Question about 2006 Ford F350 Truck Super Duty Crew Cab Power Window Regulator wit
Reservoir repair ford f 350 year 2006
Repair windshield washer container
    Sergeant:
    Champion:
  • 253 Answers
I would just get another one, junk yard or new
Posted on Aug 14, 2014
6.7l. How can I replace windshield washer pump?
The pump is on the bottom of the washer fluid container. Take out the bottle and remove the pump.
Mar 11, 2016 | 2011 Ford F-350 Super Duty
How do you replace the windshield washer pump on 2008 ford focus, wipers work but no spray comes out
The hose could be clogged ! Do you know where you add the washer fluid ? Somewhere on the bottom of that plastic bottle is the washer pump .
Removal and Installation
> WARNING: Windshield washer solution contains methanol, which is poisonous. Observe all cautions and warnings indicated on label of washer solution container. Failure to follow these instructions may result in personal injury.
> CAUTION: When replacing the windshield washer pump be careful not to damage the rubber grommet.
> CAUTION: Do not operate the windshield washer pump before filling the reservoir. Failure to do so could result in premature pump failure.
  1. NOTE: When installing the reservoir, the filler neck must be lubricated using a water-based lubricant.
    Remove the bolt and the windshield washer reservoir filler neck.
  1. Remove the RH fender splash shield. For additional information, refer to Section 501-02 .
  1. Remove the foam filler and remove the retainer.
  1. Remove the 2 screws and the accessory drive splash shield.
    • To install, tighten to 5 Nm (44 lb-in).
  1. Remove the nut, 2 bolts and position the A/C accumulator aside.
    • To install, tighten to 9 Nm (80 lb-in).
  1. Unclip the A/C lines from the inner fender well.
  1. Drill out the rivet and remove the bracket.
  1. Remove the 2 bolts, slide the windshield washer reservoir assembly forward to release it, and position the washer reservoir aside.
    • Install the upper bolt followed by the lower bolt, and tighten to 5 Nm (44 lb-in).
  1. Disconnect the windshield washer tube assembly from the pump and release the windshield washer tube assembly from the washer reservoir.
  1. Disconnect the electrical connector from the windshield washer pump.
  1. Release the wiring harness from the reservoir, and remove the washer reservoir.
  1. To install, reverse the removal procedure.
Apr 07, 2015 | Ford Cars & Trucks
Where is the windshield washer motor located? Is it near the heater motor? I had mine fixed and now the heat comes out of the dash for the defroster
Windshield Washer Pump Removal & Installation To Remove:
  1. Remove the air cleaner assembly.
  3. Position the pump and reservoir aside.
  4. Disconnect the electrical connectors.
  5. Disconnect the washer hose.
  6. Remove the pump and reservoir.
  7. Remove the washer pump.
WARNING
Windshield washer solution contains methanol which is poisonous. Observe all cautions and warnings indicated on label of washer solution container.
NOTE: Windshield washer fluid should be collected in a container after the windshield washer hose is disconnected.
To Install:
WARNING
  1. Install washer pump in reservoir.
  2. Install washer pump reservoir assembly.
  3. Connect washer hose.
  4. Connect washer electrical connector.
  5. Install air cleaner assembly.
The windshield wiper fluid pump is located in the tank which is not in the heater motor or defroster area in the dash.
The defroster/heat control door is located in the dash board area:
Air Door Actuators, Cables or Motors Removal & Installation Air Inlet Door Vacuum Control Motor To Remove:
  1. Remove the instrument panel lower insulator cover.
  2. Disconnect the vacuum connector.
  3. Remove the control arm clip and the spring.
  4. Remove the nuts and the air inlet door vacuum control motor.
To Install:
  1. Install the vacuum motor on the mounting bracket.
  2. Connect the control arm and spring.
  3. Connect the vacuum hose to the vacuum motor.
  4. Install the lower instrument panel lower cover.
Floor Defrost Door Vacuum Control Motor To Remove:
  1. Disconnect the negative battery cable.
  2. Remove the left lower dash insulator panel and disconnect the lamp.
  3. Remove the two pin-type retainers and remove the fill panel.
  4. Remove the DLC mounting screws.
  5. Detach the vacuum line.
  6. Remove the lighting module.
  7. Remove the screws and the bracket.
  8. Remove the floor/defrost door vacuum control motor.
Floor/Defrost vacuum motor mounting screws for-10-00-246.gif
To Install:
  1. Connect the vacuum lines and install the floor/defrost vacuum motor.
  2. Install the bracket and lighting control module.
  3. Install the DLC bracket and mounting screws.
  4. Install the fill panel.
  5. Install the left lower dash insulator panel.
  6. Connect the negative battery cable.
Panel Door Vacuum Control Motor To Remove:
  1. Remove the instrument panel.
  2. Reach through the door opening and remove the pin.
  3. Disconnect the panel door vacuum control motor vacuum line.
  4. Remove the screws and remove the panel door vacuum control motor.
To Install:
  1. Install the panel door vacuum motor.
  2. Connect the vacuum line to the panel door motor.
  3. Reach through the opening and install the pin to the linkage.
  4. Install the instrument panel.
Jan 19, 2011 | 2003 Mercury Grand Marquis
My windshield washer switch doesn't work on my 2006 Ford Focus.
Check for the fuse in the box if is blowed replace it if it is not this check your water reservoir under the hood if it is low fill it up.
Dec 17, 2010 | 2006 Ford Focus
I have a 2006 Toyota 4runner and I can not locate the rear windshield washer reservoir
The rear window washer gets its feed from the front reservoir. One reservoir feeds both windows.
