Question about iLive IHB613B - Ihb613b Black Home Music System With Bluetooth
Stereo works CD player won't play cds
Started out playing CDs then when I put another CD in screen showed no CD progressed by putting on CD that previously played to no avail
My sharp cd-ba200 will barley play cds
Put the player On for few hours or overnight. Now remove the panel and get access to the optical head unit, use a clean ear bud to polish the optical head. If not the optical head is weak and must be replaced.
Mar 14, 2012 | Sharp CD-BA200 CD Shelf System
Alpine CDE0-7826P Cd Player doesn't always work
If It dosent play burned cds its not an mp3 compatiable cd player as far as the other problem kinda seems like its time for a new cd player
Jun 14, 2009 | Alpine CDE-7826P
It wont play CDs
the cds you put in there are not compatible to the player.if it had been playing the same cds then it is time to take your set to a tech for repair it can be your memory chip or your lens.good luck.
Apr 18, 2009 | Memorex MKS5009 Karaoke System w/CD/CD+G...
CD changer will not play reads "player error" .
Most new car-stereo's don't have an "oldschool" CD-drive, but really a CD-ROM drive; meaning that they won't (properly) read and/or play copy-protected CDs.
Most CD protections are specially designed not to work in CD-ROM drives to prevent copying. As a side-effect most of those protected CDs won't work in car-stereo's.
Try a CD without copy-protection (like an homemade audio CD using burning software on your computer) and see it that works ?
In case that doesn't work either, your car's CD-drive is probably broken ...
Mar 22, 2009 | 2004 GMC Envoy
Cd/stereo
I had the same problem with a different CD player. It turned out that there were 2 CDs in the player.It is only meant for one. I had to use a flat plastic spoon handle to gently lift the cd up and I saw there were 2 cds in it. I removed the player and took the cds off. it fixed the problem.Somebody must have put in another CD on top of the other one. I couldn't figure it out for a while. Maybe that's your problem too.
Aug 04, 2008 | 1999 Nissan Quest
CD won't play in stereo receiver
Are these CDs burned copies?
If they are, some CD players don't read burned copies at all.
Feb 25, 2008 | Audio Players & Recorders
Trouble playing store bought cd's
itll be the lens on the player clean it with surgical spirit
Jun 26, 2017 | Lenoxx Electronics CD-102 Cassette/CD...
iLive IHB613B - Ihb613b Black Home Music System With Bluetooth Logo
70 people viewed this question
Top iLive Audio Players & Recorders Experts
cwradio73
Are you an iLive Audio Player and Recorder Expert? Answer questions, earn points and help others
