the deposit and clean the lens with a soft cloth and windex reposition put the burner tray back in hook up the fuel line and off you go.
Dec 20, 2010 | Heating & Cooling
Furnace wont stay on
Have you checked to see if oil is coming out of nozzle? you should be able to put a flash light in the axcess hole. Is there sparks going acrosas electroides? Has furnace filters and oil filter been chanded, and furnace been cleaned?
Jan 20, 2009 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
