Question about Rug Doctor Mighty Pro Mpc2c Carpet Cleaning Machine
NOT SPRAYING WATER - Rug Doctor Mighty Pro Mpc2c Carpet Cleaning Machine
Hi I have a nilfisk alto that has not been working properly. It has not been spraying the water
Alto nilfisk vaccuum is not spraying water , a highpressure washer do you mean not a vaccuum .
But If it's an alto nilfisk blue pressure washer on the vaccuums topic it must be the bypass / autostop on the pumphouse its internally a point where a microswitch is placed and depends on the type of washer by a problem with the parbak ( a parbak is a oring/ with auxiliary kevlar ring(s)) that can hang on lime, but on an other model there are 2 springs on the bypass and one of them the great spring is broken or only hanging on lime but thats rare if it is.
I don't know if there are vaccuums with water spraying only for remove dust.
Feb 15, 2017 | Nilfisk Vacuums
Bissell 9500 spraying solution but not water
Hey, sorry to hear the spray isn't working on your machine.
Here's a quick link to the complete troubleshooting steps for no spray for your machine.
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Feb 13, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
Water won't stop spraying water 9400 bissell
Hey, you may want to have a Qualified Technician at a BISSELL Authorized Service Center inspect your machine.
Here's a quick link to locating one of our Authorized Service Centers in your area.
http://www.bissell.com/service-centers/?cid=ccsocial
Jan 27, 2013 | Bissell ProHeat Turbo Deep Cleaner Upright...
Windsor fiber pro 20 Betco extracter not spraying out enough water
clogged nozzel run some hot vinegar through it... then some plain water. (do this in a dry bathtub.)
Dec 29, 2012 | Vacuums
My bissell stops spraying water, carpet not wet
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
rtetrhgd
May 30, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Bissell Proheat is not spraying water. What is causing this? and will it be expensive to fix?
It is very simple and inexpensive to fix. All you need to do is replace the pump belt. Here is the belt you need:
Bissell Proheat Pump Belt
May 20, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell Proheat Clearview water problem
The water comes out the hose at the same time. The diverter only diverts the suction from floor to attachment. If it is constantly spraying there is a problem with the attachment. Is it not spraying on the floor?
May 17, 2008 | Bissell 1699 ProHeat Clear View Upright...
Rug Doctor Mighty Pro Mpc2c Carpet Cleaning Machine Logo
Top Rug Doctor Vacuums Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Rug Doctor Vacuum Expert? Answer questions, earn points and help others
