Question about Barco SIM 5W Compatible Projector Lamp
Lamp i replace the lamp but light not coming
Panasonic PT-52LCX66 blinks green then red lamp light comes on
Replace the lamp cartridge. You can get the replacement DLP lamp from www.tvrepairworld.com and the lamps come with installation instructions
Oct 27, 2012 | Panasonic PT-52LCX66 Projection Television
What's your problem?The tv comes on for 1 second and turns off and the red lamp light is on
Replace the lamp. The red lamp light is indicating an issue with the lamp. You can get the replacement lamp with installation instructions from www.tvrepairworld.com
Oct 19, 2012 | Mitsubishi Televison & Video
I have a 1991 honda accord the brake lamp light comes on & off yet all of the back lights work properly why does the brake lamp light come on if the lights work properly
You can try to replace all the brake lamp bulbs as sometimes eventhough all bulbs are working but one of them is about to blow and give high resistance. That's why the brake lamp lights up.
Dec 06, 2011 | 1991 Honda Accord
My Sony LCD rear projection tv model KDF-55WF655 won't come on. Instead the red lamp light comes on. What can I do ?
Red lamp light indicates that tv needs lamp replacement as existing lamp in tv is dead/ broke.
Lamp replacement procedure is written in user manual of tv.
Thanks.
Apr 28, 2011 | Sony Televison & Video
THE TV PICTURE KEEPS GOING BLANK THEN COMES BACK ON ALL BY ITSELF. THERE IS A GREEN LIGHT FLASHING, NO RED LIGHT.
This is symptom of weak lamp in TV.
How old is this TV and did you replaced lamp recently?
If not, replace lamp in TV to fix this issue.
Lamp light does not lit solid if lamp is not broken or dead.
Lamp replacement procedure is easy and would written in user manual.
Thanks.
Jan 26, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
Replaced lamd power and lamp light are green for
Yes you need to replace lamp,so you buy a new lamp.
Dec 14, 2009 | Sharp Notevision PG-A10X Multimedia...
I turn tv on...green light comes on but i get no picture or audio....then light indicator blinks red
Hello!
Lamp or ballast(if lamp has been replaced) is bad.
Explanation: green comes on: system works, waiting for light to shine into light engine: no light is coming out of lamp, system shuts down, then you see red! how to determine: pull the lamp out of the unit's compartment. Inspect lamp: bloated stem? shuttered? reflector is not shiny? Chuck it!
Lamp looks good or just been replaced: try ballast. Close lamp compartment without lamp itself. Make sure, door is shut, as well. Turn unit on and listen close to lamp compartment: good ballast will make a buzzing noise, then stop. You've got "red'! No buzzing: ballast quit. Needs major repair! Lamp must be good, for sure, to get to the last part of diagnostics. Conclusion: more, than 2000 hours of usage: replace lamp first!
Good luck,
Alex.
Jul 29, 2009 | Panasonic PT-D5600U DLP Projector
MULTIMEDIA PROJECTOR
have you ever seen the lamp come on? has the unit been used for a prolonged period with lamp on?
May 24, 2007 | Sanyo PLC XU35 Multimedia Projector
Barco SIM 5W Compatible Projector Lamp Logo
Top Barco Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Barco Office Equipment and Supply Expert? Answer questions, earn points and help others
