Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
Kenmore upright turn on but cut off with out warring
Run hot
I have a Kenmore Progressive and it will not turn on can you help?
Is it hot when it shuts down the filters may need to be cleaned often,see if this works for you wait for it to cool it may take a few hours.
Aug 29, 2010 | Kenmore Progressive Bagless Upright with...
Machine cuts out due to getting hot
most vacuums have a heat resister in when they overheat they cut out, this is normally because they are full up, got a blockage or the filters need cleaning, suggestions are, clean filters, empty and check for blockage.
Jul 13, 2009 | Dyson DC07 Allergy Blue/Turquoise Bagless...
Hot Smell when I run it
Check to make sure there is no hair on the ends of the axel. Hair will sometimes wrap up around the axel and make it hard to turn. Cut off with razor and place a drop of oil on the ends.
May 08, 2009 | Hoover Fusion Plus Cyclonic Upright Vacuum...
I HAVE A KENMORE 34612306 UPRIGHT VACUUM. IT SEEMS TO OVERHEAT AND STOP AFTER USING FOR 20 MINUTES OR SO. ANY POSSIBLE SOLUTIONS??
the filters may be clogged causing the motor to run fast which is causing the motor to get too hot..make sure you don't have any clogs anywhere like your hoses or at the bottom
Apr 12, 2009 | Kenmore Vacuums
Kenmore upright model number 86039259990. The
don'thave to smell, the belt just snapped in half.unplug the vacuum and try to turn the brush roller by hand,if it turns real freely the belt is broke.it should be kind of hard to turn by hand if the belt was good
Mar 04, 2009 | Kenmore Progressive Bagless Upright with...
Kenmore bagless upright Model # 116.35726401
There is actually an internal fuse in the vacuum. You may have blown this. The circuit board connected to the ON/OFF touch pad may be bad too but probably unlikely. There is also an overheat sensor that trips the vacuum off when it gets too hot. This could be bad preventing it from coming on too. All of these solutions, require you to open the vacuum to fix.
Sep 25, 2008 | Kenmore Progressive Bagless Upright with...
Dyson
the automatic cut out switch on the motor needs replacing when the motor gets hot this switch comes in and stops the motor from overheating when the motor cools down the cleaner will work again and cut out again when the motor gets hot if it is not replaced it will eventually burn the motor out after the switch has been replaced both the filter and cyclone need to be cleaned on a regular basis or the same will happen again
Sep 04, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
It just turned off
Could be the cord, overload protector for the motor, or the motor itself.
Mar 15, 2008 | Kenmore 34721 Upright Vacuum
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
12 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
