Question about Intertherm 56000 Btu Gas Furnace
Intertherm furnace manual
WON'T FIRE UP
    Top Expert:
  • Intertherm Master
  • 3,698 Answers
Www.intertherm.net/
Posted on Aug 03, 2014
I have a Intertherm furnace model# MGH-065-ABRN-05...The target burner needs to be replaced. I type in my model # and it isn't reconized. Is this a good number. Thank You
I don't think that is a good model #. Here is a link to their site and the furnace models there have a totally different type of #.
http://intertherm.net/Products/Furnaces/GasFurnaces.aspx
If you really need the burner, Id call Intertherm and then they can tell you what data plate you should be looking at.
http://intertherm.net/DealerServiceLocator.aspx
Jan 02, 2018 | Intertherm Heating & Cooling
I HAVE A MODEL UFG-101AG-4 SERIAL # 800H2 INTERTHERM FORCED AIR FURNACE FOR MOBILE HOME OR TRAVEL TRAILER THAT I DONT KNOW WHATS WRONG WITH IT?
OK. Let me answer you, even if honestly I don't have any idea about an INTERTHERM FORCED AIR FURNACE. To get any answer, to a problem, you should describe your problem. Just telling that you don't know what's wrong with it is simply no enough information, even for a star expert in your INTERTHERM FORCED AIR FURNACE.
Jun 25, 2015 | Intertherm Heating & Cooling
Manual for model C7BAM03648C-C
According to the web, the model C7BAM03648CC is a Westinghouse refrigeration unit. Are you sure you didn't get the number from the top portion?
C7BAM Cased Vertical Coil
• R410 refrigerant-non-ozone depleting
• All aluminum micro-channel coil eliminates formicary corrosion
• Piston metering for all 13 SEER matchups
• Field installed TXV accessory for 14 SEER matchups
Recent Intertherm furnaces have "M" or "CMF" numbers.
Either way, you will probably have to contact a local dealer because their website is useless.
Intertherm Gas Furnaces
Mar 19, 2015 | Intertherm 56000 Btu Gas Furnace
Intertherm gas furnace in mobile home..igniter comes on then nothing tries to fire byrners but nothing
by igniter I assume you mean the thermocoupler. are you turning the control button to run after you light the pilot light? Normally when those furnaces quit it is the thermocoupler that has quit. Get a new one and leave it in the furnace compartment as a spare.
Jan 06, 2015 | Intertherm Heating & Cooling
INTERTHERM NO HEAT OR BLOWER
This could be failure of the igniter and/or thermocouple.
Jan 27, 2014 | Intertherm 56000 Btu Gas Furnace
Vanderhoof BC Canada
http://www.intertherm.net/DealerServiceLocator.aspx
Jan 08, 2014 | Intertherm 56000 Btu Gas Furnace
Intertherm furnace M1BG wont fire
Make sure the gas valve is turned to the ON position after you had it in PILOT position. Also check the thermostat low voltage wiring @ furnace...jumper the Red & White wires to bypass the thermostat temporarily. Make sure there is 24 volts on you low voltage circuit.
Dec 16, 2013 | Intertherm P3RA-048K Air Conditioner
Intertherm furnace model # MMHB-070ABHR-06 red light blinks two times
Number of flashes mean different things for diff models. The meanings of those flashes should be posted somewhere on the unit; usually inside front of the bottom service panel. Though you can't truly diagnose a problem by number of flashes they can give you an idea of where to look for a problem. There are a ton of videos and how-to's about furnaces on youtube by real service techs. Most modern furnaces have basically the same set-up and features so don't worry about your paticular brand; but of course that would be the best place to start looking. You could start here to familiarize yourself with your brand of furnace:
http://www.youtube.com/results?search_query=Intertherm+Gas+Furnace+&oq=Intertherm+Gas+Furnace+&gs_l=youtube.12...62316.62316.0.63907.1.1.0.0.0.0.202.202.2-1.1.0...0.0...1ac.Ko9QBdxK6OM
And then here:
http://www.youtube.com/results?search_query=gas+furnace+won%27t+light&oq=gas+furnace+won%27t+light&gs_l=youtube-reduced.3..0.5619.10061.0.11544.11.5.0.6.6.1.741.1982.0j1j2j5-1j1.5.0...0.0...1ac.1.5-0zJyxNMEo
Hope this helps.
Dec 21, 2012 | Heating & Cooling
Looking for an operatios manual for intertherm downflow gas furnace model MGHA056
Here's the closest thing I could find. It's a technical manual that shows all of the specifications, parts and ratings for the furnace. Hope it helps you.
http://www.intertherm.net/Literature/712a.pdf
Mar 08, 2011 | Heating & Cooling
Intertherm Furnace Will not stay on
possible dirty air filter low air flow causing high temp in fire box to trip limit switch or fan motor is bad hope this help let me know if you if this solved problem I may need more info
Jan 04, 2009 | Intertherm P3RA-048K Air Conditioner
Intertherm 56000 Btu Gas Furnace Logo
610 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
