Question about Humax Dtr-T1000 Youview Digital Tv Recorder
Recordings only recording some of programme
Recording does not record full programme
  • 6 Answers
SOURCE: Humax DRT800 DVR recorder has no sound
Loss of sound is often a problem with the SCART connections. The SCART may not be pushed in securely, or if the SCART is old the pins may not be good. Check SCART is securely in, or try another SCART lead.
Posted on Mar 22, 2009
SOURCE: havejust bought a digital t.v.recorder, which was
We have since contacted the manufacturers. It's their product, why should we pay someone else to deal with their problem? We have just bought the ruddy thing, we don't want to be paying out again. Thanks anyway, Julie.
Posted on Nov 09, 2009
davidgut_99
  • 33 Answers
SOURCE: DRT400 TiVo 40-Hours Video Recorder: unable to delete programmes...
Do a complete CLEAR and ERASE.
This should fix the problem.
Posted on Jul 05, 2010
  • 11800 Answers
SOURCE: We have had a Humax
Simple test: try to access, view and delete several programs. If you can do that then the fault is in the hdd - either it's full and you need to wipe more programs to free more space or the disk itself is dying. If it's the latter recover whatever programs from it you can, while you still can, and replace it.
If you can't access the programs but no error message is displayed it's the firmware/processor of the box - they are failing . Start saving for a new unit, this one is circling the drain.
Posted on Aug 26, 2011
gopakumarg43
  • 74185 Answers
SOURCE: It stops recording a few minutes before the end of the programme
Hello
A firmware update is necessary with your Humax Foxsat receiver. Get into Humax site and update the device with latest firmware. OK.
Posted on Oct 27, 2011
I recently purchased the Toshiba DR570KU DVD recorder. I live and purchased this machine on a small Caribbean Island,and with respect to local people they have no technical knowledge of what they are...
Hi -
I'll try to explain without confusing you any further, but if anything doesn't make sense, please let me know. The instructions on page 79 are contradictory, which doesn't help very much. The upper part of the page suggests you can create extra space on a DVD+RW disc by deleting titles, while the lower part, in the grey box, states you cannot. The bottom part is actually correct.
I'll split this into two sections - blank/unused and used discs then explore a few scenarios.
Blank/unused discs
A DVD+RW is typically 4.7GB and will record approx. 2 hours of video in SP mode or 4 hours inLP mode. If you record more than one programme, they will appear consecutively in the disc editing menu, and shown as numbered blocks in the Title List. The last block shown will always be 'EMPTY', but the actual size of this block can be all or none of the total capacity of the disc.
If you insert a blank DVD+RW disc into the machine and view the title list, you will see this:
Although you can't 'record' to a block labelled EMPTY, this doesn't mean you cannot record to this disc. The blank space on the disc precedes the block labelled as 'EMPTY'.
If you then record one programme of 1 hour duration in SP mode. the title list will look like this:
Once again, although you can't 'record' to the block labelled EMPTY, this doesn't mean this disc is full or that you cannot record anything else on it. The next programme recorder will appear between title 1 and the 'empty' block - as long as there is sufficient space on the disc remaining to record the programme.
If you then record a second programme of 1 hour duration in SP mode. the title list will look like this:
This disc is now full as 2 hours of video has been recorded in SP mode. However, if you'd only recorded 1 hour in total for these 2 programmes, you would still be able to record another hour of video in SP to this disc. The additional programmes would appear between the last numbered title and the 'empty' block - until the disc is full.
The empty block is always present and you cannot 'get rid of it', but it doesn't mean the disc is full or cannot be recorded on.
Hopefully, this goes some way to explaining it, but I still need need to explain what happens with used / full discs when you want to delete programmes and re-record.
There is a maximum length for messages posted on FixYa and I may be getting close to this, so rather than break off in mid-flow, I will continue the explanation for used discs in another message below this one. I will do this right now, but it will probably take me 20 minutes or so to write part 2, so keep checking back. It will be less confusing if you hold any questions until I've written part 2, but I will be happy to answer any after that.
Regards,
BElectric
May 02, 2011 | Toshiba DR570 DVD Recorder
My Thomson Top up TV box will not record. I go to the TV guide, press the R button. It then takes me to 'Planned Recordings' list. I press R again and the programme I want to record disapperas. I get...
Sounds to me like your hard drive is full. Do you use the topup tv part of the box? If not, deselect all the topup tv channels. This will free up a significant amount of drive. Failing that, you'll have to delete some of your programs, sorry!
To deselect topup tv channels;
Go into the menu option, Customise Top Up TV Anytime, and de-activate all the selected channels
Jan 23, 2010 | Televison & Video
I have an HDD rerecorder that now sjips and freezes
HD takes more info and if you don't have a fast enough processor to handle this, that might be the problem.
The age of the recorder would tell you that. If it's 3 years old that might be it. Also how can the recorder record the HD signal unless it has the right tuner??
Dec 29, 2009 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Stop Substitles on a LG RHT497H 160G dvd recorder?
I have the LG DVD recorder DRT389H which has the same problem. You can't switch off the subtitles during timer recording from the Electronic Programme Guide. The only way I could stop this was to go to the main set-up menu then select the A icon. Select DTV Subtitle and choose a language that the TV programme isn't broadcast in. I chose Gaelic. The only disadvantage is that this stops any subtitles being recorded so you can't access them later.
Dec 26, 2009 | LG RH177 DVD Recorder/HDD Recorder
Cannot record without watching the programme
This unit does not have twin tuner,you would have to watch another channel on the tv.
Dec 03, 2009 | Panasonic Televison & Video
I have purchased a Teac HDR2500T video recorder. I can set up to record television programme through EPG or PVR. I can see in LIST that the programme is recording, however when the programme is finshed,...
The part re the other channels having no signal....I had the same problem with mine and that was because the small loop cable in the back wasnt right. I could watch all channels, press record and still watch that channel but try to watch a diff channel while its recording and they were gone. As soon as I had the loop cable in properly it solved the problem. Hope this helps....
Sep 06, 2009 | Televison & Video
Can't finalising the recorded discs, and can't record at high speed from SKY box to DVD recorder.
instruction man available on line
plug the sky output cable directly into the recorder then press record
Jun 01, 2009 | Televison & Video
My Thomson freeview recorder box wont let me record anything as it saya that my drive is full but it freezes when i try to delete some of my recordings
Marriott, You will find that it is only one recording that is causing this. This also happens to my box as well when we tape emerdale on a Monday. look through what has been taped and find out if the minutes used is correct for that programme. if not then you need to do the following in very quick procession.
Press the delete button and confirm as quickly as possible when you scan down the the programme that has not recorded correctly.
Hope this helps
Norrie
Oct 10, 2008 | Televison & Video
DTI6300 recorder. Sometimes records and sometimes not. Seems to record, red light on, and then lists programme as recorded, but then only plays a blank screen.
had it 3 months,it was fine,now it has stopped recording and has erased all programmes i had recorded,do i just take it back to comet?
Aug 02, 2008 | Televison & Video
Programmed recording to the hard drive
Either You haven't set the time/timer correctly or you need to find a way to clear/format the hard disk.
Aug 16, 2007 | Samsung DVD-HR735 DVD Recorder/HDD...
Humax Dtr-T1000 Youview Digital Tv Recorder Logo
73 people viewed this question
Top Humax Audio Players & Recorders Experts
Jay Plesset
Are you a Humax Audio Player and Recorder Expert? Answer questions, earn points and help others
