Question about eMachines E Machines Et1831-07
How to take apart a ET1831-07
How do i open the case
Pisen USB Hub burned out and wont work
Look for a seam around the case, scrape the plastic until you can pry it apart. This usually results in destroying the case and quite messy and sometime even dangerous (sharp knife, unprotected hands, slippery surfaces). From my experience liking to take things apart, and being a major Band aid user, its not worth it.
If it s done for, you might as well use a large screwdriver and force it apart from where the wires go into the case. It cant be repaired, get a new one.
Mar 30, 2014 | Generic Pisen Multi Purpose USB Hub, White
How to open an LCD monitor.
I personally haven't worked on this monitor, but most monitors are held together with plastic clips on either side of the casing.
After removing the stand and all other screws, you will need to use a small flat-head screwdriver (or something of that nature) to pry apart the clips. Find the crease/gap in the plastic where the casing of the monitor comes together. Insert the screwdriver and gently twist and pry the casing apart. When you hear the first click/snap indicating the first clip has come apart, follow the gap with the screwdriver, prying it apart each time you reach an area of resistance. Do this all the way around the monitor.
Keep in mind that after you open up all the clips, the LCD panel and boards may be screwed either the front casing or most likely the back casing. So you must first unscrew the mounting screws inside the monitor to remove the back cover. Also be careful unhooking ribbon or speaker cables that attach the circuit boards of the monitor to the front casing.
Jan 12, 2010 | Gateway FPD2275W LCD Monitor
Cover to usb port wont close
To fix this, you'll have to take the case apart--the plastic guides have apparently come out of place in the case.
You may be able to put them back in place, but it will be a tedious job just because you have to take the case apart.
Jun 24, 2009 | Dell Dimension 8200 PC Desktop
Inside of PC is extremly dirty!
There should be a gray button type thing on the top of the back end of the case and the bottom. You will need to push both in at the same time to get the case open. Push both in and slide the case apart. I found that having somone pull the case apart while i push on the buttons is easier.
Let me know if how it goes.
Regards
Dec 13, 2008 | Dell Dimension 2400 PC Desktop
Changing casing
you need t6 screw driver to open all screw before you can open housing
Aug 15, 2008 | Nokia N95 Cellular Phone
Opening to find UBS
it should just pull apart to open. grasp recorder from both ends and pull apart
Aug 02, 2008 | Olympus WS-100 Digital Voice Recorder
ITT Mariner 160 - How to open the case...
this unit is siliconed together to make it waterproof and outer ring on eye piece is glued on after assembley you have to pry casings apart with knife ect not easy but they do come apart without damaging internal parts make sure you also remove casing screw under label as well i have dissasembeled about four of this model succesfully
Wayne
Jan 16, 2007 | ITT Night Mariner 160 Monocular
How to open case?
***THIS MAY NOT BE THE CORRECT ANSWER, IM SHARING MY EXPERENICE*** Well, i have same MP3 player, and i dropped it going about 25 on a bike, and it pretty much all came apart, so im assuming it's glued, and clipped together,
Aug 12, 2006 | SanDisk Sansa e130 MP3 Player
eMachines E Machines Et1831-07 Logo
Top eMachines Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
