Question about Schlage COBRA by Keyless Lock
Battery pack how do I remove the cover to change the batteries
How do we charge or change batteries?
Remove the batter cover on the back and replace the batteries. If you wish to charge the batteries using the charger, you will need to purchase a battery pack from a battery store or from an online vendor.
Jun 11, 2014 | Midland LXT317 Two Way Radio
Tip
How to reset Nintendo DS Lite.
Remove the cover for the battery compartment. At the back of the DS Lite, the cover has a small screw holding it in place. You will need a Phillips size 0 screwdriver to remove it.
Take out the DS Lite's battery pack. There is a tab at the top of the battery pack. Insert your fingernail or the end of the screwdriver carefully into the edge of this tab and pop out the pack.
Keep the battery pack out of the unit for at least 10 seconds. If you keep the battery pack out for too short of a time, it will not cause a reset in the unit.
Put the battery pack back. Just line it up in the compartment and push it back into place.
Replace the cover. Replace with the screw.
Turn on the DS Lite. If the unit has properly reset, a screen will come up that reads "Before you begin, you must adjust system settings." You can now enter all new settings and information on your DS Lite. If you do not get the system settings screen, you did not keep the battery pack out long enough. Repeat the steps and leave your battery pack out for a longer period of time.
on Feb 12, 2010 | Computers & Internet
How to change drive belt on tor o 8-25?
disconnect the spark plug wire from the spark plug
Remove the battery pack cover, the battery and the fuse.
Remove the screw inside the battery cover and the screws that hold the belt cover underneath the mower.
Remove the screw from the battery bracket.
Flip the mower on its side to access the bottom and remove the belt cover.
Remove one of the screws holding the belt guide in place. Loosen the second screw holding the belt guide.
Move the belt guide away from the belt driver assembly.
Loosen the drive belt by loosening its tension around the pulley and pry the belt from the fingers of the bracket.
Jun 04, 2014 | Toro Garden
How to open APC UPB10 battery pack to change the chargeable battery?
1. Remove front cover by sliding front panel down.
2. Install 4 new AAA (LR03) batteries (sold separately) and replace cover.
3. Turn unit on by sliding ON/OFF switch towards USB port. LED will
illuminate.
4. Plug USB charging cable (sold separately) into the Emergency Power Pack's USB port.
5. Plug the other end into your mobile device. (Make sure you do this last, as a few devices will not recognize the charge otherwise). Your device is now being charged
Apr 27, 2014 | Computers & Internet
How could i change its batteries?
  • Your radio, Midland LXT110, utilizes a NiMH rechargeable battery pack or 3AAA batteries. I have a similar set and when the battery pack runs out I just use regular AAA rechargeable batteries. They are more economical. To change the batteries in general follow these steps.
  1. Remove the back clip.
  2. Now remove the battery cover by pushing down from the top center of the battery cover and slide it off.
  3. Replace batteries observing polarity.
  4. Replace the battery cover.
  5. Replace battery clip.
Regards, Tony
May 17, 2011 | Midland LXT110 Two Way Radio
How do I change the ram chip?
1 Turn off the computer, unplug the AC adapter (if connected) and remove
the battery pack. Then turn the computer over to access its base.
2 Remove the screws from the memory cover; then lift up and remove the
memory cover.this cover is in the center of the machine on base
3 (a) Insert the memory module diagonally into the slot, then (b) gently press
it down until it clicks into place.
4 Replace the memory cover and secure it with the screw.
5 Reinstall the battery pack, and reconnect the AC adapter.
6 Turn on the computer.
The computer automatically detects and reconfigures the total memory size.
Jan 04, 2011 | Acer TravelMate 5520 Notebook
Need to change the batteries in a Stanley bar flex light. lost instructions. how do you change the batteries.
I know this thread is old, but I just had to change the battery pack in mine. I could not locate a 4 pin battery pack so here's what I did:
You'll need: 3 NiMH 1.2v AA solder tab batteries, Razor blade, #1 Phillips driver, Kapton tap (standard electrical tape will do), soldering gun/iron, spare 18awg wire
1. Use a razor blade to remove the black sticker from the bottom of the flashlight base, it covers the magnets
2. remove the three outer phillips screws (the inner ones hold the magnets in and can stay installed)
3. Pull off the bottom plate
4. Pull out the battery pack and disconnect it from the flashlight at the 4-pin queeze connector
5. Remove the outer wrap and end protectors from the old pack keeping the end protectors in tact
6. Assemble the 3 new batteries in the same configuration as the old pack using Kapton tape, connecting + to - at the same two spots (use the old pack as a reference)
7. Carefully desolder the 2 wire leads from the old battery pack
8. connect up the 2 power wires to the same two spots as the old pack and insert the temperature probe between two of the batteries as in the old pack
9. Put the end caps on the new pack and wrap the entire thing in Kapton tape to simulate the plastic wrapper you removed
10. Install pack in to base, secure bottom plate and re-adhere black sticker(if needed you can use non-foam double-sided tape or spray adhesive)
The old pack was rated at 1300mAh and I used three 2000mAh each for a total of 6000mAh so theoretically the light should run for about 6 times as long between charges.
Aug 28, 2010 | Garden
Batteries dont last very long after batteries are fully charged
It is time to replace them. You will find the repalcement battery pack for model 6885XL at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
To change batteries, you will need to remove the back cover by removing the two screws. You will then be able to access the batteries. It is easier to work with if you remove the metal clip at the bottom of the shaver that covers the ends of the batteries.
For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs.
Feb 22, 2010 | Norelco Quadra 6885 XL Electric Shaver
Wii remotes will not stay on
1. Press the Power button on the Wii console to turn it on.
2. Remove the battery cover on the back of the Wii Remote you wish to sync up.
3. Remove the battery pack & install regular batteries.
4. On the back of the Wii remote press the SYNC button just below the batteries. The Player LED will blink.
5. Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment.
6. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
7. Quickly remove the batteries and reinsert your Battery Pack.
8. Return to Step 2 for each other remote.
You may run into this issue any time your battery pack has a 0% charge left in it for a duration. Try to keep them charged to prevent it from occuring in the future.
Dec 16, 2008 | Nintendo Wii Console
Hard drive
These instructions should help.
Toshiba® Satellite 100, 105, 110, 115, 200, 205, 210, 400, 405, 410, 420, 430 Series
Hard Drive Installation Instructions
  1. Turn notebook upside-down.
  2. Remove the battery compartment cover.
  3. Remove the battery pack.
  4. Remove the 2 Phillips screws that mount the hard drive down.
  5. Slide the hard drive away from its connector and gently lift it out of the notebook.
  6. Remove the tray from the old hard drive and assemble it onto the new hard drive.
  7. Slide the new hard drive into its connector inside the notebook.
  8. Replace the 2 Phillips screws used to mount the hard drive into place.
  9. Replace the battery pack.
  10. Replace the battery compartment cover.
Jul 28, 2008 | Toshiba Satellite A100-S8111TD Notebook
Schlage COBRA by  Keyless Lock Logo
66 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
ken skalski
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
