Question about Radio Communications
Can't remove either the control knob or thermostat in smeg CR 325 A1 fridge freezer
Also known as CB 18 N
watsuke
  • 48 Answers
SOURCE: Monster CAble Coding Y CB CR
http://en.wikipedia.org/wiki/YCbCr
I dont quite understand it all but, it works somehow.
Posted on Feb 05, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Freezer not working
Your refrigerator has a Control-defrost,adaptive timer ,PC board part number 241508001
This is providing your model is the one listed above your post WRS3R3EW. The model you listed in post does not come up. Until we can determine that the freezer is not defrosting you need to unplug and remove the back panel of freezer compartment to see if the evaporator coils are frozen or clear. If frozen this alone will cause a chain reaction that keeps vents to fresh food compartment open and cause freezing in that area. Go to link below and enter model number WRS3R3EW0 Then you will see a list of diagrams on left side, chose #11 this will show the control parts. Click link below Thanks, Sea Breeze
We offer free help and assistance also.
http://servicepartstec.blogspot.com/
Posted on Apr 27, 2009
frederiquema
  • 76 Answers
SOURCE: GE fridge GDS 18 LBR
Have u check the moisture control in the frezzer? If so make sure that all the vents are clear of all food and/or food containers and such... Turn ur fridge temp control to max.. Wait 5 hours WITHOUT opening fridge or freezer. Good luck! Let me know how everything tur out
Posted on Sep 13, 2009
SOURCE: replacing a fridge thermostat of a Smeg FC40RX fridge freezer
DO NOT ATTEMPT THIS METHOD UNLESS YOU UNDERSTAND ELECTRICAL SAFETY. The thermostat is behind the cooling element at the back of the fridge compartment and it connected to the dial at the top front of the compartment that controls its temperature setting. Remove the front plate to access the switch and you will see the wiring that goes to the thermostat. Connect the two wires to the thermostat and if the fridge does not start the thermostat is faulty. Replacements are available, but you may need to do some hunting on line. With the power off this time, securely tie a few feet of string around the thermostat wiring at the switch. carefully loosen the cooling element to free the thermostat and pull it free. Now tie the string to your new thermostat and pull the string back through so the wiring is pulled into place. Put everything back the way you found it and, after a short while, enjoy a nice cold drink.
Posted on May 23, 2011
SOURCE: Smeg A1 cooker built in. Wish to remove top to
my smeg oven has always never worked properly, the temperature is faulty etc i now want to remove this oven and have bought a new electrical oven but cannot seem to get the smeg oven out. How do i remove this smeg oven?
Posted on Aug 06, 2011
Hotpoint fridge freezer ff200 tx displays error code A1?
These tempratures are pretty cold should be around 0 deg. but it sounds like you might have a bad defrost timer or defrost thermostat the frost should not come back if defrost system is working
Jul 26, 2014 | Hotpoint Freezers
Smeg FAB28QRI thermostat not restarting fridge unless I hit side of fridge! Do I need a new thermostat?
It could be a loose wire on the terminal of the compressor. Also check for loose wires on the thermostat. If that is ok, the thermostat could be bad because it is a temperature controlled switch that turns the compressor on or off.
Jun 14, 2014 | Smeg FAB28QR1 Retro Fridge with Freezer...
True T-49 refrigerator/freezer temperature calibration
Contact the manufacture, it is most likely going to be covered under warranty. If the knob is not removable, (check for a set screw on the side of the knob it will take a small allen wrench) Then the thermostat (temp controller) will need to be replaced, if it isn't a style that you can calibrate.
Jan 30, 2014 | True Refrigeration True T-49 2 Door Bottom...
How to replace thermostat
This all depends on the type of fridge. I had a problem with my fridge/freezer and it need a new thermostat.FIRST UNPLUG THE APPLAINCE FROM THE WALL SOCKET. Basically you need to get access to the thermostat and many models the control knob is on the inside and on some its outside on the top. You need to first undo the end where the capillary tube ends then remove the control knob. There is usually a nut holding the thermostat, remove that and also remove the electrical connector and simply pull until the whole of the capillary tube is out. Refit the new one in reverse order.
