Question about Crosley Dryers
My crosley dryer won't work at all its like it don't have power. It was working just fine!
  • 867 Answers
Check the circuit breaker for your dryer at your power box
Posted on Jun 15, 2009
Model #CEDX563JQ0 Crosley Dryer won't heat and getting current
I would check to be sure you have 220v going to Dryer. Possibly timer problem as heat circuit runs through that too.
Aug 27, 2017 | Crosley Dryers
Dryer won't turn on - digital panel is on
Check the fuse. It is mounted on the right hand side of the control panel:
This fuse trips when that element gets too hot. Look for air restriction or a bad blower wheel.
Older dryer from monkeywards is like yours inside:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 15, 2012 | Crosley CDE6000 Electric Dryer
I have a model # CDE20P8A crosley clothes dryer that will not start. It has power to the dryer, but the interior light or motor will not work. Is there an internal fuse that I should check or replace?
Yes. It takes an LA-1053 fuse kit. Most of these dryers take way too long to dry the clothes, then the fuse blows because it over heats. The problem being the blower wheel. The fuse itself is attached to the side of the heater and is held there by a clip that is held in place by the long screw that hold the element. Unplug it and take it outside so you can sit it on a table to work on it.
To get inside release the clips
It won't do any good to replace the fuse if ya don't check the blower wheel.
They strip out and get loose on the motor shaft.
Aug 01, 2011 | Crosley Dryers
Crosley dryer will not turn on - worked fine one day and now will not work - suspect electrical switch but which one?
The thing that kills these dryers is lint and bad blower wheel. The lint causes excess heat in these dryers and that melts the blower wheel hub and it begins to slip. This makes the clothes take twice as long to dry and eventually trips the small thermal fuse mounted beside the heating element. themobilian_594.jpgthemobilian_595.jpg
Go ahead and remove the front panelthemobilian_596.jpgthemobilian_597.jpg More HERE
Dec 28, 2010 | Crosley Dryers
MY CROSLEY DRYER WILL NOT COME ON. IT WAS WORKING FINE AND NOW WHEN I PUSH THE START BUTTON NOTHING HAPPENS.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 28, 2010 | Crosley Dryers
Dryer does not get hot
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 13, 2010 | Crosley CEDC392JQ Electric Portable Dryer
My crosley gas dryer is 10 yrs old. It tries to start, I can hear the buzz. Sometimes it takes hours of tries to get it to ''catch'' and turn on. I recently changed the belt and the (?)blower wheel. Any...
when it starts does it work
if once you get it started it seems to work fine
well then you have astart winding on the motor goin bad. or done.....
try this... empty the machine
tape the door switch closed
push start and try to spin the tumbler
if it starts right up you have confirmed it
your motor is done
Oct 08, 2009 | Crosley CDG6000 Gas Dryer
Crosley cde6500w dryer has power will not work.
check the cord, check the safety switch on door. any internal fuse? last check section switch
Jun 24, 2009 | Crosley CDE6000 Electric Dryer
Dryer won't start
check door switch..onthejob
Jan 27, 2009 | Crosley CDE6000 Electric Dryer
Crosley dryer
right the part that is faulty is a silver tube which is fastened to the motor take it of making sure you have done a diagram of the wiring replace it once replaced the dryer will work fine common fault on these dryers its just wear and tear m8
Nov 17, 2007 | Crosley CDE6000 Electric Dryer
Dryers Logo
63 people viewed this question
Top Crosley Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
jasbo
jasbo
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