Dec 11, 2010 | 2006 Toyota 4Runner
Replace windshield reservoir
Windshield Washer Motor REMOVAL & INSTALLATION 1987-95 Vehicles
  2. Drain or siphon the washer solvent from the reservoir.
  3. For 1987-91 vehicles, remove the brace.
  4. Unfasten the reservoir screws.
  5. Detach the electrical connectors and washer hose.
  6. If necessary, remove the reservoir from the vehicle.
  7. Remove the washer pump motor from the reservoir. Fig. 1: Location of the windshield washer fluid reservoir and pump - 1987-91 vehicles 89636g50.gif
    To install:
  8. Install the washer pump motor on the reservoir. Make sure the pump is fully seated in the reservoir gasket.
  9. Position the reservoir in the vehicle.
  10. Attach the electrical connectors and washer hose.
  11. Install the reservoir retaining screws.
  12. Install the brace.
  13. Fill the reservoir with washer solvent.
  14. Connect the negative battery cable, then check for proper washer pump operation.
1996-99 Vehicles
  3. Detach the electrical connectors from the washer.
  4. Disconnect the hose from the washer pump.
  5. Loosen the nut at the bottom of the washer reservoir.
  6. Unfasten the 2 nuts, then remove the washer solvent reservoir.
  7. Remove the washer pump from the container.
  8. If necessary, remove the solvent lever sensor switch from the washer solvent container. Fig. 2: Exploded view of the washer fluid reservoir, pump and level sensor 89636g51.gif
    To install:
  9. Install the solvent level sensor switch in the washer solvent container. The tab on the solvent level sender switch must be lined up with the slot in the hole.
  10. Install the washer pump into the reservoir, making sure the pump is pushed all the way into the container seal.
  11. Install the washer solvent reservoir and secure with the 3 nuts. Tighten the nuts to 44 inch lbs. (5 Nm).
  12. Attach the electrical connectors to the solvent level sensor and washer pump.
  13. Connect the hose to the washer pump.
  14. Fill the reservoir with washer solvent.
  15. Connect the negative battery cable, then check for proper washer pump operation.
Nov 09, 2010 | 1997 Pontiac Bonneville
How do I fix my window washer pump on my 2000 dodge caravan?
One can get a repair kit that includes a new motor pump and wiring clips, or
one can get the original motor that plugs into the windshield wiper fluid reservoir.
Windshield wiper reservoir (gives idea of how to change the windshield wiper fluid pump motor) Removal & Installation To Remove:
  1. Disconnect and isolate the negative battery cable.
  2. Raise and safely support the vehicle.
  3. Remove the right front wheel and splash shield.
  4. Disconnect the electrical connectors from the pumps and detach the rear washer hose.
  5. Place a drain pan under the reservoir if it contains fluid.
  6. Disconnect the front washer hose at the wiper unit in the engine compartment. NOTE: The front hose will be removed with the reservoir.
  7. Let the fluid drain from the reservoir.
  8. Remove the mounting screws and the reservoir.
To Install:
  1. Install the fluid reservoir with the mounting screws.
  2. Connect the front washer hose in the engine compartment.
  3. Connect the electrical connectors and rear washer hose.
  4. Install the splash shield.
  5. Install the right front wheel.
  6. Lower the vehicle.
Aug 27, 2010 | 2000 Dodge Caravan
Windshield washer fluid reservoir - MB ML 350
right where the lines connect to reservoir, has little black seals that leak. I recommend removing reservoir, empty it out, then use RTV silicone and place it between seals and reservoir. Let it dry for FULL day. than reinstall.
Jun 23, 2009 | Mercedes-Benz ML350 Cars & Trucks
Wash wipe on a Focus 2000 model
I blieve it's the same pump taht runs the rear and front washers.
The windshield washer comprises the following parts:
  • Windshield washer reservoir, below the front left-hand fender
  • Washer pump, on the outside of the washer reservoir
  • Two washer nozzles on the hood/bonnet, adjustable.
Windshield Washer Pump and Reservoir Removal
All vehicles
  1. Remove the windshield washer reservoir filler neck.
  1. Raise and support the vehicle. For additional information, refer to Section 100-02 .
  1. Remove the right-hand fender splash shield (wheel shown removed for clarity).
  1. Remove the washer reservoir.
    • Disconnect the electrical connectors.
    • Pull off the hoses.
  1. Remove the windshield washer pump with rubber gasket (shown with reservoir installed).
    1. Disconnect the electrical connector.
    1. Disconnect the hoses.
    1. Lift out the pump.
Feb 27, 2009 | 2000 Ford Focus
Wiper fluid level sensor replacement
Reservoir —Windshield Wiper
Removal
  1. Remove the RH wheel; refer to Section 204-04 .
  1. Position RH splash shield aside.
    1. Remove six screws.
    1. Remove three pin-type retainers.
  1. NOTE: Windshield washer fluid should be collected in a container after the windshield washer hoses are disconnected.
    Disconnect the electrical connector and washer hoses.
  1. Remove the upper reservoir bolt.
  1. Remove the windshield washer reservoir.
    • Loosen the two lower reservoir bolts.
Jan 15, 2009 | 2000 Mercury Villager
2006 Ford F350 Truck Super Duty Crew Cab Power Window Regulator wit Logo
55 people viewed this question
Top 1A Auto Parts Vehicle Parts & Accessories Experts
Mike Stager
Mike Stager
Jesse Walters
Jesse Walters
Are you a 1A Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
