Question about Samsung HD502HJ Samsung 500 GIGAByTE SATA DESKTOP STORAGE 7200 RPM 16MB CACHE BA Hard Drive
HD502HJ vbdh dtrhdhdh
How to repair samsung HD502HJ bad sector
No way. Try to make it shorter and cut off that area including bad sectors. Make a two partition around and enjoy!
Feb 11, 2014 | Samsung HD502HJ Hard Drives Sata-ii...
Unknown device
Samsung HDD division was only recently sold to Seagate.
"ST" is a Seagate number so your drive cannot be old - manufactured by ex-Samsung factory now part of Seagate.
Utility from Seagate (e.g. Seatools) should be able to display from S.M.A.R.T the number online hours.
Dec 27, 2013 | Samsung HD502HJ Samsung 500 GIGAByTE SATA...
S.M.A.R.T Status BAD
The SMART function on your computer monitors your SATA hard drive to let you know if it is at risk of failing. This software detects bad sectors on your hard drive and repairs them when you initiate a repair. You can use the Disk Utility on your Apple computer to repair the SMART errors on your hard drive. The Disk Utility has an easy to use interface so even a novice can perform this task.
Insert your OSX install disc into the computer's optical drive. Start the computer while holding down the "C" key. Choose your language from the menu that appears. Click the "Installer" tab and then click "Open Disk Utility" form the menu, Click the "Disk Utitlity" icon from the menu and then click the "First Aid" tab at the top of the menu. Click the "Repair Disk" button and wait for the repair to complete. Restart your computer. Windows PC Click the "Start" button and then click on the "Computer" option. Right-click on your SATA hard drive and then click the "Properties" button. Click on the "Tools" tab and then click the "Check Now" button. Click on the box next to "Automatically fix file system errors" and then box next to "Scan for and attempt recovery of bad sectors. It might take some time depending on the of the disk be patient. Have no input while the chkdsk utility is in progress any input might further damage your hard drive. Click the "Start" button. Restart your computer after the scan and repair have finished to clear your SMART error.
Feb 02, 2013 | Samsung HD502HJ Samsung 500 GIGAByTE SATA...
Hd502hj problem
Windows 7 can be a pain it always seems to think the large drives are damaged whether external or usb drives.
You could run the chkdsk disk utility Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive or an easier way to run the chkdsk utility Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart have no input while the chkdsk utility is in progress any input may further damage your computers operating system and Hard Drive. Hope this helps.
Dec 18, 2012 | Samsung Computers & Internet
Why always the RED LIGHT?
Maybe the detection circuit for the diagnostic lights is faulty, if the disk utility found no issues I would continue using the hardware.
Jun 29, 2012 | Samsung HD502HJ Samsung 500 GIGAByTE SATA...
I HAVE A SAMSUNG HARD DARIVE HD502HJ AND I AM LOOKING THE DRIVER FOR THAT TO MAKE MOTHERBOARD TO RECOGNIZE IT WHERE CAN I DOWNLOAD THAT THANKS
if you physically unplug a device restart your computer then plug it in it should activate found new hardware wizard if you are having problems with a certain device it could be a driver issue
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
SlimDrivers automatically updates PC drivers with real-time scanning and cloud technology. The first cloud-based utility for updating and maintaining drivers,
SlimDrivers provides instant optimization of the interaction between a computer and its system components and periperhals, such as printers, graphic and sound cards, motherboards, USB ports, game controllers and other devices and hardware. SlimDrivers scans a PC, identifies the correct drivers needed, and retrieves them from the cloud
http://www.driver-fix.com/scan.php?id=scan5&key=2
Drivers Freeware
Now you can download driver updates automatically and safely. This handy software utility will keep your system up to date by automatically getting the latest drivers from your hardware's manufacturer - No need to waste hours upon hours every week searching the Internet for the latest driver files. You have better things to do than a driver scavenger hunt!
You could try either of these to find and fix any driver issue
Hope this helps
Feb 13, 2012 | Samsung HD502HJ Samsung 500 GIGAByTE SATA...
Hello my Samsung hard drive has a problem a year ago something went wrong then all of a sudden my samsung was gone i went straight to disk management but its not letting me make a new partition for my...
I understood your problem...my friend but some times such a type of problems are occurs due to High magnetic field. High magnetic field cause such a damage which lost all data from Hard disc.
Just format your Hard disc and while installing OS you can create the desired size Partition.
I hope you understood what is the actual problem!!!!
Thank you for giving me oportunity to solve your problem ..
please give your Ratings..!!
Jul 17, 2011 | Samsung HD502HJ Samsung 500 GIGAByTE SATA...
Hi, I have recently purchsed HD502HJ SATA drive (500 GB with 16 MB Cache) at system boot there is head clicking sound. some times it hangs and not boot and take some attempts to start. so far it bootup...
That clicking is almost always the sound of a hard drive failing. It is the sound made when the heads attempt to park. You may have purchased an old or a defective drive. If you are able to get this running, immediately back up all of your data to a flash drive to preserve it because there is no guarantee the drive will continue to work the next time.
Jul 26, 2017 | Samsung HD502HJ Samsung 500 GIGAByTE SATA...
My husband recently built a new computer (previously built 5 others successfully). Motherboard seems to be working properly. Green LED lit. Graphics card works in another computer. Power supply...
Hi, the thing to do here is to narrow down what could be causing the problem, initial suspects would be the RAM chips. If you have known working ones you can try in it, try these, if not, try without one, then swap them over, or even try without both.
Also, remove any components that aren't strictly necessary, i.e. hard drives & cables, cd-rom/dvd drives, extra PCI cards,network cards etc
Another suspect may be just a loose connection, try taking everything out, re-seating it. Again, pay particular attention to the RAM chips.
It could possibly even be a faulty processor, have you another you could try? Try taking it out and re-seating it.
Apr 12, 2011 | ASUS M4N75TD AM3 NVIDIA nForce 750a SLI...
Give me a site for cheking hdd warrenty
From the manufacturer's web-site:
http://www.samsung.com/ca/support/search/supportSearchResultView.do?group=&group_cd=&type=&type_cd=&subtype=&subtype_cd=&model_nm=HD502HJ+&dType=D&mType=&model_cd=&menu=repairpolicy&prd_ia_cd=&disp_nm=HD502HJ+
the warranty for the HD502HJ is "12 months".
Many of the drives sent to SAMSUNG for exchange, are actually defect-free. Often, there are configuration issues or corrupt data causing the difficulty. Before you send your drive in for exchange, we suggest that you try the following troubleshooting option. Many times this down-time and inconvenience caused by unnecessarily removing, exchanging, and re-installing the hard drive.
Click: On-line hard disk troubleshooting page
to run "checks" against your disk-drive.
May 31, 2010 | Samsung 500GB, 7200RPM, Internal, 16MB,...
Samsung HD502HJ Samsung 500 GIGAByTE SATA DESKTOP STORAGE 7200 RPM 16MB CACHE BA Hard Drive Logo
22 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
