Question about Compaq Evo N800v Notebook
N800v harddrive blew out
I need a new harddrive for it but idk whats the best size vs price one and what will fit in the laptop tself
  • beyblader54 Jun 15, 2009
    whats the bios
  • Compaq Master
  • 32,281 Answers
It depends upon your needs, the larger the hard drive to higher the cost and the maximun size you can install depends upon the BIOS. The smallest hard drive that is readily available is about 100Gb.
Posted on Jun 15, 2009
  • Chris Hingee
    Chris Hingee Jun 15, 2009
    The BIOS is the Basic input/output system, this system controls the basic function of a computer, such as the Date & Time, hard drive, built-in devices such as graphics video, audio, network card, keyboard etc. etc.
    To get into the BIOS configuration, press the F10 key as you switch on the computer, do not change any of the settings unless you know what you are doing.
WD 500G HDD suddenly un-readable; changed name to local disk, says I need to format in order to use it. I have tons of important stuff on there.
Could you confirm if the problem with the drive not being recognized is a problem with the USB cable? I have a 250GB passport and it worked fine with my XP. Once I decided to reformat it to NTFS and tried to do so by plugging into my new windows7 laptop the problems started.
Aug 21, 2011 | Western Digital My Passport Essential...
My lacie drive fell off desktop and is not recognized as readable by my Mac. What chance do I have of recovering the data?
Inside that LaCie external harddrive's enclosure is a regular SATA harddrive.
The kind that fits in a desktop computer (3.5 inches in width), or laptop. (2.5 inches across in width)
Open the external enclosure (Case) of the LaCie, remove the harddrive, and install it into a suitable external enclosure.
(Laptop size, or desktop size)
The external enclosure has a USB cable also. Just plug it into any available USB port on your desktop computer.
Do I know for a fact that the harddrive is okay, and this will fix the problem?
No sir/maam I do not.
But IMHO this is the first diagnostic method to use.
IF the harddrive is a desktop sized harddrive, it could be installed in your desktop computer as a Slave drive.
However the above method is so much easier, and it allows your harddrive to be an external harddrive once more.
Inside the external enclosure of the LaCie external harddrive, is a small circuit board that the Harddrive plugs into.
It is this small circuit board that receives the damage in most cases.
If the problem is the Harddrive itself, a professional data recovery shop will;
A) Try a new, or good used harddrive circuit board.
Check to see if the harddrive's circuit board received the damage.
B) If the circuit board proves to be good then the next step is to remove the Platters inside.
The room used is a Clean Room.
A room that is 99.9 percent dust free. (In most cases)
The Platters are installed into the case of a compatible harddrive, that has the Platters removed.
Then as much information as possible is copied off.
There are other methods data recovery specialists use also.
[A Harddrive is built in a Clean Room. 99.9 percent dust free. The technicians wear a Clean Suit, that resembles what a doctor would wear in an operating room.
They enter the work area after going through a corridor, fitted with air jets at various levels.
If a harddrive is opened up in a room that is not a Clean Room, the harddrive's 'life expectency' drops to a day, or a few hours. The dust 'kills' them ]
http://computer.howstuffworks.com/hard-disk.htm
http://www.youtube.com/watch?v=gpY8c7lT_7k&feature=related
http://www.youtube.com/watch?v=ax390l2A-AY
Observe the other videos also.
Examples of both a SATA 2.5 external enclosure, and a SATA 3.5 SATA enclosure,
(The Harddrive's width is measured in inches. (2-1/2 inches for a laptop drive, 3-1/2 inches for a desktop drive)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
SATA 3.5 external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4421576&CatId=2780
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 02, 2011 | LaCie Hard Disk design by Neil Poulton...
Hard drive for my dv 2842 se crashed.. I want to replace it..Which Hard drive I should go for and what all things should I keep in mind
A good place to look for a new harddrive is newegg.com. What you want to look for is a large cache, fast read/write speed RPMs and harddrive size. A good laptop harddrive would have 7200RPMs 32mb cache and roughly 500 GB harddrive space. Also check quality by viewing user reviews. I personally like Western Digital.
Mar 07, 2011 | HP Pavilion dv2842se Notebook
Can I replace my gateway T-6836 laptop 250 gb hardrive
Yes, it can be upgraded for a larger drive. The important specs to know are the physical size and the interface. The size that this computer needs is the 2.5 inch and the interface is the SATA. These are the typical size and interface used today so finding a drive that fits should not be a problem.
Hope this helps.
