Question about Juicelady JL500 Juice Extractor
It won't work. Have I put it together incorrectly?
The motor is working, but the metal juice cup isn't going around. Did I put it together incorrectly? I know I have all the parts in the right position.
My juicer is about 10 - 12 years old and still works okay but lately when I am juicing it sprays juice everywhere from around the top and leaks out the bottom of the blade piece. Is it just wearing out?...
You might have been able to find a replacement seal for the top but if the bottom is leaking that means the seal is gone there as well and that means replacing the container. The real problem is finding any of these. And when you do the cost is going to be as much as a new unit.
I'm afraid the best advice is to replace the entire unit. The only thing is to make sure you buy a quality unit if you want to get any useful life out of them. A cheap unit is going to start leaking within a year or two (about 30 seconds after the warranty runs out) a good unit will give you hopefully another 5-10 years of use.Might cost more now but you won;t have to replace it that quickly either.
Feb 01, 2011 | Breville JE900 Juicer
Motor is humming not working .. stoped in between juicer
it is jammed, or it is too full....stop, take apart, scoop out pulp, put back together and restart. go slow when juicing...too fast will jam it!
Jan 07, 2011 | Jack Lalanne Power Juicer (Stainless...
WONT RUN
is it all put together? if if is not all put together properly it will not power up. if the whole thing is put back like the picture and it doesn't work perhaps it is your motor?
Jan 03, 2011 | Champion G5NG853S Household Juice...
I purchased a Hamilton Beach juice extractor, Type CJ01, Model 395W from a thrift shop. No manual available. How do I remove the circular blade cup to clean?
The solution i have found is relatively simple, but going to take a bit of handy work.
first, it would greatly help to remove the bottom from the unit. You will need to remove the 4 rubber pads, and then the 4 screws. 2 of the screws are way up there and need a thin philips.
Regardless if you removed the bottom, you will need to drill a hole right in the center of that circular grill on the bottom piece.
If you did NOT remove the bottom piece, I would take a nail, clamp it with vice grips, get it red red hot off the burner, and burn away that center plaster to create a hole. So whether you drilled the hole (with the bottom removed) or burned the hole (with the bottom intact), you will see the bottom of the motor has a slot head.
Now, all you need to do is take a thin blade screwdriver, or thin butter knife into that slot, holds the motor, then twist the blade right off...or on...whichever the case may be.
Hope this helps...sure helped me!
Oct 30, 2010 | Hamilton Beach 67800 HealthSmart Juice...
I HAVE AN OLDER KRUPS JUICER TYPE 251. IT SAYS IT IS MADE IN SWITZERLAND. THE METAL HANDLE WHICH KEEPS THE TOP ON TIGHT IS LOOSE. THE SPRING HAS FALLEN INTO THE BOTTOM OF THE HOUSING. THIS MEANS IT CANNOT...
Did you ever find a manual? I have the same machine, working fine but I'd like to know if I should use the plastic strainer for all my juicing or just for certain fruits or vegetables.
Jul 18, 2010 | Krups Juice Extractor
I need direction manual
hello,
kitchen.manualsonline.com
instructables.com
wardappliances.co.nz
comparestoreprices.co.uk
the above site are site that you can down load the instruction for your jack Lalanne power juice
thank you .
Jul 12, 2010 | Jack Lalanne Power Juicer 250 Watts
Using the Citrus Attachment
CALL WARING AT 800 492 7464. MAY BE
SOME TYPE OF SAFETY CUT OFF. YOU
MIGHT ACTUALLY HAVE TO ATTEMPT
JUICING AN ORANGE OR SO WITH THE
NEWER MACHINES.
Jun 25, 2008 | Acme 5001 Supreme Juicerator Juice...
Motor not working
Hi I had the same problem yesterday and emailed Champion Juicer about the problem here's their reply below, his suggestion worked. Hello Duane, Your machine is equipped with a magnetic start system which will only allow the machine to start when you have the screenholder all the way in place just as you would have it to start juicing. If you do not have any parts on the machine it will not start. Please assemble it again and give it a try. If it still wont start call me at 209-369-2154 for further assistance. Thank you Carl
Apr 16, 2007 | Champion G5NG853S Household Juice...
Champion Juicer stopped working
Nov 09, 2006 | Champion G5-PG-710 650 Watts Juicer
Juicelady JL500 Juice Extractor Logo
Top Juicelady Juicers Experts
Tom Chichester
David Payne
David Payne
Are you a Juicelady Juicer Expert? Answer questions, earn points and help others
