Question about Heidi Klum 1028772 Truly Scrumptious Sienna Double Dresser
Can't open Unable to open stroller. Left side is stuck but right slides down to open. How can I unhitch the stuck side
Init unable 50
Solution 1:
  • Lift the scanner cover using the plastic tabs, located on the left and right side of the machine until it locks securely into the open position.
  • Slide the print head to the middle.
  • Check for any pieces of paper or staple , paper clip...
Solution 2:
  • Slide the print head over to the right side under the cover to make sure you clean the entire encoder strip.
  • With the lint free cloth, firmly grab the encoder strip on both sides and rub the cloth down the strip from one end to the other (left to right then right to left) at least three times.
Jul 13, 2016 | Office Equipment & Supplies
My baby stroller is not folding it stuck
Which model Safety 1st stroller do you have and which country are you in?
Feb 28, 2013 | Safety 1st Baby Gear
My stroller if not folding its stuck how can i fix that
Hi
Which model Safety 1st stroller do you have? What country are you in?
Unable clean print50
or
If you need any kind of technical assistance then you can contact support cell at http://vtechsquad.com/printer-support/
Sep 05, 2012 | Brother MFC295CNAll-In-One InkJet Printer
Have bought second hand mutsy stroller, no manual and no idea how to fold the chasis down!
First remove the seat or carrycot/car seat if this is on the chassis. Then, stand to the left of the chassis. Push down the button on the handle which lowers the handle bar height with your right hand. With your left hand, take a hold of the black cuff on the side of the chassis (this should be about waist height). In one movement, you need to pull the left hand up, whilst pushing down your right hand, this needs to be done at the same time, and with some force.
When the chassis is lowered toward the floor, this will click shut. To open the chassis, there is a small metal arm on the left hand side of the chassis with a red cover on (this is quite little) you need to lift this button upwards (towards you) and the chassis will open.
I hope this helps.
Nov 13, 2009 | Mutsy 4Rider - Red Stroller
Can't fold maclaren mac 3 pushchair
Just below where the handle bar part meets the rest of the frame, on the left and right side you will find black plastic bits that point down, which you can slide your finger behind. The right hand one has a silver button which you need to push in. Then pull both of the plastic levers towards yourself and push down at the same time. The Mac 3 will then fold down.
Apr 06, 2009 | Maclaren Mac 3 Jogger
Zooper Boogie User's Manual
There's a safety lock located on the right side of the frame, about 6-8" down from the handle bar. There are also 2 sliding locks, one located on either side of the stroller, on the underside of the frame. One is located just below the safety lock. First pull up on the safety lock, and while keeping the safety lock open, simultaneously slide the other 2 levers up toward you. The stroller will unlock/open and you will be able to fold it.
Dec 24, 2008 | Zooper Boogie Jogger
How do fold the quinny buzz?
The are 2 grey clips either side...slide the left one forward at the same time as pushing down on the right & then frame will fold down.
Jul 09, 2008 | Quinny Buzz Jogger
Bertini M5 Shuttle
hi I think I could help I bought a bertini shuttle as well if you stand behind the pram on the right run your hand down the right side of the hood there is a push up lever there mine is grey ok you need to push the grey? lever but also on the left and right there is a black lever you must push up al together hope this helps good luck from debbie
Jan 09, 2008 | Bertini M5 - TS City Stroller
Heidi Klum 1028772 Truly Scrumptious Sienna Double Dresser Logo
70 people viewed this question
Top Heidi Klum 1028772 Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Heidi Klum 1028772 Furniture Expert? Answer questions, earn points and help others
