Question about Breville BOV800XL 1800 Watts Toaster Oven with Convection Cooking
Tempature knob does not respond
When turning right does not increase and is loose
There are three knobs on the system. the marking are all wipe off on knob one and knob two. which knob are the timer and tempature. thank you.
Hi, here's a link to the toaster manual http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-rival-products-Site/Sites-rival-products-Library/default/v1417091459184/documents/instruction-manuals/TO600_43_20470216.PDF The top knob is the temp the bottom the timer. If you want replacement markings try here www.ovenlettering.co.uk cheers Mark.
Nov 27, 2014 | Rival TO600 1500 Watts Toaster Oven with...
Tempature knob and timer knob are the two the same
NO! They are labeled different because they perform different functions. The temperature controls how hot it get and the time I will let you guess.
My timer knob is broken. How can I order only that part?
I would advise you to call Kitchenaid Customer Service. They would be able to send you a replacement timer knob at no cost. You may simply pull off the broken timer knob, and the new knob will snap in with ease.
Their toll free telephone number is 1800-541-6390.
Jun 16, 2009 | KitchenAid KCO1005OB 1400 Watts Toaster...
I bought a kenmore toaster oven. There were no instructions.
This controls the heating elements in the oven Briol// Bake// and Toast
Dec 16, 2008 | Toaster Ovens
The knob on the bottom dial of the toaster oven has cracked and fallen off. Can i get a replacement knob so that I cAn turn the toaster oven on I need all three knobs (temp, function & timer) for my Euro...
You *can* order parts from the manufacturer directly, but good luck with that. The first time I called, and mind you their 1-800 # is a quagmire of numeric menu selections before you ever get to talk to someone, they said they would be happy to send me one but they were out/backordered and that I should call back in 2 weeks. Instead of putting me on some kind of list and sending me one when they got more...Grrr! Then I tried calling back and made it, again, through the menu maze only to find out they are in Eastern time. Super frustrating!
But I also discovered that the flat head screwdriver is the best temporary solution until I can get my hands on a replacement knob!
Dec 06, 2008 | Oster 6071 Toaster Oven with Convection...
To get new knob for my Euro-Pro K4245 I went to www.euro-pro.com and put model number in for parts search and they have knob for $1. It appears all three knobs are the same.
Apr 16, 2008 | Euro-Pro K4245 Toaster Oven with...
Toaster oven
THERE IS A SAFETY MECHANISM ATTACHED TO THE DOOR THAT TURNS OFF THE OVEN WHEN YOU OPEN THE DOOR. INSIDE, BEHIND THE KNOBS THERE IS A SPRING THAT ATTACHES TO A WIRE THAT IS CONNECTED TO THE DOOR. WHEN THE DOOR OPENS THE WIRE RELEASES THE SAFETY MECHANISM AND THE OVEN SHUTS OFF. WHEN CLOSED THE WIRE PUSHES AGAINST THE MECHANISM AND THE OVEN WORKS. I WAS ABLE TO FIGURE OUT HOW TO RECONNECT THIS FEATURE SO THAT THE OVEN WOULD WORK.
Feb 24, 2008 | Black & Decker TRO210 Toaster Oven with...
No Oven but still Toasts
Never buy black & decker they don't supply parts they want you to rebuy the same junk over & over. its a shame this is what american companies have become buy japanese they last longer and make replacement parts.(I'm not unpatriotic just an informed consumer).
Jun 11, 2007 | Black & Decker CTO650 1500 Watts Toaster...
Breville BOV800XL 1800 Watts Toaster Oven with Convection Cooking Logo
57 people viewed this question
Top Breville Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Breville Toaster Oven Expert? Answer questions, earn points and help others
