Question about E-Machines eMachines Desktop PC
T3624 will not power on
Came home from a weekend trip.
Computer had been working fine, now I push power button and nothing happens.
monitor, printer, scanner, etc. works fine just cpu will not power up.
Any ideas
  • E-Machines Master
  • 32,281 Answers
Does the power on LED light up, if not check the power lead, make sure it is connected properly. If you still don't get a power when you try to boot up and the power LED isn't on then you most likely have a faulty switch mode power supply.
Posted on Jun 15, 2009
My aspire ast180-ea 350b won't power on
This sounds as though the power supply unit within the desktop has failed.
You should be able to buy a standard replacement from your local computer repair shop.
Dec 10, 2013 | Acer Aspire Computers & Internet
The monitor starts up and goes into sleep mode
After repairing the on/off button for $100.00 and then rehooking up the monitor to my pc, the monitor has power but stays asleep even when I push in the menu button, I can't get anything to happen. HP techs tell me that the problem is with my computer although it worked perfectly fine before I unhooked all to send out the monitor.
I hooked all back up again as before but now the monitor will only say "monitor going to sleep" and nothing happens.
Wishing I had a solution. Thanks
Sep 10, 2010 | HP f2105 21" LCD Monitor
Working fine till yesterday. When shutdown
Open up the set and look for bad caps, see some failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 11, 2010 | Gateway FPD1760 Monitor
Emachine T3624 will not power up
Emachines are notorious for having faulty power supplies. If your lucky you just need to replace the power supply. I've seen a lot of them where the power supply also fried the motherboard.
Please don't forget to rate this solution.
Jun 15, 2009 | E-Machines T2984 PC Desktop
Cannot turn off monitor
It is problem with power settings. Start/Control Panel/Power Options -- and then pick a Power Scheme from the drop down list and make whatever modifications you want to the settings that power down your monitor
Feb 28, 2009 | Dell E196FP 19" LCD Monitor
Hyundai LCD monitor L70N Stuck in sleep mode?
push and hold the power button... then hit the settings button on the monitor and goto power>sleep mode
Jun 17, 2008 | Hyundai ImageQuest L70N 17" LCD Monitor
Power Issue
sounds suspiciosly like your chord fitting is damaged(loose wires at connection)and shorting.if possible try a friends power supply with same connecter type before renewing cos could be faulty(loose)connection at pc(inside)constant pushing and pulling of connections often causes 1. loose split or disconnected wires at male connection or 2.loose pins on motherboard female connection or broken housing (not difficult to repair)more difficult to find out how to get to internal connection.
Mar 04, 2008 | Toshiba Satellite M65-S9092 Notebook
LCD Monitor will not switch input selections
NOTE: You can also lock or unlock the OSD by pushing and holding the Menu button for 15 seconds. In this mode All buttons will be locked including the "Menu" button. You can unlock by pushing and holding the Menu button for 15 seconds.
Reference:
http://support.dell.com/support/edocs/monitors/2005FPW/En/setup.htm#Using%20the%20OSD
Oct 16, 2007 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
