Question about Nicor Dryers
Three globe nicor fan
Need new globe
2 Suggested Answers
sean1dave
  • 7 Answers
SOURCE: Need white translucent globe for
I believe Harbor Breeze is sold through the Home Depot. Any well stocked Home Improvement store will carry a great selection of replacement globes for your light.
Posted on Mar 07, 2011
Change bulb in ceiling fan model #40934. Was following instruction to push on globe then slight counter clockwise turn isn't working. Heelp
Hey Jennifer,
Look closely at the base of the globe.. there is (usually)(three of these).. a small groove(s) that make a 90* bend ..these grooves mate to the three screws on the side of the fan's globe socket,, the screws have to be backed out a little to allow the globe to seat and the screws guide the globe in place, once the globe is in place then retighten each screw a little at a time until the globe is tight
Sep 19, 2017 | Dryers
Harbor Breeze Portes ceiling fan. How do I replace the lamp?
Check a home-depot store, if you see a similar fan, ask for the sales person to show you.
Jun 26, 2015 | Dryers
Need white translucent globe for Harbor Breeze Ceiling Fan to cover light. Globe fits to fan base with 6-1/4" Inside diameter mounting ring and is secured with three thumb screws.
Mar 07, 2011 | Vacuums
How do I get to the lights to change the bulbs?
I don't know what your fan looks like, but if it has a solid glass bottom on it, the glass will rotate off, usually counter clockwise. Push up gently on the glass, and turn, should come right off.
Mar 31, 2010 | Nicor 52HAMSW Hamilton Sienna Wash Ceiling...
Light bulb replacement in ceiling fan. Hampton Bay with a solid globe (no hole in middle) - how to remove globe?
Look for three or four small thumbscrews around the metal rim that holds the globe. Unscrew each several turns while holding the globe with your other hand underneath to keep it from dropping out. You should not have to remove the screws completely. Just loosen them all enough to remove the globe. If there are no screws then the globe may twist into the rim light a light bulb. Hold the fan housing steady and turn the globe counter-clockwise to unscrew it. If it turns but does not unscrew then there are probably screws holding it as first described. They may be flush with the rim and you may need a small screwdriver or Allen wrench to unscrew them.
Oct 16, 2009 | Dryers
Bulb replacement 0 how do you get the glass cover off?
Les:
The globe is held on by three metal tension clips holding the globe to the base. To remove the globe, you need to pull down on the globe gently but firmly. Try pulling down on one side and then the other, sort of "wiggling" the globe off. Getting the globe back on can be a bit of a challenge, calling for you to get all three clips aligned in place before pushing the globe back up. A little patience and the job will go smoothly.
Hope this helps. If it does, please leave feedback! That is the only way I know if I am being of assistance or just wasting my time.
Oct 10, 2009 | Westinghouse Turbo Swirl 78145 Ceiling Fan
The globe turns but not screw out. How do I
Oct 07, 2009 | Westinghouse Turbo Swirl 78145 Ceiling Fan
Need new globes on lights
Go to lowes or home depot as both places carry replacement globes in stock. They can also special order for you. Bring in one of the old globes to be sure you get a perfect fit.
Apr 28, 2009 | Westinghouse Helix 78794 Chrome Finish...
I can't remove the globe to replace bulb in the ceiling fan. I removed the 3 screws but I can't tilt the globe.
My fan has no screws. You simply twist and tug the globe (firmly but easily) and find that it is held on by three "tension clips" that hold the thing in place.
If you are nervous, have someone else get on the other side of the ladder and hold the fan steady while you twist/tug the globe with two hands.
I did it by myself but I would have liked another pair of hands holding the fan steady while I gently but firmly tugged at the globe.
Jan 19, 2009 | Westinghouse Turbo Swirl 78145 Ceiling Fan
Removing the globe for put bulb in
I found on mine that the bulb is held in with 3 tenshion clips. You just have to pull the globe down slowly to gain access to the light bulb.
Sep 03, 2007 | Westinghouse Turbo Swirl 78145 Ceiling Fan
Dryers Logo
16 people viewed this question
Top Nicor Dryers Experts
Dan Webster
Dan Webster
Are you a Nicor Dryer Expert? Answer questions, earn points and help others
