External power supply voltage for Stratitec USB Hub
DC voltage for Stratitec USB Hub serial number BGAB00065559
Benimur
  • 6966 Answers
SOURCE: lost power supply
If the desktop charger is the version that can accommodate two radios simultaneously similar to the T5000, then the AC wall adapter or the power supply is 9 volts AC.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 26, 2008
Geekman
  • 32281 Answers
SOURCE: Power supply for Targus 4 hub usb 2
Most USB hubs do not need an external power supply, except when a connected USB device draws more power than the computer/laptop USB port can supply. In this case an external power supply will need to be connected to the USB hub.
Normally this would be a 5 volt power supply, but make sure the polarity on the connector matches the power connector on the hub, check the label on the hub, sometimes it states to power requirements of the hub as well as the polarity on the connector. Normally the pin on the hub's power connector is positive (ie. +5V)
Posted on Nov 13, 2008
  • 4 Answers
SOURCE: 7 port usb hub
5V DC 3.7A  center + Adapter : )      Jay........
Posted on May 29, 2009
  • 11 Answers
SOURCE: What is correct AC adaptor for a Belkin USB Pocket Hub F5U007?
AC Adapter (100-240V, 50/60Hz)
Posted on Jun 25, 2009
  • 96 Answers
SOURCE: DC voltage
Could average around 12V I believe.
Posted on Feb 01, 2010
I have a nexxtech 7 port usb 2.0 hub which prevents boot to windows. Incompatible?
This hub is USB powered through your computer while you are using the first ports available. If you use ALL at once ports you will need to add the appropriate AC/DC external power adapter to supply the needed extra power.
Jul 03, 2013 | Computers & Internet
Usb hub heats up only when the external power is connected. It eventually fails. Removing the external power it works again. The external 5v measures corectly. Model # U222-004-R
There is a problem with an Ic on the board internally to the Hub. The
DC to DC converter IC inside the hub is defective, just replace the hub.
May 23, 2011 | Tripp Lite (U222-004-R) 4-Port USB Hub
What's the voltage output from transformer
hi YOU CAN FIND THE SOLUTION FOR YOUR HUB
Warranty Period : Lifetime Warranty Integrated/Included Cable Length : 1.8m Belkin Pro Series USB Device Cable LED Indicators : 1 x Power LED (Green), 4 x Port Indicator LEDs (Green) Max. Load Per Port : 500mA Package Contents : USB 4-Port Hub, USB Device Cable (A-B), User Guide, Power Supply Power Supply Specifications : 5 V DC 4 A (Provided) Option to Expand/Cascade : Yes, via Hubs of this design (stackable) or other Enclosure Type : High-Impact Plastic Enclosure
Sep 27, 2010 | Belkin ExpressBus Networking Hub
I replaced the USB adapter chord and know there's not enough power to run the drive. I think I need a DC adapter, 5V, 1A, that fits the drive.
If you get an error message "Insufficient power to operate USB device" when you plug in a USB device into the computer's USB port then this device is drawing power that the USB port can supply.
In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Dec 06, 2009 | SimpleTech SimpleDrive Portable USB 2.0...
USB port malfunction
CHECK THE RATING ON YOUR POWER SUPPLY BECAUSE SOME LAPTOPS WILL REGISTER THE POWER CONNECTION PORT AS A USB PORT AND IF YOUR POWER SUPPLY VOLTAGE IS TO HIGH FOR THE COMPUTER IT WILL REGISTER IT AS SUCH, "HUB-PORT" IS SHORT FOR MAINBOARD PORT ON SOME DELLS. UNPLUG YOUR POWER SUPPLY AND CHECK THE RATING ON IT COMPARED TO THE DELLS INPUT VOLTAGE, THE INFORMATION IS NEXT TO YOUR SERIAL NUMBERS AND LABELS ON BOTH PEICES KEEP ME POSTED... JON-T
Dec 07, 2008 | Dell Inspiron 8600 Notebook
Nov 13, 2008 | Targus PAUH217U 4-Port USB Hub
Problem connecting from usb to db9
There are serial port to USB adapters, but can't you use a USB cable by itself? You can find the adapters at cyberguys.com or milestek.com
Regards,
Worldvet
May 31, 2008 | Televison & Video
7 port usb hub
Dec 30, 2007 | Entrega (HUB-7U) Networking Hub
Computers & Internet Logo
137 people viewed this question
David Payne
David Payne
