Command ic 8823cpng5kg5
If,replaced, can tv get normally programmes or through service mode to be programmed
3 Suggested Answers
vortash
  • 431 Answers
SOURCE: service mode
Hi I am Vortsh sorry dont know how you activate this but I do know where you might be able to download the service manual for it .. at http://www.eserviceinfo.com hope this helps Regards Vortash
Posted on May 18, 2009
gopakumarg43
  • 74251 Answers
SOURCE: service menu mode
You should first check the output voltages comes out from its main power regulator section; and to rectify the cause of this shut down first. Then only, there is any need to enter its service mode. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window. Service mode entry, adjust and exit procedure to many brand TVs are given in detail.
Posted on Oct 30, 2013
Proscan Modle 37LG30S60 My normal Tv menue is randomly popping up and covering the program I'm currently watching.
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
May 18, 2017 | Proscan Televison & Video
My logik tv keeps reverting to dvd channel and just whirring round and round you cant turn it back to the normal tv channel
Main system control memory IC fault. Do a reset to this set and check. If it do not help you, contact any service technician to replace this IC. To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Oct 03, 2014 | Televison & Video
Sony bravia kdlv32a12u lcd tv. tune every time I switch tv on. Any ideas?
It sounds that the digital system control memory IC at the digital tuner section is faulty. Try a reset to this set, and check first. If it do not help you, replace the IC. Contact any service technician.
Sep 17, 2014 | Televison & Video
My tv is changing channels it self
The memory IC to your TV is faulty. Check and replace it. This is an eight solder terminal IC, can be located very near to main system control IC. Even though physical size to this IC is so small, function to it in circuit, when the TV works is great. You must have thofough knowledge in electronics to do this work, because, you might have to enter its service mode option to do some adjustments. This work is very skilled one, as service mode option window, and normal user window are entirely different to each other. Adjusting wrong data value to service mode options might make the TV irreparable, and irresponsive.
Jul 04, 2012 | Televison & Video
How to unlock ASM in SANSUI SV-2010K
Hello
Universal remote codes for Sansui TV with RCA RCR311B remote control are:
1020, 1054, 1133, 1145, 1167, 1230
But I really don't understand to what do you mean by this ASM lock. ASM [Automatic Search Memory] is meant for tuning fuction. When we put the set to ASM mode, it should search all the available programmes at that time at appropriate chanels, and will stop; must stop; at the end of the tuning is over, and must show the first received programme. Then we can change the programmes as our own select. If ASM function does not works with your TV as specified above, surely its memory IC is in trouble; damaged; and should replace it with same type and number. This IC is an eight terminal one, can be located very near to main system control IC of your set. OK.
Aug 08, 2011 | RCA RCR311B Remote Control
No channel is storing in auto mode
Hello
I don't know the Brand and Model of your TV. Yet considering it as a common fault for all TVs and posts this solution.
Your TVs memory IC has damaged. Every TV, which has auto tuning function will have this IC in it, to whcih tuned programmes details are stored as digital signals. It is a very small IC, of 8 terminals can be located very near to the system contro IC inside your tVs citcuit board. Locate this IC and resolder it out, note its number and go for a b\new one. They are easly available, and not costs too much. Replacing it will solve your problem. OK.
Jan 25, 2011 | Televison & Video
Chaild lock use ic tda 9370ps/n3/a/1930 ic &memo (remcon ic 24c016) rep but same prob i m a tech pls help me
You have to go through the MENU mode and clear it. If it is not clearing, you have to change the main IC.
24 CO16 is a programmable chip. You can not use it as it is. you have to program this. Better take help from the mfr service provider.
24 CO 16 series are eeprom and they never get corrupted! You have to check the main IC.
Aug 22, 2010 | Televison & Video
My video will play videos but will not record model dvp3350v/o5
Unfortunately since you are receiving the TV visuals and sound on the TV your tuning of the VCR tuner is correct. Hence the recording is not functioning. To confirm this further use an external source and through the video in/audio in try to record. if there is still no recording happening we have a problem in hand which may need expertise. You will need to check on the headd amp/ the video processing and the modulation using a scope to trace the failure of the signal. Normally the fault may lie with this section and the replacement of the IC will be necessary. However if the video in recordings were OK, the the mode selection/ digital switching IC may be defective. You will have to trace this out from the VIF/SIF section of the vcr Tuner. Hope this advice helps. Good day
Jul 21, 2010 | Philips Electronics - Others
Remote not turning the Zenith Plasma Display Panel TV on/off.
the remotes are usually multi function .. that is, they can control more than just the TV .. make sure TV mode is selected ... if its in VCR mode or Cable or whatever then it wont control the TV .. if its a programmable remote then it may have lost its program and would have to be set up again ... if its the original that came with the tv then that shouldnt happen . once in a while but not often i see a bad LED (at the tip of the remote) ... those are infra red so you cant see the light beam but a digital camera can .. point the remote at the digital camera and you should see the LED flashing in the cameras viewer when a button on the remote is pushed ...
Nov 05, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
Laptop would not start up
try starting your comp in safe mode by tapping F8 after pressing the power button.goto - start - all programmes - accessories - system tools - system restore. then select the date when you think your comp was working OK!
Jun 09, 2009 | Dell Inspiron 6000 Notebook
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