Feb 19, 2013 | Refrigerators
Freezer is good. Fridge is not cold enough. It is on 7. MTF2195
Refrigeration half of fridge does not have a cooling unit. It gets its cold from the freezer. There is a door between the fridge and the freezer which is controlled by the fridge temperature control knob. Often times the connection is purely mechanical. There may also be a fan to push the air through the door which is controlled by the fridge temperature knob which is actually a thermostat.
Jun 11, 2011 | Maytag MTF2195 Top Freezer Refrigerator
Replacing a fridge thermostat of a Smeg FC40RX fridge freezer
May 12, 2010 | Refrigerators
My Samsung Freezer isnt working but the fridge is fine
without checking equipment you can only assume things that may go wrong...1st..try fully defrosting complete unit,clean all vent/drain holes then switch back on and let unit do its thing for 24 hours.then check temperatures are minus 18-20c for freezer and plus 2-5c for fridge (approx)unless you have electrical meters to check, this is just about all you can do..
Feb 19, 2010 | Samsung RS2630SH Side by Side Refrigerator
The refrigerator ignores temperature setting.
Hello, This problem is going to be the cold control/thermostat, this part can be located in the control console inside the fridge bhind the freezer temp control knob (can also be found sometimes in the freezer depending on type/model) The reason your food in the fridge is freezing is because the thermostat controling the freezer temp is not shutting down and the air being blown into the fridge is too cold. Replace this cold control/thermostat and you should be fixed. If you have any other questions or concerns please feel free to comment again and give me some time to respond. Good luck! Mike
Sep 08, 2009 | Kenmore Refrigerators
After cleaning coils and in back of fridge, it appears that the defrost keeps cycling every 5 minutes
hi
Step 1:
 If the compressor runs all the time, turn the control knob to the OFF position. If the compressor still runs, unplug the unit, then pull off the control knob and remove the screws holding the thermostat in place. Pull out the thermostat and remove either the red or the blue wire from its terminal. Plug in the unit. If the compressor doesn't run, the thermostat is faulty. Replace it with a new thermostat.
Step 2:
If the compressor runs after the wire is removed from its terminal, there is probably a short circuit somewhere in the unit's wiring. In this case, don't try to fix the problem yourself; call a professional service person.
Step 3:
If the refrigerator or freezer runs but the box doesn't cool, unplug the unit and remove the thermostat with a screwdriver. Disconnect both wires from the thermostat. Tape the ends of the wires together with electrical tape, and plug in the appliance. If the refrigerator starts and runs normally, the thermostat is faulty. Replace it with a new one of the same type. Connect the new thermostat the same way the old one was connected.
Step 4:
If the freezer compartment is normal but the refrigerator box doesn't cool, set the dials that control both compartments to mid-range. Remove these knobs (they're usually friction-fit). Then unscrew the temperature control housing; you'll see an air duct near the control. Replace the knob on the freezer thermostat and turn the control to the OFF position. Open the refrigerator door and look closely at the air duct. If this duct doesn't open wider in about ten minutes, the control is faulty. Replace the control with a new one of the same type. Connect the new control the same way the old one was connected.
Oct 10, 2008 | Amana ARB2557CW / ARB2557CB / ARB2557CC...
I have a 2 year old SMEG FAB 32 Fridge/Freezer and the freezer section has suddenly lost temperature. Upper frdige section is fine but freezer not. I have emptied, kept door shut, turned dial up but no...
I have a 2 year old SMEG FAB 32 Fridge/Freezer and the freezer section has suddenly lost temperature. Upper fridge section is fine but freezer not. I have emptied, kept door shut, turned dial up but no success.
Any suggestions on what the problem might be?
Wouldn't expect problems on a SMEG just 2 years old.
You could have a bad thermostat or the refrigerator could be low on Freon, make sure you clean off the exposed coils on the back of the fridge and underneath to free it from dust and dirt – use some type of a blower for underneath and the coils you can vacuum off or wipe off the coils, if not call a service tech to have a look @ the refrigerator – it might have a bad compressor
Apr 14, 2008 | Refrigerators
Radio Communications Logo
41 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
