Question about Kenmore Freezers
Replacement key for maytag freezer modle# 1552TEW01
DO YOU KNOW WHERE i CAN GET ONE
Is there a freezer thermostat that is compatible with this modle
Converting a refrigerator into a satisfactorily operating freezer is quite the difficult undertaking if possible at all. It would require much more than changing to a different thernostat that cycles the compressor at a lower temperature. The key word here is "satisfactorily".
Apr 02, 2015 | Danby Freezers
Hello, My name Zoltan, and I have a Maytag
Your defrost element has failed in the freezer, ice has built up in the freezer cooling cores and air cant pass through them to the fridge, you need to defrost the unit totally and replace the elements, they are at the inside rear, behind the plate, also check your internal fan is running in the freezer, could be another fault. Russ
Jun 26, 2011 | Maytag Freezers
Maytag upright freezer with self defrost. The water line freezes.
This sounds like your defrost heating coil has gon bad. Not much you can do but replace it. Please leave a good thumbs up for me for the effort. Pretty sure I'm correct on this one. The Raz Shack
Mar 11, 2010 | Maytag 20 cu. ft. Upright Freezer MQU2056B
Refrigerator not dispensing water or ice
repairs should be performed by a qualified technician. if there isn't ice in the ice bucket located in the freezer you have a water flow problem. if there is water going to the filter and nothing out of the freezer then you have a clogged freezer replace it. if these things are ok then yes it could be the electronic control. filter failure is a common problem.
Apr 29, 2017 | Maytag Freezers
My Maytag msd2756geb freezer is too cold.
You are probably right that it is always running. This is because the thermostat/sensor has gone bad. The fridge adjusts by a door that allows air to come from the freezer to the fridge side. Therefore this will still work...
You will need to replace or have the thermostat replaced....
Heatman101
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Feb 04, 2010 | Maytag Freezers
My freezer will not work all my food is spoiled. I donot know what to do? Compresor does not start,light is on their is power but will not freeze.
you may just need a new relay and overload
goto ww3.sears.com
do a modle search your parts is found rtight on the compressor itself
without knowing more this is where i would stasrt
Oct 08, 2009 | Freezers
Frigidaire modle ffu21f5hwb door handle loose how
Pop out the screw hole covers and tighten the screws.
Sep 16, 2009 | Frigidaire Freezers
I have a Maytag MSD2142ARW side by side and it has been steadily gettingwarmer on the fridge side. The freezer appears to be cooling fine and I know the fridge gets its cool from the freezer side. The fan...
HI, your Temperature Control Module has failed. it controls the air flow and vent(damper) action. replacing the temp control mod will fix this issue you are having at this time.
Jun 10, 2009 | Maytag Freezers
Freezers Logo
62 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