Jun 30, 2010 | Gateway T-6836 Notebook
LIQUID COME OUT OF THE BLUE LENS NOW TV WILL NOT COME ON
Needs a new blue gun and the others should be looked at as well. Not an inexpensive repair, 300-400 parts & labor. New LCD's in the same size are close to that price now. Weigh the cost vs. replacement, call a TV repair shop and get the price of the part then go look at new TV's. Best of luck. Hope this helps
Jun 11, 2009 | Philips 46PP9302 46" Rear Projection...
Compaq evo n800v saying non system disc or disc error
You need to check in the BIOS to see if the hard drive is being detected. Other than that, do you have like a flash disk or a media card attached to it when booting up?
Mar 06, 2009 | Compaq Evo N800v Notebook
My Scroll botton will not work on my Evo N800v
You dont need to use the scroll on the touchpad just use the up and down arrows on the right hand side of your touchpad, you will find this easier to use and operate too
Feb 21, 2009 | HP Compaq Evo N800v Notebook
Broken dell inspiron 2650, what do I need to do,
If you "accidently" can repair this laptop, then you get a reasonable good computer.
you will find the price for your RAM here:
you will find the price for your HDD here:
you will find the price for your HDD caddy here:
-> the rest is up to you
plz let me know how you are going regards /Teis
Jan 11, 2009 | Dell Inspiron 2650 Notebook
Toshiba satellite a205-s5831 Received kernel data error. Hard drive has clicking noises. Programs ran slow. Chkdsk running now for over 15 hours and only on 11%..preplacing bad clusters.
When a harddrive starts clicking it's on it's way out.
Buy a new harddrive and at the same time get a USB to laptop harddrive adapter. You can reinstall XP with the recovery disks that came with your machine ans then slave your old drive to your laptop and recover your personal files.
If you really want to get technicalbuy an Apricorn housing: http://www.newegg.com/Product/Product.aspx?Item=N82E16817155602
And two new harddrives, fit one new harddrive to the Apricorn housing and try to install the EZgig cloning software to your dying Windows. You can clone your existing Windows install to the new harddrive in the Apricorn housing and then move that drive to your laptop, the second new harddrive can then be fitted to the Apricorn housing and used as an external harddrive.
EZgig comes with the Apricorn housing and you could even go so far as to create a clone of your Windows install to the new external harddrive. The Apricorn housings are excellent, they are small enough to carry in your laptop case and all they need for power is a USB port.
Sep 01, 2008 | Toshiba Computers & Internet
Laptop harddrive
Hey,
Debends on what is the current size of the HardDrive
For example a ATA 80GB drive here - EBAY
Thanks,
Ekse
Aug 29, 2008 | Dell Inspiron 8600 Notebook
Open Questions:
How to Remove a Virus from Windows PC or Laptop - Toshiba Dataalign As the number of cybercrimes and harmful online attacks are increasing these days, it is difficult to keep ourselves safe while surfing the websites of various sites online. If you are looking for a safe online risk reduction scenario, then trust the tech support of TechFree for Toshiba products. Toshiba laptops and other devices get best maintenance and recovery by the services of Toshiba support. Toshiba support provides best risk safety from online threats and also recovery for broken computers and other peripheral devices. Online threats in the form of viruses, Trojans and malwares that are prevalent everywhere pose serious safety threats to the customer's personal information. Various other regular issues like slow computers, snail speed processing, recurrent screen freezing, frequent and without reason computer shutting down and restarting etc. also prove to be a reason of headache for the customers. In case you want all your tech issues to get resolved while you can be busy doing your usual life stuffs then get in touch with the fabulously supporting Toshiba supprot team. You can get the benefit of 24/7 tech support service at your home or office by calling on their toll free helpline number Call Toshiba +1888784-9316 Technicians of Toshiba support got certified for involvement of advanced technology and still making it available for customers at affordable prices. Also, many profitable deals and offers are provided to the customers. Your search for that perfect tech support with features like reliability and consistency is over with Online Toshiba support Email service technique makes delivery of support easier and comfortable for the customer. Also, professional tech services become more trust-worthy with the 30 days money back guarantee it comes with. Toshiba technicians make efforts of delivering the best customer support along with proper knowledge sharing which helps the customers to get proper understanding about all issues and their resolutions. For tech related support contact tech service team of TechFree on their toll free helpline number Toshiba Customer +1888784-9316 anytime. Toshiba support providing professional and certified tech experts will use the most appropriate troubleshooting to resolve tech issues in least turnaround time.
Aug 22, 2018 | Toshiba Computers & Internet
See all Compaq Evo N800v Notebook Questions
Compaq Evo N800v Notebook Logo
114 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
