Question about HP Office Equipment & Supplies
When i scan an image in and then crop it with the photoshop software, when I hit "accept" the file closes, the scanner gets stuck in "scanning" mode and the image file is lost. I used to do this all the time, but suddenly in the past week, this happens anytime I goto crop an image and "accept" the changes. Please help!
    President:
  • 1,865 Answers
Use add/remove programs to remove photoshop, and then reinstall it.
Posted on Jun 15, 2009
When I push the SCAN button I get a message that asks me to 'specify the program where the scanned image is transferred'
You need to set up the destinations in the Canon software. First launch the Canon Scan-Gear Toolbox. The Scan button on the scanner is the same as Scan-1 button by default but no software is linked to this button. Click on the Scan-1 button then choose Set. Then set your application that you will want to work on the scanned image. Select your application (Photoshop Elements, for example) - the exe file if using Windows. (You may need to browse the Program Files folder and then the individual application folder (C:\Program Files in recent versions).) Then click Open and then Apply to confirm this. You can also select the file type that you want the scans to be saved as in this settings window.
If you want to change the scan destinations, then click on Settings (on the far right). You will see the drop-down menus for each of the scanner buttons. Select the desired function for the scan button and click OK. (Scan-1, Scan-2 and Scan-3 can be linked to other software.)
I hope this helps.
Oct 10, 2011 | Canon CanoScan N670U Flatbed Scanner
How do i select the destination of a scanned file ie photoshop using epson scanner tx550
Firstly, the best way to get more from the scanner is to use it via an image application which is twain compatible e.g. serif photoplus, photoshop or gimp. Run the program, click file, then either aquire or import depending on the application you are using, the twain will then start the scanner software, use the scanner software as shown in the manual and this will produce the scanned image in e.g. photoshop. Click file on the program and click save as. This will give you the opportunity to save the file either onto the internal hard drive or an external memory stick etc. hope this helps
Jul 17, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I scan a document and then I click on
I suppose you should have some software running on your system to accept the file.
Check the user guide.
Scan an image
You can start a scan from your computer or from the HP All-in-One. This section
explains how to scan from the control panel of the HP All-in-One only.
To use the scan features, the HP All-in-One and computer must be connected and
turned on. The HP Photosmart Software (Windows) or HP Photosmart Mac Software
(Mac) must also be installed and running on your computer prior to scanning.
● On a Windows computer, look for the HP Digital Imaging Monitor icon in the
Windows system tray (at the lower right side of the screen, near the time) to verify
the software is running.
HP All-in-One overview
Note
Closing the HP Digital Imaging Monitor icon in the Windows
system tray can cause the HP All-in-One to lose some of its scan
functionality. If this happens, you can restore full functionality by restarting
your computer or by starting the HP Photosmart Software.
● On a Mac, the software is always running.
Tip You can use the HP Photosmart Software (Windows) or HP Photosmart
Mac Software (Mac) to scan images, including panorama images. Using this
software, you can also edit, print, and even share your scanned images. For
more information, see the onscreen Help that came with the HP All-in-One.
To scan to a computer
1. Place your original print side down on the left front corner of the glass.
2. Press Start Scan/Reprints.
A preview image of the scan appears on your computer, where you can edit it.
3. Make any edits to the preview image, and then click Accept when you are
finished.
Dec 19, 2009 | HP Photosmart C3180 All-In-One InkJet...
How can I scan from my scanner to my computer
Of course scanner have it's own freeware software provided with driver & software for your scanner with all operating system required.
Run the Disc to install a program with the drivers also to let you scan documents, pictures, & etc...
All the setting are there to know how to scan.... First Preview it then scan and it will send to your driver (destination folder) where it saves the files.
Sep 19, 2009 | Epson Perfection 2400 Photo Flatbed...
How does the scanner work?
Simply pull the lid on the top and place the paper on it . Then close the lid and press scan button on the scanner, which will start scanning your documents.
Aug 29, 2009 | HP PSC 1315 All-In-One InkJet Printer
Scanned image is yellowish
which software is running with this scanner.
Plz check the settings for this software, i think it might be setting problem of this scanner software.
Try to scan the photo in photoshop where u will watch the setting of this software.
Open Photoshop-File-Import-then Acquire Image
Here you will find the settings.
May 29, 2009 | Umax Astra 1220P Flatbed Scanner
Most of the time my Nikon 5000 works well. Recently I encounter the following problem. After several normal scans the program stops after the physical scan. (can hear from the scanner movment.) Nothing...
Hi, I have the same problem. I am running on the same computer with the same software Nikon Scan without problems. Found out that the problem happens mostly when a crop is selected that just eliminates the scanning frame. Without crop mostly OK. However no reason why and no real solution
Apr 15, 2009 | Nikon COOLSCAN 5000 ED Film Scanner
Scan copy to computer
Please check the original software disk that accompanied the scanner. You should have the option to install a twain or twain32 driver at the least, which would allow you to scan from within a graphics program (photoshop, or even paint).
Jul 04, 2008 | Epson Perfection 2400 Photo Flatbed...
Automatic Cropping...
Before turning off the autocrop feature, reset the software to the default setting. Then turn off the autocrop feature. Some scanning software need to be reset to the original default condition and accept software switches only then!
S. Mohan
Dec 05, 2007 | HP ScanJet 8270 Flatbed Scanner
Scanning
Reinstall the the software Come back it that does not work
Mar 22, 2007 | Lexmark P6250 All-In-One InkJet Photo...
21 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
