Question about Dell A940 All-In-One InkJet Printer
My Dell A940 will not feed my paper anymore. All you hear is the little gears running. Than it asks you to load paper? What can I do to fix this?
    Problem Solver:
  • 12 Answers
Make sure that there is nothing in the paper tray can blocked the way out
Posted on Jun 22, 2009
HP 1315v Printer Makes grinding noise and won't feed paper anymore
It sounds as though a sheet of paper or an envelope bunched up and has jammed inside. Until that is removed from the feed roller, you will continue to hear the 'grinding' sound, and won't be able to print anything. Remove the cover from the backside of the machine, then locate and remove the obstruction. If you don't have any such obstruction then you have a mechanical defect which is not user repairable.
Oct 20, 2014 | HP PSC 1315 All-In-One InkJet Printer
Paper feeding problem
Sounds like the rollers may need to be cleaned, take an older rag and wipe down everything and also check for jammed paper in the printer.
Let me know how this goes and if this doesn't fix it, then we can see what else could be wrong
Jun 05, 2008 | Dell A940 All-In-One InkJet Printer
The paper feeder wont do it's job,will not feed paper . Makes loud noise but no action, then screen asks to load paper.
The feeder on this model has 1 weak mounting place for the gears that drive the feed roller. The plastic stud that holds the gear will break off of the frame and cause the noises you hear and no paper feed. The only fix is to replace the sheet feeder assembly, about $30.00 for the part.
Feb 21, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Dell A940 printer will not pull down,or start
I got it fixed........But if I told you how...I would need to charge you $6.95 per month.
Dec 24, 2009 | Dell A940 All-In-One InkJet Printer
What does load mpf mean
It does stand for Manual Paper Feed.
On this printer, that's on the front of the unit, above the paper trays.
Once your PC has sent a print job with the paper-select set to "Manual Paper Feed" the printer will not do anything until it's processed this job.
The easiest way to do this is to put paper into the MPF and let it print, but at some point you're going to want to fix your PC so it doesn't send MPF print jobs anymore.
To do this, open your Printer Properties and select the default paper tray instead of the Manual Feed.
Sep 25, 2009 | Dell 3010cn Laser Printer
The papaer is not feeding well on both sides therefore it sticks during printing.The right side of the paper feeds quickly and stiks. I have a dell all in one A940 Thanks Undine Wooding
looking at the pictures i would say the paper feeds in from the top turn the printer upside down and shake it there could be something fallen in there and is cause the paper not to feed on the one side.
Sep 02, 2009 | Dell A940 All-In-One InkJet Printer
Paper feeds to the right and Jams
Sounds to me like there is something in the paper chanel, a staple, paper clip or something small enough to get in there. Have you tried turning the printer upside down and lightly tapping the side to see if anything falls out?
Mar 14, 2009 | Dell A940 All-In-One InkJet Printer
Power light blinking but cannot switch on
Usuall the power light will blink if the paper fails to feed or is out. After putting more paper or straightening the paper out after a miss feeds, you usually have to press the on/off button so the printer will recycle and start printing.
Hope this helps. Bud
Jan 10, 2009 | Dell A940 All-In-One InkJet Printer
A940 doesn't feed paper correctly
My DELL A940 printer used to jam every time with the paper pulling to the right.
Solution - there was a pen jammed in the mechanism !
I was about to trash the printer when I looked deep into the workings from above, holding the printer to the window to get bright sunlight into it. I could see a round ballpen laying in the groove at the bottom.
Hooked the pen out and all is back to normal.
This may not be your problem, but its worth a look.
Dec 26, 2008 | Dell A940 All-In-One InkJet Printer
Dell A940 All-In-One InkJet Printer Logo
77 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
