Question about Kenmore 57029 Side by Side Refrigerator
Wall hot between doors
I just bought a new kenmore model 5890 side by side refrigerator. The front wall strip where the doors meet is very hot. Is that right?
  • cphasili Jun 15, 2009
    Thank you! your advise was correct.
  • 58 Answers
No. The problem that you are having is the condenser fan motor in the rear of the unit is not functioning. You'll need to take the cardboard off the back, locate the fan motor and determine the cause for non-operation. My guess is that since it's new it's probably just obstructed. Hope this helps... Bill
Posted on Jun 15, 2009
Changed both bulbs on lower back of refrif they will not come back on Cant find an activator swithch
Look on the frame where the seal of the door meets the body of the machine. Occasionally on the inner side of the wall there will be a switch
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 16, 2012 | Kenmore Side by Side Refrigerator
The post between where the freezer and
Hi, Welcome to FixYa.
I`ll start by letting you know first the heat between the doors is normal...to a degree, and done by design to help prevent moisture along the "breaker strip"/divider.
If all else appears fine, temp. Ok, fans running, no significant frost build up on freezer back wall, it's likely nothing to be concerned about.
**Just be sure the condensor fan isn't jammed and still turning.** The fan at the back next to the compressor.
The amount of heat can be determined by several factor's such as,
1) temperature setting - lower ( colder ) the temperature is set the more the run time the hotter the strip.
2) The ambient temperature - hotter the environment the more the unit runs to compensate, hence the hotter the strip.
3) The amount of "fresh" content added to the unit ( especially freezer section if unfrozen items added ) - new items add a lot of warmth thus demanding the unit to run more to remove this heat (btu`s or british thermal unit`s )causing the strip to be hotter.
4) Build up of dust & dirt on the condensor coils - this also causes the unit to run excessively which in turn makes for more heat on this strip.
These are all things which can and do determine the amount of heat between the doors.
Another factor to always consider is of course If it is hot where you live the unit may just be running more to compensate as with other factors I mentioned.
Hope this answer's your question and let me know if I can assist you further. Thank's for coming to "fixya" and good luck moving forward.
Please take a second to rate the info provided here.
macmarkus :)
Jul 30, 2010 | Kenmore 53642 / 53644 Side by Side...
Where the two doors meet it is hot why?
Pull the refrig out and remove the rear panel . Check the fan there to see if it is working and the blade is not obstructed . If not working , and the blade is not obstructed , replace the fan motor . Also make sure the coils in front behind the kick plate are clean of dust , lint , etc . The cooling fan not working will cause the center door strip to get very hot .
Jun 13, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
REFRIGERATOR MODEL 106 IS HOT ON THE OUTSIDE. RIGHT FRONT SIDE WHERE FREEZER MEETS FRIDGE.
Make sure the condenser fan underneath near the compressor is running when the compressor runs. How to test it. http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 24, 2009 | Refrigerators
Burning hot where the doors meet
if the black pipes or outside evaporator gets very warm and there where you are telling me you have nothing to worry that is how its should be. wats the problem with the other fridges i will assist
Jun 16, 2009 | Estate TS25AFXK Side by Side Refrigerator
Leaking by freezer door in bottom
your drain line is clogged remove back wall and trow hot water in hole please unplug unit
Apr 05, 2009 | Kenmore 57029 Side by Side Refrigerator
I have a Kennmore Cold spot Model # 57285791. The center strip where the two doors meet is extremely hot and everything in the freezer is defrosted.
2 things you neeed to check first of all clean teh coils underneath the refrig. then pull unit from wall and pull off rear compartment cover and see if the fan that cools compressor is running. it is possible the motor is jammed or bad. if the motor is bad you can put a house fan blowing into the comp compartment until you get it repaired.
Jan 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Samsung model # rs2630sh side by side fridge. center strip is hot
I had the same problem, and it was the condenser fan motor. I ordered mine from www.partstore.com. It was half the price of sears.
I would suggest ordering the 2 "plastic bushings" for front and back of motor. I was able to reuse mine, but for a few dollars more it's worth it.
Jan 20, 2009 | Samsung RS2630SH Side by Side Refrigerator
Black strip on front of wall between frig and freezer really hot
not supposed to be hot to touch, try pulling out refrig and vaccuming the coils, your probably FULL of dust and debris, also remove the kickplate from front and clean under there as well
Sep 29, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Kenmore 57029 Side by Side Refrigerator Logo
135 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
