Question about ifrogz Earpollution Toxix Headphones
Toxix headphones sometimes only one side works
Sometimes only one side of my headphones works. Other times, both sides will work. I don't know if the problem is the position of the wire or what, but its really aggravating.
You can remove the soft bit on the headphones protectin the ear, after that you can remove the plasic inner covering with a very small phillips head screwdriver, then you can see the wires inside and figure out how to fix the problem.
Posted on May 07, 2015
Bose qc15 right side not working
If the cup itself is not cracked or broken, you can carefully detach the "snap on" cushion to expose the inner workings. There may be an inner cover which also can be carefully detached to expose the wire connections. After making repairs, reverse the disassembly process.
Jan 10, 2014 | Bose QC15 Headphones
Right side of headphone stoped working
you need to open the broken side up and re solder the cable back also check the other cable to see if it hasn't sheered off inside the insulation like mine did. Hope this helps. J
Feb 17, 2013 | Philips SHB9100/00 Bluetooth Stereo...
Left Side of Coby-215 Headphones Don't Work?
sounds like you have a broken wire to the left side . we can not FIX that here
Nov 16, 2017 | Coby CV215 Headphones
Passenger window goes down but not up
On the passenger side pull carpet back by the kick panel you will see some wires loomed together pull the loom off u will see several wires spliced from the factory those get worn from passenger traffic...
Nov 17, 2011 | 2001 Pontiac Montana
Left turn signals don't work, but rt does.
turn signals need full 12.7 battery voltage to work sometimes when the batt is loww only one side will blink ,if the flasher is bad sometimes only one side will blink charge ur batt and try again a quick check to see if both sides are wired correctly or that the wires to the side not working is to unplug the flasher a small square box sometimes under tank or left side cover and jump the two wires and put blinkers on each side they should come on but not blink and that will tell u if ur flasher is ok or not good luck!
Aug 23, 2011 | 1982 Yamaha XJ 650
Left side of my sharper image ct411 doesn't work at all.
Check your cable and make sure there aren't any frayed or cut wires. If your cable looks good, then open up your headphones and make sure the connection to each speaker is correctly soldered. Sometimes when you expand/contract the size setting on these headphones it pulls the wire until it eventually disconnects. I hope this helps!
Aug 31, 2010 | Sharper Image (CT411) Consumer Headphones
Is it possible to connect my headphone SBC HC 8395 to my PC and to wich outlet do I have to connect?
i cant see from any website, but one i did translate - looks like a standard Jack plug, if so it should work OK - you can also get adapters
If a PC - should have a headphone socket at the front, or it may be on the back audio card outputs - sometimes coloured Lime Green - or on a laptop - you will have the socket on the front or sides - usually with a headphone symbol OR sometimes coloured a lime green
Apr 12, 2010 | Philips Audio Players & Recorders
ifrogz Earpollution Toxix Headphones Logo
200 people viewed this question
Top ifrogz Audio Players & Recorders Experts
 Grubhead
Grubhead
 binay biswas
binay biswas
Tom Chichester
Are you an ifrogz Audio Player and Recorder Expert? Answer questions, earn points and help others
